Покупка USB Cable KKL 409.1 VAG COM (и прочей ерунды) на Аукционе eBay
Тема в разделе "Мультимедиа и автозвук", создана пользователем СерGunЧик, 24 авг 2010.
  1. СерGunЧик
    СерGunЧик Участник форума
    26 мар 2008
    240
    Audi 100/44 WC 84г.
    #1 СерGunЧик, 24 авг 2010
    Выкладываю по просьбам:
    VAG1.jpg Стоит это чудо 9,99$ с доставкой vvv.jpg а это стоит 4$ с доставкой
    USB Cable KKL 409.1 VW/AUDI OBD2 OBD OBDII VAG COM
    http://cgi.ebay.com/ebaymotors/ws/e...0429099904&viewitem=&sspagename=STRK:MEWAX:IT
    This VAG_COM OBD II interface enables you to connect your PC to your car so that you can troubleshoot any problems in your vehicle by reading the Diagnostic Trouble Codes (DTC’s) that appear when the ‘check engine’ light is showing.
    Workable Models
    This diagnostic cable is usable for ISO9141 and KWP2000 transmission protocol (16pin OBD II style Data Link Connector).
    Reference Data
    This cable can not work if your car uses a protocol/bussystem like VPW, PWM or CAN-bus.
    Terminal K = Bus of communication
    Terminal L = Ignition for waking up car computing system (ECU: Engine Control Unit)
    Existed 3 different protocols with same OBD2 connector incl. ISO/KWP, VPW, PMW
    This K/L Diagnostic interface & cables work on ISO/KWP (Key Word Protocol) launched after 1996 only.
    Supported also ISO9141 protocol
    The Cables may work with some versions of the Carsoft, but carsoft used a lot of different interfaces during the different versions and also had some custom interfaces.
    Features
    Supports VAG-COM version 409.1 or older
    Fully automatic support for 2002+ Audi models with dual K-lines
    High quality precision moulded diagnostic connector made to fit all Audi/VW vehicles
    LED light shows cable communication status
    Fully CE approved
    In-built electronic protection from ‘aftermarket radio problems’
    This purchase is for one 145cm long, 16 pin OBD diagnostic socket to RS232 9 pin interface cable with USB connector
    About VAG-COM
    VAG-COM is a Windows based diagnostic software for Volkswagen, Audi, Seat and Skoda vehicles that emulates the functions of expensive professional scan tools. It is:
    Fully compatible with all models of the above makes of car or van produced between 1996 and 2006 (see below for more information on earlier models)
    Compatible with the above makes of car with CAN connection
    Has a data base of more than 7500 fault codes and measuring block texts
    Can use the new 7 digit PIN/SKC codes to match new keys in all immobilizer-equipped W, Audi, Seat and Skoda models
    Is my Car VAG-COM Compatible?
    VAG-COM will work with most Volkswagen and Audi models sold worldwide from 1994 onwards. It will also work with most late-model SEAT and Skodas sold outside of N. America.See below for full list. It does not work with diesel engines.
    If your VW or Audi has a 16pin OBD II style Data Link Connector then VAG-COM will work. If your car has the old 2x2 Data Link Connection check to see if there is a wire going to each pin - if there are 4 wires VAG-COM should work – if there are only 3 it won’t.
    VAG software:
    Versions: 3xx, 4xx, (THIS CABLE NOT SUPPORT CAN-BUS )
    ShadeTree Software ProDiag 1.0x (for PalmOS) Serial Cable
    Palm III, Palm V/Vx, Palm VII, HandSpring Visor Series, HandEra TRG, SONY
    PDA to Serial converter cables available
    VAG Diagnose (for DOS)
    Supports powerful Direct Memory Access (DMA) which allows users to modify RAM/EEPROM/SEEPROM directly through the cable without ever touching the controller cover
    REVO Lemmiwinks ECU Tuning
    APR Immobilizer Information Reader
    ECU Tuning Applications (please consult the vendors)
    Other VW diagnose/tuning software
    Итак, поехали!
