народ помогите не работает ABC A8 99 год VAG COM пишет ошибка 1044 модуль управления неправельно закодирован машина простояла пол года и после этого такая проблема блок абс меняли тоже самое
Ответ: A8 ABC ошибка 1044 <TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD vAlign=top>так надо блок закодировать! если непонятно,спрашивайте,обьясню Basic setting Encode control unit Control unit -J104 (no. 4D0 407 389 B/C/D/E) must be fitted in vehicles built from January 1999. These control units can be encoded. New control units from the parts system are not coded and must be coded after installation. Control units with no. 4D0 907 389 (no index) cannot be encoded. Encoding of ESP control unit is designed to adapt the control unit to the vehicle. Coding is only possible after the workshop code (WSC) has been entered into V.A.G 1551. Encoding can only be performed if function 11 "Login procedure" has been successfully implemented beforehand using fault reader V.A.G 1551/1552 => Page 01-464. After the control unit has been encoded, zero position compensation must be carried out for steering angle sender -G85 without leaving the diagnostic mode. Function 04 "Initiate basic setting", Display group 01 => Page 01-398. Note: If control unit has been encoded with code 00000 or with a code not appropriate to the vehicle the ABS warning lamp (K47) and the TCS/ESP warning lamp (K155) will light continuously and the fault 01044- Control unit incorrectly coded - will be stored in the fault memory of the control unit. Test sequence <LI class=nonenone>[size=-1]‒ [/size]Establish engine version. <LI class=nonenone>[size=-1]‒ [/size]Establish gearbox version. [size=-1]‒ [/size]Connect up vehicle diagnostic, testing and information system VAS 5051/fault reader V.A.G 1551 and select "Brake electronics" with address word 03 => Page 01-5. </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ Indicated on display:</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>Rapid data transfer HELP</TD></TR><TR><TD>Select function XX</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Press 1 twice to select the function "Login procedure". </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ Indicated on display:</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>Rapid data transfer Q</TD></TR><TR><TD>11 - Login procedure</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Confirm input with Q key. </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ Indicated on display:</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>Login procedure Q</TD></TR><TR><TD>Enter code number XXXXX</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Enter code number as per following table and confirm with Q key. Login code table <TABLE style="BORDER-COLLAPSE: collapse" cellSpacing=0><COLGROUP span=3><COL width="36%"><COL width="38%"><COL width="25%"></COLGROUP><TBODY><TR><TH><TR><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=left>Type of engine </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Gearbox version </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Login code </TD></TR></TH><TR><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid" align=left>6, 8-or 12 cylinder </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Manual gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>05495 </TD></TR><TR><TD style="PADDING-RIGHT: 1ex; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=left>petrol engine </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Automatic gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>05497 </TD></TR><TR><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid" align=left>6 or 8-cylinder diesel engine </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Manual gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>05455 </TD></TR><TR><TD style="PADDING-RIGHT: 1ex; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=left> </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Automatic gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>05457 </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ Indicated on display:</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>Rapid data transfer HELP</TD></TR><TR><TD>Select function XX</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Enter 07 for function "Erase fault memory" and confirm with Q. </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ Indicated on display:</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>Rapid data transfer Q</TD></TR><TR><TD>07 - Code control unit</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Confirm entry with Q key. </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ Indicated on display:</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>Encode control unit</TD></TR><TR><TD>Enter code number XXXXX (0-32767)</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Enter code number as per following table and confirm with Q key. Coding table <TABLE style="BORDER-COLLAPSE: collapse" cellSpacing=0><COLGROUP span=3><COL width="36%"><COL width="38%"><COL width="25%"></COLGROUP><TBODY><TR><TH><TR><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=left>Type of engine </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Gearbox version </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Coding </TD></TR></TH><TR><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid" align=left>6, 8-or 12 cylinder </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Manual gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>08395 </TD></TR><TR><TD style="PADDING-RIGHT: 1ex; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=left>petrol engine </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Automatic gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>08397 </TD></TR><TR><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid" align=left>6-or 8 cylinder diesel engine </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Manual gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>08355 </TD></TR><TR><TD style="PADDING-RIGHT: 1ex; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=left> </TD><TD style="PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>Automatic gearbox </TD><TD style="BORDER-RIGHT: black thin solid; PADDING-RIGHT: 1ex; BORDER-TOP: black thin solid; PADDING-LEFT: 1ex; BORDER-LEFT: black thin solid; BORDER-BOTTOM: black thin solid" align=middle>08357 </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ The display on fault reader V.A.G 1551 will show the control unit identification code e.g.: 4D0 907 379B ABS/ESP front.</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>4D0 907 379B ABS/ESP front D05 ⇒</TD></TR><TR><TD>Coding 08395 WSC XXXXX</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Press⇒ key. </TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD collspan="2"> </TD></TR><TR><TD vAlign=top align=left>→ Indicated on display:</TD><TD style="PADDING-LEFT: 20px" vAlign=top align=left><TABLE class=displ width="100%" border=0><TBODY><TR><TD>Rapid data transfer HELP</TD></TR><TR><TD>Select function XX</TD></TR></TBODY></TABLE> </TD></TR><TR><TD vAlign=top> [size=-1]‒ [/size]Enter 04 to "Initiate basic setting" and confirm with Q to perform zero position compensation on steering angle sender -G85, Display group 01 => Page 01-398. Note: If control unit has been encoded with code 00000 or with a code not appropriate to the vehicle, then the ABS warning lamp (K47) and the TCS/ESP warning lamp (K155) will light continuously and the fault 01044- Control unit incorrectly coded - will be stored in the fault memory of the control unit. </TD></TR></TBODY></TABLE>
Ответ: A8 ABC ошибка 1044 Помогите шибка Airbag 1044 Машина Audi A8 97 год. Ошибка 1044 Кодировка модуля управления не соответствует конфигурации модели автомобиля. Причём чел говорит что до замены салона этой ошибки не было, но горела лампа из-за неисправного мата присутствия водителя.
Ответ: A8 ABC ошибка 1044 Правильно ли я понял что эта ошибка может возникнуть в двух случаях либо установлен новый блок либо старый потерял установки по причине к примеру долгого простаивания. И можно ли самому перекодировать его, имя VAG
