AUK что за ошибки? А ведь это новый мотор!
Тема в разделе "4F C6", создана пользователем kulikovd, 25 ноя 2012.
  1. kulikovd
    kulikovd Завсегдатай
    29 мар 2010
    665
    Поменял в общем я мотор,скинул ошибки. Читаемс:
    Address 01: Engine (AUK) Labels: None
    Part No SW: 4F0 910 115 HW: 4F0 907 115
    Component: 3.2l V6 FSI G 0040
    Revision: --H14--- Serial number:
    Coding: 01050003190F0120
    Shop #: WSC 02325 785 00200
    5 Faults Found:
    17044 - Intake Manifold Tuning Valve Control Circuit (Bank 1): Elect. Malfunction
    P0660 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 234
    Mileage: 150620 km
    Time Indication: 0
    Date: 2005.02.02
    Time: 20:30:55
    Freeze Frame:
    RPM: 640 /min
    Mass Air / Rev.: 130.8 mg/str
    Temperature: 108.0°C
    Idle
    Voltage: 13.57 V
    Speed: 0.0 km/h
    16397 - Bank 1: Camshaft B (Exhaust): Position Actuator Malfunction
    P0013 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00001000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 150637 km
    Time Indication: 0
    Date: 2012.11.23
    Time: 23:14:04
    Freeze Frame:
    RPM: 1024 /min
    Mass Air / Rev.: 190.8 mg/str
    Temperature: 102.0°C
    Part Throttle
    Voltage: 1.12 V
    Speed: 10.0 km/h
    16750 - Camshaft Position Sensor B Bank 1 (G300): Implausible Signal
    P0366 - 000 - - - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 4
    Fault Frequency: 4
    Reset counter: 236
    Mileage: 150637 km
    Time Indication: 0
    Date: 2012.11.23
    Time: 23:15:49
    Freeze Frame:
    RPM: 0 /min
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 106.5°C
    Engine Off
    Bin. Bits: 00001000
    Speed: 0.0 km/h
    18972 - Low Pressure Fuel Sensor (G410): Implausible Signal
    P2540 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 236
    Mileage: 150637 km
    Time Indication: 0
    Date: 2012.11.23
    Time: 23:14:04
    Freeze Frame:
    RPM: 1024 /min
    Part Throttle
    Temperature: -40.5°C
    Speed: 10.0 km/h
    18971 - Low Pressure Fuel Sensor (G410): Open Circuit
    P2539 - 000 - -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 7
    Reset counter: 236
    Mileage: 150637 km
    Time Indication: 0
    Date: 2012.11.23
    Time: 23:15:49
    Freeze Frame:
    RPM: 0 /min
    Engine Off
    Load: 3.1 %
    Speed: 0.0 km/h
    это что еще такое?
  2. kulikovd
    29 мар 2010
    665
    Кстати, снимали блок комфорта на америкоса ставили. Надеюсь это не связано, но все равно решил написать)
  3. Chunakovv
    Chunakovv Живу я здесь
    6 апр 2012
    2.607
    Саратовская обл.
    А6/C7 3.0 TDI
    Блок комфорта с двигателем совсем не связан. Я думаю, это "качество" сборки.
  4. kulikovd
    29 мар 2010
    665
    я тоже так думаю) и вообще смотрел по эльзе...все датчики от одного плюса питаются... то есть там херня наверное...но решил убедиться)))
    надо же на тебя все свалить хоть как то)))
