1. Дорогие одноклубники!
  1. RRomario
    RRomario Старожил
    17 янв 2010
    8.488
    Allroad 3,0TDI '09
    Не, Вась, пока не до нее. Мне и 3Г пока хватает. Но тему я курю постоянно - надо быть в тонусе.
  2. FareZ
    FareZ Новичок
    24 мар 2014
    15
    Q3 2.0 11г.
    Обновление карт MMI 3G+
    Добрый день, коллеги.
    Хотел бы поделиться историей успеха :rock:
    Что было исходно:
    1.AUDI Q3 2011 г.в.
    2.MMI 3G Navigation Plus в следующем составе
    HW version 9411 (без сим)
    MU version 0425
    Прошивка HN+R_EU_AU_P0490
    Navigation database 8R0060088N ECE 5.12.5
    Что было сделано на протяжении года:
    1. Собрана сборочка для размещения в подлокотнике:
    AMI(USB)(4F0051510Q)->D-Link DUB E-100 (vB1)->cableEth-(RJ45)->Router TPlink3040->LTE 4G модем (сим карта Yota тариф 512К)
    Инструкция по установке от DUK63
    Hi my friends,
    sorry if I write in english and not russian but I hope that you can use Google translator to be able to read the thread.
    Below you can find a guide how to enable online services in MMI 3G+ without sim: I mean unit 8R1035666.
    With online services I mean Google earth, online traffic, audi connect and poi search with Google.
    As first thing I have to say thanks to DUK63 (a fantastic person) and Sergey (admin and author of http://turbo-quattro.com/ forum): they gave me many suggestion and information needed to give positive results.
    The solution is based on AMI -> USB connection: if you don't have it you can create a USB connection following DUK63 guide.
    The unit MMI should have at least 612 firmware.
    Having a usb connection in your MMI, the information you must know (DUK63 already wrote it) is that MMI accepts only hardware based on chipset:
    AX88772
    AX88772A
    AX88172
    You must buy a usb->RJ 45 converter.
    I advice dlink DUB E-100 (rev A4 or B1), or Gembird NIC-U1 (as DUK63 suggested). I buyed dlink on ebay for 20 euro (with shipping).
    After that you must buy a wireles router: I adive tplink 3020 or 3040. I buyed a 3040 at a very good price in amazon (35 euro with shipping).
    The router must be configured in wisp client mode: connected to dlink with rj45 and wirelss to your mobile phone (you have to enable router wifi in mobile phone to be able to share mobile data connection). You could use also a 3g/4g mobile connection instead of your phone: as you prefer.
    The connection is:
    AMI(USB) ->DUB E-100-> cableEth-> (RJ45) Router3040 (WiFi WISP mode) ->))))) wireless (((((<-Android
    Now we can configure MMI.
    At first you have to enable hidden menu: set channel 6 in adaptation to value 1. Reboot MMI.
    Then you can enter to hidden menu pressing car+menu button for some seconds.
    In the hidden menù you can see the dlink:
    /config/Console
    Inside MMi hidden menu you have to set:
    1. /diagnose/coding/internal_modules_1+2:
    Here you have to deselect all "Online ....(off)" entries.
    Don't touch other entries.
    2. /config/
    Here you have to click on "Install Fair Mode": this will install dhcp server and DLinkReplacesPPP route.
    3. Now you have to set DNS: file resolv.conf.
    (Коментарий от FareZ:
    Данное действия я выполнял скриптом:
    скрипт находится по этой ссылке, для указания сервера DNS необходимо поправить файл run.sh в блокноте - можно использовать любой DNS сервер сети Интернет, либо адрес непосредственно роутера - я бы рекомендовал этот вариант, так как отклик через мобильную сеть до DNS сервера в сети интернет явно выше чем до роутера, могут быть обрывы в связи на медленном канале (в моем случае это был 192.168.1.1)
    http://digilander.libero.it/plauto5/mmi/ok/dns.rar)
    To do it I used the trick already explained by DUK63: extract the below file to sd and then you can execute it.
    Rebbot MMI and then in the hidden menu you will have:
    If inside info screen->settings you don't have the row "Online traffic data" to enable, you must set bit 15 in channel 69 of adaptation of MMI: this means to add 32768 to value you have in the channel. If set, reboot MMI.
    You have to add 32768. So if you had 15 now you have to enter the value 32783.
    After all these operations you have the options of google earth and traffic in navigations, you can search poi with google.
    To enable online traffic you have select "Online traffic data" to yes and after connecting to audi server, the licence will be activated for 3 years.
    Thanks!
    The GEMMi is included in firmware 612.
    You can switch from conventional maps on Google maps (or any type from maps) in settings page of navigation.
    2. Подключено инженерное меню скриптом
    3. Последовательно обновлены прошивки со стоящей P0490 -> 8R0906961AM(485) -> 8R0906961BM(518) -> 8R0906961BT(612) -> 8R0906961DG(770)-> 783
    Прошивка 783 + карты 8R0060884CH + Carson activator 4. Обновлены карты с версии 8R0060088N ECE 5.12.5 до версии 8R0060884CH ECE 6.20.4
    5. Активированы карты при помощи активатора Carson
    Что имеем в итоге:
    Заработали TMC и Онлайн. Яхууууу ))))
    Онлайн активировался на прошивке 770, после установки прошивки 783 и обновления карт - лицензия не слетела.
