A8 D4 Индикатор номера передачи VCDS
Тема в разделе "A8", создана пользователем himoslav, 21 сен 2021.
  1. himoslav
    himoslav Новичок
    5 окт 2019
    24
    Украина
    Как через VCDS сделать что бы отображался номер передачи возле D или S?
    Пробовал данную кодировку, не сработало.
    Upshift Display
    [17 – Instruments]
    [Adaption - 10] -> Upshift Display in center panel ->
    Use dropdown to activate/deactivate
    Параметр дает изменить но номер передачи не появляется. AUDI A8 D4 3.0 tdi 2013
  2. roadall
    roadall Заблокирован
    23 май 2011
    1.245
    A8 4.0 biturbo
    Disable After-wipe of windscreen wipers
    [09 – Cent. Elect.] [Coding - 07] ->Long Coding Helper -> Byte 1
    Bit 3 - Remove check mark (1 = active)
    ________________________________________
    Disable amber corner lights
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    Disable Key warning
    [46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 7 set to 0 (Uncheck)
    Disable "Lights are on" Warning
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
    Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
    Disable NAV & Phone warning messages while entering data at speed
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    Disable Seatbelt Chime
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning inactive
    Adjust Date display
    [17 – Instruments]
    [Coding - 07] -> Long Code Helper ->
    Byte 7 – Use dropdown to select date format
    Upshift Display
    [17 – Instruments]
    Enable Adaptive brake lights
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    __________________________________________
    Enable Double Disarm Beep
    [46 - Central Conv.] [Adaptation - 10] -> Channel 63
    Add 4
    Enable/Disable Auto Locking
    Byte 5 – 0=off/1=on
    Bit 4 – Auto lock
    Bit 5 – Auto Unlock
    Enable DRL (Daytime Running Lights) to include the following:
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
    Bit 1 = DRL with Front Side markers
    Bit 2 = DRL with High Beams
    Bit 3 = DRL with Fog lights
    Bit 4 = DRL with LEDs
    Bit 6 = DRL with Side markers
    Bit 7 = DRL with Tail lights
    Enable Euro parking lights that turn on signal at night
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 0 - Set to 1
    Enable fog lamp to come on for the same side as that turn signal
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 0 - Check the box or change :Bit 0 set to 1
    Enable Front Turn Signals as Parking lights
    Bit 0- Check the box or change :Bit 0 to 1
    Enable Gauge Test/Needle Sweep
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
    Enable Hidden menu in MMI
    change 0 to 1
    Use this hidden menu at your own risk.
    Caution: Keep away from the "Bootloader", if it appears as an option
    Enable Import CDs to MMI's HD
    [Hidden menu]
    Main/Diagnose/Settings
    Import Media
    Set to 4 of 4 "Copy/Ripping"
    Note: CD must be inserted in player below the mmi, not the changer in the glovebox to be able to rip it.
    Enable Independent Fogs control with high beams (Fronts don't have separate fog light, only 'all weather mode.')
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    ________________________________________________
    Enable Release Parking Brake without putting foot on Brake
    [53 - Parking Brake][Security Access - 16] (Enter code presented by program)
    [Adaptation - 10] -> Channel 4 Set to 0
    Enable Release Parking Brake without putting seatbelt
    [Adaptation - 10] -> Channel 7 Set to 0
    Enable Reverse mirror tilt
    [52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
    Bit 4 and Bit 2 set to 1
    Enable VIM on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    Set ADS to specific preset Comfort, Auto, Dynamic or Individual
    [09 – Cent. Elect.][Security Access - 16](VCDS will have popup telling you the access code, mine was 20113)
    Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
    [Adaptation - 10] -> Channel 64
    [Adaptation - 10] -> Channel 65
    [Adaptation - 10] -> Channel 66
    *Note all four channels needs to be set to the same value. (Uncomfirmed)
    Set Headlight washer – Duration (values in milliseconds)
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 6
    change to e.g. 500
    Set Headlight washer – Activation Delay (values in milliseconds)
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 25
    change to e.g. 3000
    Set Headlight washer – Delay (How many times you can activate the regular washers without activating the headlight washers)
    [09 – Cent. Elect.]
    change to e.g. 6
    Set Coming Home Time– Duration
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 43
    change to e.g. 30
    Activate/Deactivate Leaving Home Function
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 46
    change to 0=off / 1=on
    Coming Home – Ambient Light Threshold for activation
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 37
    change from 0-7
    Enable/Disable Coming Home and Leaving Home Function
    [09 – Cent. Elect.]
    Byte 6 – 0=off/1=on
    Bit 1 – Coming Home
    Bit 2 – Leaving Home
    Enable/Disable Parking Lights
    [09 – Cent. Elect.]
    Byte 9 – 0=off/1=on
    Bit 0 – Parking Light Function
    Adjust DRL nighttime brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    Set between 5 and 100
    Adjust Seat Heat Stepdown Time
    [08 – HVAC]
    [Adaptation - 10] -> Time until heated seat power withdrawal stage 3 to stage 2 (or Time until heated seat power withdrawal stage 2 to stage 1)
    Set the number of minutes you would prefer and click 'Do It.'
    Adjust Massage Shut Off Time
    [88 – Driver's Seat] or [89 - Passenger's Seat]
    [Adaptation - 10] -> Running Time Of Massage Function
    Set the number of seconds you would prefer and click 'Do It.'
    Adjust Massage Intensity
    [Adaptation - 10] -> Intensity level (1,2,3,4, or 5) of massage function
    Set the intensity(0-100%) you would prefer and click 'Do It.'
    Adjust Heated Steering Wheel Temperature
    [16 – Steering Wheel]
    [Adaptation - 10] -> Channel-10
    Temperature is measured in Celcius, 28 is default
  3. himoslav
    himoslav Новичок
    5 окт 2019
    24
    Украина
    пробывал кодировку из списка, не помогло
  4. himoslav
    himoslav Новичок
    5 окт 2019
    24
    Украина
    [02 — Auto Trans]
    Адаптация — В строке ”Single Gear Display” выбрать значение ”D on/S on
  5. duduk
    duduk Новичок
    16 янв 2021
    11
    Украина
    может подскажите как это совершить с vag can pro?
