Дисплей показывает "ESP FAULT! SEE OWNER,S MANUAL" на 3.0 TDI
Тема в разделе "4F C6", создана пользователем Robert_, 11 апр 2012.
  1. Robert_
    Robert_ Bad e-mail
    29 фев 2012
    43
    A6/C6 3.0TDI Q 04г
    Начала вискакивать ошибка Дисплей показывает "ESP FAULT! SEE OWNER,S MANUAL" и горит значек ESP.
    Диагностика покизывает:
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Control Module Part Number: 8E0 614 517
    Component and/or Version: ABS/ESP front D1320
    Software Coding: 04279
    Work Shop Code: WSC 00180
    VCID: E5C507727F7A66C
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    Wednesday,08,February,2012,14:50:10:62986
    VCDS Version: Release 11.11.1
    Data version: 20111209
    5
    Также есть ошибки по двигателю:
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 4F0 910 401 F HW: 4F0 907 401 A
    Component and/or Version: 3.0L V6TDI 0000AG 0030
    Software Coding: 0011772
    Work Shop Code: WSC 30467 264 56988
    VCID: 1F49D59ACEA6FCC
    5 Faults Found:
    29703 - Please check Fault Memory in Battery Monitoring Module
    U1007 - 001 -
    Freeze Frame:
    RPM: 1449 /min
    Torque: 249.6 Nm
    Speed: 63.8 km/h
    (no units): 1045.5
    Voltage: 13.98 V
    Temperature: 13.5°C
    (no units): 4.0
    Torque: 292.5 Nm
    16785 - EGR System
    P0401 - 001 - Insufficient Flow - Intermittent
    Freeze Frame:
    RPM: 1701 /min
    Torque: 124.8 Nm
    Speed: 57.1 km/h
    Duty Cycle: 56.8 %
    Duty Cycle: 20.9 %
    Mass Air / Rev.: 470.0 mg/str
    Duty Cycle: 39.5 %
    Mass Air / Rev.: 299.6 mg/str
    17471 - Fuel Pressure Regulation
    P1063 - 003 - Control Range Not Reached - Intermittent
    Freeze Frame:
    RPM: 756 /min
    Torque: 78.0 Nm
    Speed: 4.5 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.63 V
    Pressure: 99.4 bar
    Duty Cycle: 24.9 %
    Temperature: 44.1°C
    17426 - Intake Manifold Runner (Bank 2)
    P1018 - 001 - Lower limit not reached
    Freeze Frame:
    RPM: 756 /min
    Torque: 50.7 Nm
    Speed: 0.0 km/h
    Voltage: 11.78 V
    Duty Cycle: 80.9 %
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    Temperature: 83.7°C
    16488 - Mass Air Flow Sensor (G70)
    P0104 - 001 - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 167.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 80.9 %
    Voltage: 11.93 V
    Absolute Pres.: 979.2 mbar
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 25.2°C
  2. Robert_
    Robert_ Bad e-mail
    29 фев 2012
    43
    A6/C6 3.0TDI Q 04г
    Никто, ничего не подскажет?
  3. Front
    Front Участник форума
    7 дек 2011
    340
    ауди продал
    #3 Front, 13 июл 2013
    Всем удачи
  4. igor33
    igor33 Заблокирован
    19 июн 2010
    19.979
    А6/С6 3.0i Q 05
    Ты ещё здесь, всё не угомонишься, воюешь с концерном...
    Или после типа финика опять аудю прикупил? :lol:
  5. Front
    7 дек 2011
    340
    ауди продал
    #5 Front, 14 июл 2013
    Я не воюю...
    Я, в отличии от тебя, добился бесплатной замены 7 летнего бракованного двигателя ауди.
    У меня все ОК!
    Ауди можно купить только новый!
    Покупая б/у, покупаешь гавно!
    Не будьте дураками, не покупайте этот хлам.
  6. jforeman
    jforeman Новичок
    10 апр 2013
    52
    A6/C6 3.2q 08г
    ESP - однозначно от мотора заглючила!
    На А6 ESP - не только тормозит, но и двигателем курс пытается скоректировать.
    Убирать ошибки пробовал - привкл. зажигании, но без завода двиг. тоже выскакивает?
  7. jforeman
    jforeman Новичок
    10 апр 2013
    52
    A6/C6 3.2q 08г
    Заметь - все ошибки двигателя в разное время!!!
    удали - попробуй ещё раз!
    По ESP 1я ошибка походу датчик в подшипнике.
  8. 0500
    0500 ____________
    17 июл 2011
    1.932
    № 11
    Авто: А6 3,2 Q, 6МКПП
    Пепел Клааса еще стучит?
    И как понимать
    в профиле :help:
  9. Front
    7 дек 2011
    340
    ауди продал
    Кому вопрос?
    Не нужно тупить, 6 ст. механика с дв.аук 3,2 кватро, что не понятно?
  10. igor33
    igor33 Заблокирован
    19 июн 2010
    19.979
    А6/С6 3.0i Q 05
    #10 igor33, 15 июл 2013
    Front, так тебе ж концерн собирался машину новую подогнать, обломались в последний момент что-ли?
    Обидно...
  11. ikonstantinov
    ikonstantinov Завсегдатай
    7 фев 2013
    925
    Нет
  12. 0500
    0500 ____________
    17 июл 2011
    1.932
    № 11
    Это вернулась та, которую обменяли на новую?
  13. ikonstantinov
    7 фев 2013
    925
    Нет
    Та была на автомате. Вот 3.2 на МКПП очень большая редкость :umnik:
  14. mudrec
    mudrec Живу я здесь
    26 дек 2006
    4.188
    Нижегородская обл.
    А8 D3
    Вы че там придумываете? Датчик поворота руля с колесным спутали? )))
