http://www.nihoncarandbike.com/index.php?page=galery&newsid=323&index=0 For those of you that are not aware what Toyota has cooked up for us, here are the main specs of this IS500: a V8 (2UR-FSE) engine that develops 420bhp (at 5800rpm) and 550Nm of torque (at 3800rpm), 5.0L displacement, overall dimensions of 4665x1820x1435mm with a 2730mm wheelbase and a total weight of 1685kg. -------------------------------------------------------------------------------- зы: порадовали жабры аля ххх
Ответ: Lexus IS500 Let's take the long-awaited Lexus IS500 as an example, the M and AMG killer from Japan. Press shots of this vehicle have been available since April 2006 in magazines like Car Top (in their April issue that has been on sale since March). Here's a scan of the page. For those of you that are not aware what Toyota has cooked up for us, here are the main specs of this IS500: a V8 (2UR-FSE) engine that develops 420bhp (at 5800rpm) and 550Nm of torque (at 3800rpm), 5.0L displacement, overall dimensions of 4665x1820x1435mm with a 2730mm wheelbase and a total weight of 1685kg. That IS going to hurt!
Ответ: Lexus IS500 эмка новая 4.4 V8 около 425 лыс http://www.autobild.de/aktuell/meldungen/artikel.php?artikel_id=11141
Ответ: Lexus IS500 интересно, а "горбик" на капоте это камуфляж или останется..? смотрится необычно, во всяком случае на бехах такого пока не видел и вообще последние бехи по дизайну меня не радуют. тяжёлый он какой-то.. и фары неприкольные хотя может заряженная будет получше смотреться.. обратите внимание на капот IS500.. какая то непонятная линия изгиба по диагонали слева направо .... или у меня глюки?