    1. Регистрируемся на ebay.com
    файл с пошаговыми инструкциями тут: http://rapidshare.com/files/142692365/ebay-reg.pdf
    2. Регистрируемся на paypal.com
    файы с пошаговыми инструкциями тут:
    http://rapidshare.com/files/141447024/paypal-reg.pdf
    http://rapidshare.com/files/163252520/pp_verification.pdf
    3. Банковские карты:
    Скажу сразу, Visa Electron и Maestro не пройдут. Рекомендую завести карту Master Card Virtual от Промсвязьбанка (psbank.ru) Это лучшее решение.
  2. Ruha
    Ruha Участник форума
    24 янв 2010
    227
    AUDI a6
    #2 Ruha, 6 сен 2010
    Хочу купить. Где взять оба кабеля?
  3. Ruha
    24 янв 2010
    227
    AUDI a6
    Не дружу с английским.
  4. dot1q
    dot1q Участник форума
    22 авг 2010
    138
    RS
    именно по этой ссылке, не шипят в Рашку ! :ded:
    This seller does not ship to Russian Federation.
  5. СерGunЧик
    26 мар 2008
    240
    Audi 100/44 WC 84г.
    Я договорился с продавцом и он все выслал.
  6. Mark_Norman
    Mark_Norman Участник форума
    5 дек 2010
    402
    Audi S6
    1 человеку нравится это.
  7. Nemudroff
    Nemudroff Участник форума
    23 май 2010
    339
    no car
    а можете тыкнуть конкретно, какой будет нормально работать из USB шнурков? и так чтобы была возможность ковыряться в настройках
  8. Mark_Norman
    5 дек 2010
    402
    Audi S6
    те, что скинул автор и я конкретно с твоим авто работать будут
  9. BlackBaller
    BlackBaller Живу я здесь
    12 сен 2010
    1.728
    Тюменская обл.
    На счет карточки! Сейчас можно легко оформить карточку в любом магазине "связной", ну или на крайний случай "евросеть". Бесплатное формление за 10 минут, и мобильный банк есть )) Удобно для "палки"
  10. Nemudroff
    23 май 2010
    339
    no car
    я вот заказал такой шнурок USB Cable KKL 409.1, скоро прийдет.
    вопрос теперь в другом, с каким софтом его использовать?
  11. vanoM939
    vanoM939 Живу я здесь
    25 сен 2007
    2.691
    Рисовозка
    На диске будет VagCom 409, либо качай VagCom311 русский.
  12. Грек
    Грек Bad e-mail
    7 май 2009
    50
    Audi a6/c5 2.8 00г.
  13. teplopro
    teplopro Участник форума
    14 фев 2011
    479
    A6 Avant '96 2.5TDi (AEL)
    подскажите, какой k-line кабель лучше выбрать? тот, что с USB подключением или через COMпорт? одинаковы ли у них функциональные возможности? у меня в копьютере есть оба порта, операционка - виндовс ХР (сп3). подскажите кто знает!!!
  14. mikle_s
    mikle_s Новичок
    11 авг 2011
    1
    Подскажите, кто знает: такой кабель работает с Mac OS или только с Виндой?
  15. bais
    bais Живу я здесь
    28 июн 2006
    1.472
    Audi A6C5 2.4Q 02г
    Покупал такой шнурок на ebay. Работает. Но учтите, в комплекте софт без кряка(функционал ограничен, но почитать и потереть ошибки можно). Мне интересно 311 VAG COM с ним будет работать? И для моей машины хватит 311 или нет. Попробовать пока времени не было. Насчет яблока незнаю, помоему не будет, диск в машине лежит посмотреть не могу, но скорее всего нет.
  16. Elchin
    Elchin Участник форума
    16 апр 2011
    418
    A6/C5 2.5TDI 2000
  17. Zerg()()()()
    13 фев 2011
    11.083
    Ауди
  18. Elchin
    16 апр 2011
    418
    A6/C5 2.5TDI 2000
  19. Zerg()()()()
    13 фев 2011
    11.083
    Ауди
    нафига? там ничего хорошего нету и рграничения без регистрации .я снес его и пользовался 311.2
  20. Roman -rus
    Roman -rus Участник форума
    31 авг 2011
    180
    A6 2.5tdi Avant
