ну так свяжись с автором ролика... в коментах он правда пишет, что не готов делать такое на продажу...
на пассат-б5 клубе было нечто похожее, http://passat-b5.ru/showthread.php?t=154448 на не цветной приборке
на В6 и В7 это не канает, другой протокол. есть нечто подобное из Польши, но связаться с автором также не вышло https://www.youtube.com/watch?v=-jSwfiJEigA по сабжу автор пишет: Sorry guys, but now this is a one-time tuning project. Maybe in the nearest future I will consider the possibility of retail sales. так что всё может быть
Hello, The VFIZ prefers color display but can work also on red, anyway on color looks ten times better due high resolution and multicolor, it needs Multi Function Steering Wheel to work (MFSW). Installation is easy, there is only need to insert plugs and need to make change of adaptation channel of tachometer once (to enable telematic support in tachometer, because of this VFIZ can't cooperate if telematic is installed in car, but this is rather not used). In future I can make to work without MFSW or cooperate with telematic but this is rare request thus have low priority. The VFIZ integrates seamlessly with existing car infotainment so you don't lost normal operation of Navi or MFSW or Bluetooth module. Normal cost of VFIZ is 220 euro with 24 months warranty and free updates, Currently this version has practically all software features, like Open Ceremony (Needle sweep), custom user defined measures sets (with parameters chosen from almost hundred car parameters, e.g. Boost, Oil temp, EGT, DPF, and many more), graphing chosen car parameter, displaying standard Measures Value Blocks, DTCs reading and clearing, also with DTC descriptions performance measurement like different accelerations time, lap timer, user configured Alarms (visible and audible alarm when some parameters limits are exceeded, EGT, oil temperature, boost...) If you need support for extra external sensors then it can be also build in Extended configuration, which have support external sensors (e.g. EGT, wideband AFR modules, external relay, Oil Pressure). It can also have more performance and data memory (to be used for future extra functions and data tables). Most powerful version price is 300euro. There is also extra bonus then, 48 months warranty and updates. I can also made some custom / intermediate configuration, combination of features and prices on request. Insured shipping cost by parcel service is generally about 20-30euro to Europe, North America 50 euro, South America about 70euro. Due fact that it can be significant cost abroad Europe it is possible to send it by national post service as priority/express shipment,which can be insured to most of countries, e.g. then cost would be around 30euro to both Americas and they usually arrive in 7-14days. Can you provide more details about car in which you what to use it, do you have Navi/RNS-E, MFSW, Color(white) or Red only FIS ? When you will decide I will ask you for you ECU part no, this is not necessary just helps to check is your engine profile is pre-configured in the VFIZ during start. What kind of experienced do you have in modding your car ? PS: Module can do Needle Sweep on startup (so called open ceremony), there is known only one car model for which currently this doesn't works, this is A4 B6 2.5 V6 TDI (tested years 2001, 2003). warm regards Mariusz
Если я правильно перевел, то 220 евро +доставка !! Сообщение от SeRiLLo Посмотреть сообщение Здравствуйте, В VFIZ предпочитает цветной дисплей, но могут работать также на красном, во всяком случае, цвет выглядит в десять раз лучше, благодаря высоким разрешением и многоцветный, он должен многофункциональный Руль работать (MFSW). Установка очень проста, только нужно вставить пробки и нужно вносить изменения, адаптации канала тахометра один раз (чтобы включить телематических поддержки в тахометр, из-за этого VFIZ не можем сотрудничать, если телематических устанавливается в автомобиле, но это скорее не используется). В будущем я могу сделать, чтобы работать без MFSW или сотрудничать с телематических но это редко, таким образом, имеют низкий приоритет. В VFIZ легко интегрируется с существующей автомобильных информационно-развлекательных систем, поэтому вам не потерял нормальное функционирование Navi или MFSW или модуль Bluetooth. Нормальная стоимость VFIZ составляет 220 евро с гарантией на 24 месяца и бесплатные обновления, В настоящее время эта версия имеет практически все функции программного обеспечения, как Церемония Открытия (Иглы sweep), настраиваемые пользователем устанавливает меры (с параметрами, выбранными из почти ста параметры автомобиля, например. Boost, температура Масла, EGT, DPF, и многое другое), построение графиков выбранный автомобиль параметров, отображения стандартных Мер величин, чтение и стирание Кодов неисправностей, а также с DTC описания измерения производительности, таких как различные время ускорений, lap-timer, настраиваемый пользователем Сигналы (видимый и слышимый сигнал, когда некоторые параметры будут превышены лимиты, EGT, температура масла, повышение...) Если вам нужна поддержка для дополнительных внешних датчиков, то она также может быть построен в Расширенной конфигурации, которые имеют поддержку внешних датчиков (например. EGT, широкополосные AFR модулей, внешнее реле Давления Масла). Она также может иметь большую производительность и память данных (в дальнейшем будете использовать для дополнительных функций и данных таблицы). Наиболее мощная версия цена 300euro. Существует также дополнительный бонус затем, 48 месяцев гарантии и обновления. Я также сделал некоторые пользовательские / промежуточные конфигурации, сочетание возможностей и цены по запросу. Застрахованного стоимость доставки курьерской службы, как правило, около 20-30euro в Европе, Северной Америке 50 евро, Южной Америке около 70 евро. Из-за того, что она может быть значительные затраты за рубежом Европы, то можно отправить его по национальной почтовой службы в качестве приоритета/Экспресс-доставки,которая может быть застраховано в большинстве стран, например. в то время стоил бы около 30euro для обеих Америк и они обычно приходят в 7-14дней. Можете ли вы предоставить более подробную информацию о машине, в которой вы, что использовать это, у вас есть Navi/RNS-E, MFSW, Цвет(белый) или только Красный FIS ? Когда вы решите, я попрошу вас за ECU нет, в этом нет необходимости, просто помогает проверить ваш двигатель профиль настроен в VFIZ во время пуска. Какие опытных вы имеете в моддинг вашего автомобиля ? PS: Модуль может работать Иглой Развертки on startup (так называемые открытые церемонии), известен только одной модели автомобиля, для которого в настоящее время это не работает, это является A4 (B6 2.5 V6 TDI (проверено годами 2001, 2003). с сердечным приветом Мариуш
