японская приблуда на аккумулятор
Тема в разделе "Тюнинг", создана пользователем dimo61, 21 авг 2006.
  1. dimo61
    dimo61 Живу я здесь
    14 фев 2006
    3.428
    Audi 100S4 2.2т "hand made"
    #1 dimo61, 21 авг 2006
    кто знает принцип действия или использовал такое устройство? http://lot.vladconcept.com/product_info.php?lot=r25453721&cPath=332_480_483
    3000 electrolytic capacitors.
    - EDLC system adoption *
    The American Department of Defense is centered with EDLC.
    It is a developed state-of-the-art accumulation of electricity element.
    The capacity of F130 + is 10 million��F how.
    It is a commodity sold by the fixed price 98000 yen as HP limitation goods in a few capacity differences in the other companies.
    "F130 + ...." of Rossam is very reasonable when thinking about it.
    It does by obtaining very much.
    - Efficient battery booster Debut *
    Battery exclusive use of 12V
    Principle of operation
    Because internal resistance is high, the speed at which this energy is taken out is limited though a lot of electricitys can be saved in the battery. This device supplies to the demand of the flannel of ..high power.. E ghee as necessary energy is high-speed, and will have the action where the electric power is saved oppositely at the standby in a short time in the battery. As a result, a preciser energy control became possible.
    Moreover, the electrical charge and discharge frequency has high durability of one million times and almost permanent durability. The synergy effect with a past battery makes a rapid electrical charge and discharge possible, and the I/O of the power supply energy becomes possible a speed of tens of times the battery. Moreover, the charge capacity decreases up to about 40% as the battery becomes old.
    The current to which the battery was accumulated when the demand current is insufficient is used though the electric power under running is basically covered by the power generation of the alternator. Therefore, the condition of the engine is controlled whether to keep the battery charge efficiency to be very high. Longevity and the performance of the main body of the battery can be greatly extended by depending on, improving the charge capacity of the battery up to 95% that is the limit, enabling a high-speed electrical charge and discharge, and keeping the power supply variation even in the effect of the float.
    Length of cable: Standard 50cm(An additional extension is received in charge. )
    Within 1.0m 1000 yen Within 1.5m 2000 yen Within 2.0m 3000 yen
    F130PLUS type: Fixed price 34500 yen
  2. 265KW
    265KW Живу я здесь
    25 окт 2005
    1.213
    с 265KW есть только одна.
    Ответ: японская приблуда на аккумулятор
    ГДЕ, дайте 2!!!!
    Мне мне надо....
    Я себе представил что такое 10 миллионов ФАРАД.
    Подключил такой на полчаса к Днепрогесу. Потом год без бензина можно ездить. :)
  3. 229
    229 Участник форума
    3 май 2004
    266
    Ауди 80/b4 2.6 94г. ABC
    это набор конденсаторов, для снижения колебания тока и всяких там потерь при заводе, т.е. впринципе ерунда.
  4. 265KW
    265KW Живу я здесь
    25 окт 2005
    1.213
    Аааа! Дайте 5!
    Я понял для чего это!
    taking and putting это сунуть и высунуть?
    come straight это становится прямо?
    кароче , заряжаеш от батереи. Потом подключаеш куда надо (под мошонку наверно)
    для ублажения многих (девушек) (And ....crowding). Для улучшения впячатлений (The following impression and S) все становится прямо для сувания и высувания (taking and putting), все это немножко момогает (and improves a little.) и касетво песни твоей души улучшается (and tone quality C of audio)
    Где где такие девайсы продают?
  5. 265KW
    265KW Живу я здесь
    25 окт 2005
    1.213
    Фильтр это высокочастотный. Ставить его на батарею не имеет смысла. В любом приличном приемнике такой стоит на входе питания.
    Для других челей приблуда нафиг не нужна. Но может помочь если подглючать дешевый китайский приемник к мопеду :)
  6. sim_a100_2.3_92
    sim_a100_2.3_92 Старожил
    6 дек 2003
    29.330
    ВАЗ 21083
    Reducing the fuel cost by improvement of combustor efficiency
    Torque improvement by whole area
    Power-up
    Brightness improvement of light
    Improvement of throttle response
    Long life of battery by load decrease
    Tone quality improvement on which voltage depends with stability
    Тааак, мощность с моментом увеличиваютя, расход топлива уменьшается, отклик на педаль газа улучшается, даже лампочки светят ярче. Последнего нет даже у вакуум колапсара. Как заказывать, я не понял. :shock:
