Кто-нибудь работал с VAG K+CAN 1.4 Commander Diagnostic Tool?
Тема в разделе "Ремонт Ауди", создана пользователем olll, 9 дек 2008.
  1. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    Есть вариант довольно дешево взять такую штуку (Шнур + софт)...
    Лично мне, нужно обнулить crash-data. Все остальное идет внагрузку. Интересует, возможны ли описываемые функции на моей машинке?
    VAG K+CAN 1.4 Commander Diagnostic Tool Audi VW OBD 2
    -----= latest version of Vag K+CAN Commander =-----
    Diagnostic via CAN and Special functions via K-line.
    Covers all electronic control units in vehicles (diagnostic addresses from 0x01 to 0x80). This can allow of user to investigate and diagnosis some new units untouchable for remaining diagnostic tools. Functions are under CAN-TP2.0.
    Manual definition of running diagnostic session ¡¡ìC not like remaining diagnostic tools always standard diagnostic session 0x89. Function is under CAN-TP2.0.
    Broadcast diagnostic request, disable normal communication, clear DTCs, Logistic (transport) mode, xxxxx Functions are under CAN-TP2.0.
    Allows managing of brand new units (and immobilizer units) where is allowed programming of PIN, SKC, BGW, MAC. Functions are under CAN-TP2.0.
    Most of popular diagnostic requests, identifications, coding, adaptations, DTCs and xxxxx Functions are under CAN-TP2.0.
    Special functions
    Odometer correction in instrument clusters and EDC15x.
    Read Security Access Code/Login WFS.
    Read/program immobilizer data.
    Read/write EEPROM from instrument cluster/immobilizer. All supported clusters CAN/K.
    VAG MMI TV Activation.
    Read/Write EEPROM of Engine Control Units BOSCH VAG-EDC15x, VAG-ME7.1.1, VAG-Cartronic ME7.8, Porsche.
    Key learning buttons for easy usage (not needed security code). Can do component security authorization.
    Key learning Porsche CAYENNE (not needed security code) K+CAN.
    Custom memory reading from different units like ECUs, EZS-Kessy and xxxxx.
    Reading flash memories EDC16x, EDC15x, ME7x, MED951, MED751 (with next update will be possible programming of flash memories
    Crash data clear in airbag units
    List of vehicles covered from function odometer change via OBDII
    Audi Q7 (CAN)
    Audi A2 (K)
    Audi A3 (CAN) up to 2007 !!!
    Audi A3 VDO/M73 up to 2003 (K)
    Audi A4 VDO/M73 (K)
    Audi A4 BOSCH - RB4 clusters (CRYPTO eeproms R/W by OBDII)
    Audi A6 VDO (K)
    Audi A6 (CAN)
    Audi Allroud (K) up to 2004
    Audi A8 (K) VDO93xx
    Audi A8 (CAN) up to 2007 !!!
    Audi TT (K)
    Seat Alhambra (K)
    Seat Altea (CAN)
    Seat Arosa (K)
    Seat Cordoba after 1999 (K)
    Seat Ibiza VDO after 1999 (K)
    Seat Leon (K+CAN)
    Seat Toledo (K+CAN)
    Skoda Octavia (K)
    Skoda Octavia II (CAN)
    Skoda Superb (K)
    Skoda Roomster (K)
    Skoda Scout (CAN)
    Skoda Fabia (K)
    VW Bora (K)
    VW Beetle (K)
    VW Caddy (CAN)
    VW EOS (CAN)
    VW Golf4 VDO/Motometer/BOSCH RB
    VW Golf5 VDO (CAN)
    VW Golf5 VISETEON
    VW Crossgolf (CAN)
    VW Individual (CAN)
    VW Jetta (K+CAN)
    VW Passat B5/B6 (K+CAN)
    VW Polo VDO/Motometer (K)
    VW Sharan (K)
    VW T4/T5 VDO (K)
    VW Touaran VDO (CAN)
    List of vehicles covered from function security access code/login reading via OBDII
    Audi A2
    Audi A4 VDO (K)
    Audi A4 BOSCH (K) up to 2001
    Audi A4 after 2000 - petrol engines >= 1.8
    Audi A6 VDO (K)
    Audi A6 (CAN) petrol engines
    Audi Allroad (K) up to 2004
    Audi Allroad (CAN) petrol engines
    Audi A8 up to 2001
    Audi A8 from 2001 to 2002 2.5TDI
    Audi A8 (CAN) 2003+ petrol
    Audi TT (K)
    Audi Q7 petrol engines
    Seat Altea (CAN)
    Seat Ibiza (VDO) after 1999 (K)
    Seat Leon (K+CAN)
    Seat Toledo (K+CAN)
    Skoda Octavia
    Skoda Superb
    Skoda Roomster
    Skoda Scout (CAN)
    Skoda Fabia
    VW Bora
    VW Beetle
    VW Caddy (CAN)
    VW EOS (CAN)
    VW Golf5 VDO (CAN)
    VW Crossgolf (CAN)
    VW Individual (CAN)
    VW Jetta (K+CAN)
    VW Passat B5 (K) B6(CAN)
    VW Polo5
    VW Sharan after year 2000
    VW T5
    VW Phaeton petrol
    VW Touareg petrol
    PORSCHE Cayenne (CAN/K)
    Current version 1.4 covers VW/SEAT/SKODA (CAN) up to September 2006 while AUDI covered up to 2007
    1 человеку нравится это.