    Вин в Car меню не отображается
    Надеюсь мой пост будет полезен кому-либо :)
    Готов поправить и дополнить и пояснить - пишите в личку )
  3. VasilbV
    VasilbV Директор БАНи
    13 май 2008
    13.357
    Вожак стаи
    Отличный отчёт )
    Это легко поправимо )
  4. FareZ
    FareZ Новичок
    24 мар 2014
    15
    Q3 2.0 11г.
    Не докурил :shock: Поделитесь информацией? буду рад добавить в историю успеха :nod:
  5. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    #1545 VasilbV, 3 июн 2015
    По факту VIN так и останется скрытым, т.к. таков принцип работы активатора - тут ничего не поделать
    Но существует патч, который надпись "VIN ещё не передан" заменяет любым VIN, в частности, своим
    Ссылка на VINPatcher1.0.0.3
    В итоге получим как-будто нет никаких активаторов и штатно отображается VIN
    Там в самой программе в Справке есть инструкция, если что не понятно - спрашивайте. Но если в двух словах то:
    1. Запустить программу VINPatcher
    2. Записать на SD карту скрипт
    3. Вставить в MMI и запустить скрипт
    4. Вернуть SD карту в компьютер и модифицировать скаченный из MMI файл с помощью VINPatcher, введя свой VIN. Скрипт перезапишется
    5. Снова вставить SD карту в MMI и дать отработать скрипту
    Всё, готово
  6. igor33
    igor33 Заблокирован
    19 июн 2010
    19.985
    А6/С6 3.0i Q 05
    Кстати Василий, спасибо! Лекарство твоё помогло.
  7. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    На здоровье )
  8. Vlasoff
    Vlasoff Tell me
    3 мар 2014
    2.683
    А5 TDI 190Q, Q5 TDI 177Q
    Вин патчер фактически формирует и подставляет изображение в котором ваш вин.. Василий правильно написал.
    Но.. Как говорится, на скорость не влияет:)
  9. FareZ
    FareZ Новичок
    24 мар 2014
    15
    Q3 2.0 11г.
    Собственно это и понятно, что подставляется "заглушка", зато визуализация :rock:
  10. igor33
    igor33 Заблокирован
    19 июн 2010
    19.985
    А6/С6 3.0i Q 05
    Влияет.
    Когда инспектор просит вин показать в MMI, это часто очень сокращает время задержки.
  11. r_Q7
    r_Q7 Живу я здесь
    12 дек 2011
    4.173
    Audi Q7 4M
    #1551 r_Q7, 3 июн 2015
    Что-то напрашивается фраза >> не верю << ...... В части " ОнЛайн " ..... Активации на 2011 в штатном режиме запроса лицензии...
    Если конечно чудом сервак ауди воспринимает VIN ошибочно - но и это проверить можно на my.audi.com (сомнительная проверка - 50% на 50% но слышал историю про то как выдавался PIN по вину (без sim) и авто высвечивалось иное - тока это слухи ... (если выдаст не Q3 2011г -.............) а так....
  12. FareZ
    FareZ Новичок
    24 мар 2014
    15
    Q3 2.0 11г.
    Лицензия на дорожные данные до 14.05.2017. Активировал год назад.
    Пин не дают :( аппелируют тем, что не входит в комплектацию автомобиля функция.
  13. Lasy
    Lasy Make Russia Warm Again
    31 июл 2008
    11.837
    Q7 TDI 2015
    Интересно, кто то реально пользуется My Audi в плане прокладки маршрута и последующего переноса в авто? Как это функционирует? Удобно? Или нах не надо?
  14. BigD
    BigD Завсегдатай
    6 авг 2011
    886
    Audi A7
    Т.е. Вы хотите сказать, что если я поставлю Ами онлайн на карты 2011 г, то меня заблокирует и никакой активатор не поможет при обновлении карт?
  15. Grafik
    Grafik Старожил
    12 фев 2009
    5.059
    А3 8V 1.8 quattro ABT
    Я поигрался на А3 этим пару раз и забил.
    Это ж сесть за комп, взять карточку, зайти в инет, скачать, перенести в авто.
    Вобщем в рекламе все красиво на деле так себе. Просто фишка, прикольная, не более.
  16. Lasy
    31 июл 2008
    11.837
    Q7 TDI 2015
    Я так и думал, что муйня.
    Кто то в курсе, не собирается ли Ауди "поженить" MMI с Apple на подобие CarPlay?
  17. BigD
    BigD Завсегдатай
    6 авг 2011
    886
    Audi A7
    2016 модельный год :)))
  18. Vlasoff
    Vlasoff Tell me
    3 мар 2014
    2.683
    Пусть смотрит вин под капотом! А из меню вообще убрать этот пункт.
  19. r_Q7
    r_Q7 Живу я здесь
    12 дек 2011
    4.173
    Audi Q7 4M
    #1559 r_Q7, 4 июн 2015
    Вот в это можно поверить :)
    Год назад еще не было привязки к дате продаж.
    а после 6 месяца 2014 года уже не але.
    А вот если сейчас люди (впервые) с авто 2011 года попробуют запросить лицуху будет ОФ ....... отказ.
    А то выдал отчет спустя год ;-)))
  20. Q Sieben
    Q Sieben Живу я здесь
    22 июн 2011
    2.134
    Q7 4M
    или на стойке центральной
    уже это обсуждали вроде, вин в мми смотреть безпонту, там любой можно показать.