  2. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    Ответ: Кто-нибудь работал с VAG K+CAN 1.4 Commander Diagnostic Tool?
    или, тупо взять такую коробочку?
    VW/AUDI/SEAT/SKODA Airbag/Service Reset Tool OBD2 VAG
    Пугает, что она полностью автоматическая...
  3. melkon
    melkon Суровый диагност
    21 сен 2005
    27.088
    Tuareg NF 3.0TDI на пневме.
    Думаю она будет интересней на более поздних моделях . А что по деньгам ? Она судя по всему и шить может через диагностическую колодку ?
  4. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    вот это то и интересно
    по деньгам - смотри репу
  5. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    Вот зараза!
    У меня AirBag Unit - 8A0 959 655 A, а в этих девайсах описаны 8A0 959 655 С. В итоге, краш-дата не ресетится... Хотя у обоих модулей один заменитель - Bosch 0 285 001 038
  6. melkon
    21 сен 2005
    27.088
    #6 melkon, 6 янв 2009
    Господа скручиватели/обнулители ! Дайте советов по сабжу .... Сегодня пытался с ним подружиться ,пока без результатов (верней пронесло пока тфу тфу) . Пытался соедениться с 01 адресом (двиг) - есть соеденение ,логин который она выудила не подходит (?) С приборкой 17 адрес вообще чума ,соединяешься ,жмешь "читать эбу" она конектится и.... вся приборка обнуляется ( сбрасывает показания компа,времени) внутри чего то шумит ...После этого по всем блокам имею ошибку 01794 (задолбался все переадаптировать после ) и еще букет ошибок во всех контроллерах по потери блока приборки ...Стремно что пипец ! Как оно должно работать то ?
    ЗЫ. Все манипуляции провожу на своей (родненькой) машине. Не ради обогащения . Подсказки можно в ПС (дабы не травмировть психики слабые)
  7. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    странно... у меня с приборкой соединилась без проблем. ты по к-линии?
  8. melkon
    21 сен 2005
    27.088
    Естественно .
  9. Woland[RU]
    Woland[RU] Живу я здесь
    7 апр 2008
    1.252
    В поисках аВоськи
    какой прогресс?
  10. melkon
    21 сен 2005
    27.088
    Вытянул логин из мотора и приборки (приборка после этого чуть не крякнула см вверху). И все . Больше эксперементов на себе не проводил.
  11. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    Сдается мне, что это обычный USB-KKL шнур... :(
  12. melkon
    21 сен 2005
    27.088
    Ну хз он с VAGcom не подружился и с другими прогами под ОБД II .
  13. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    понятно...
    Я просто своим ККЛ-ным кабелем пробовал пользовать программу CAN-Commander. Результат был очень похожим... Точно так же, подцепиться смог только к приборке. Делать ничего не стал, мне хватило того кабеля :D До сих пор, на одометре точка мигает... Теперь докажи, что я пробег не скручивал.... :rofl:
  14. Gorizont
    Gorizont Новичок
    12 июл 2008
    12
    a4
    #14 Gorizont, 23 фев 2009
    У меня шнурок VAG-HEX-CAN, я скачал VAG COMMANDER 5.0, дружить со шнурком не хочет, может VAG COMMANDER 5.0 и VAG K+CAN 1.4 Commander Diagnostic Tool это разные вещи?
    Подскажите если не трудно, где можно скачать VAG K+CAN 1.4 Commander Diagnostic Tool или если есть у кого поделитесь, я бы с удовольствием протестил и отписался.
  15. melkon
    21 сен 2005
    27.088
    У нее свой шнур в комплекте.
  16. Браза Далли
    Браза Далли Живу я здесь
    13 авг 2005
    4.730
    Купил 5.1 betta китайскую, для интереса. Пробовал на последних Jett_е, Passat_е, А4: даже не законнектилось :)
    Кинул в ящик, больше не так и не подходил. С более старыми не пробовал есче.
    Я думаю все осознают, что заманчивую цену имеет есс-но г.. китайская подделка, а спецификации приклеины от оригинального устройства? :rotate:
  17. eeciv
    eeciv Завсегдатай
    22 мар 2007
    841
    Q5
    vag k+can 1.4 - работает все что заявлено, но надо уметь пользоваться! знать и понимать что ты делаешь! за 80$ зачетный девайс. Чем больше людей далеких от этого купит его, тем больше будет у меня работы :)
  18. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    С подушками не работает! :nod: (с моим блоком)
    Собссно, ради этого и хотел его взять
  19. eeciv
    eeciv Завсегдатай
    22 мар 2007
    841
    Q5
    я тебе уже подробно говорил - твой блок можно пальцами на коленях восстановить - только надо иметь знания и опыт, а тебе 1500р жалко :)
  20. olll
    olll Особый статус
    4 июл 2007
    5.344
    Rav4x4, ГЧ crdi
    ни разу не жалко.
    не-ка-да!:nod:
    сейчас из подольска в Зеленоград на работу мотаюсь и ниразу не по пути
