народ поможите перевести на русский
Тема в разделе "Выбор Audi с пробегом", создана пользователем Zeus, 23 окт 2005.
  1. Zeus
    Zeus Живу я здесь
    20 мар 2005
    2.504
    Q7 4.2 TDI
    ввод моего vin показал такую штуку если у кого есть переводчик, подскажите что сие означает
    VIN: WAUZZZ4AZSN033565
    Sales type: 4A50M4 ()
    Дата выпуска: 15.09.1994
    Модельный год: 1995
    Код и номер двигателя: ABC 108630
    Код КПП: CVD
    Комбинация цветов интерьера: CK
    Комбинация цветов кузова: W9
    Roof color: W9
    Комплектация автомобиля (код и наименование):
    0DT installation differentiation for build status of vehicle class C (AUDI) unit components
    0EA installation differentiation for transmission B80 vehicle components
    0F2 fuel system for carburetor gasoline engine
    0G1 gearshift lever
    0LW special plates/stickers/safety certificates for Germany
    0MA without label for starting an automatic
    0SB labels/plates in German
    0TC front floor mats
    0VC information kit in German
    0W1 label for central electric German-speaking countries
    1AC anti-lock brake system (ABS)
    1BE sports suspension/shock absorption
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    1D0 without towing attachment
    1E1 activated carbon canister
    1EC special identification plate
    1G3 alloy spare wheel with original equipment tires
    1KD disc brakes, rear
    1LB disc brakes, front
    1N1 power steering
    1PC wheel bolts with anti-theft protection (unlockable)
    1T2 warning triangle
    1VH installation parts for six-cylinder engine
    1WD transmission shaft for tripod joints
    1X0 front wheel drive
    1YA without transmission shafts f. rear axle
    1Z0 initial standard fuel filling
    2A0 without delivery equipment
    2B0 without additional exterior noise suppression
    2CA without central hydraulic system
    2G1 insert for the filling up of unleaded fuel
    2K1 reinforced bumpers
    2L0 without lower fuel tank protection
    2PG steering wheel
    2TB radiator grille and bumper for hot regions
    2V1 dust and pollen filter
    2Z1 type sign at rear and "Quattro" nameplates respectively
    3B0 without additional child seat anchor
    3C3 lap belt with retractor for the center rear seat
    3CA without partition
    3FA without roof insert (standard roof)
    3GB cargo area with continuous cross panel
    3J1 height-adjustable headrests for front seats
    3L1 manual height adjustment for left front seat
    3N0 without stowage box in luggage boot
    3NC rear seat bench/backrest, split folding
    3Q5 rear headrests
    3S2 black roof rails
    3V0 without child bench seat
    3X0 without load-through provision
    3Y0 without roll-up sun screen
    3YB door pockets, front
    3ZB 3-point seat belts, outer rear with ECE label
    4A0 without seat heater
    4D0 without seat ventilation/massage seat
    4E0 tailgate/trunk lid unlocking from outside
    4F1 central locking system
    4GH windshield tinted with windshield sunshield
    4L2 dipping breakaway inside rear view mirror
    4M0 without cup holder
    4R2 power windows front, mechanical window regulators rear
    4SA without left vanity mirror
    4TB vanity mirror right
    4U1 luggage nets/pockets on backrests
    4UE airbag f. driver a. front seat passenger
    4W0 without cassette and CD storage unit
    4ZB bright moldings
    5C0 without special body measures
    5H3 tailgate lining for station wagon Avant
    5K1 paint preservative (wax)
    5MJ decorative inserts
    6C1 door window seal as molded part
    6D1 center armrest rear
    6E0 without center armrest front
    6EA without additional side body covers (stone guard)
    6FF body-colored outer rear view mirror housings and various add-on parts
    6G1 defroster nozzles for side windows snap shut
    6KG radiator grille
    6M0 without tie down straps/net/pocket
    6N0 without mud flaps
    6Q1 plastic gearshift knob/handle
    6R1 leatherette gearshift boot
    6RA dashboard and door trim panel one-piece, single color
    6T0 without interior light in foot area
    6TB outer right rear view mirror: convex, powered
    6UA outer left rear view mirror: flat, powered
    6V1 rear trim panel (ECE)
    6W5 front license plate bracket
    7A0 without CD changer/CD player
    7E0 w/o heat accumulator/auxiliary heating
    8AD radio "gamma"
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8F2 side turn signal lights
    8FA without second battery
    8G0 without antenna cable for radio system
    8GL alternator 120A
    8JH ellipsoidal headlight for driving on the right
    8K0 without special low beam mode
    8KA w/o catalytic converter warning light
    8L3 roof antenna
    8LB additional instruments (voltage, oil pressure and temperature)
    8NA without parking light warning light
    8Q1 headlight-range adjustment
    8R0 without center high-mounted stop light
    8RN eight speakers (active)
    8S0 without reading light
    8T0 without cruise control system (CCS)
    8TC rear fog light for driving on the right
    8U0 without additional instruments for distance measurement
    8WB front fog lights
    8X0 without headlight washer system
    8Y1 two-tone horn
    8Z2 engine cooling system with heavy-duty fan and radiator
    9A0 without taxi alarm system
    9AK "Climatronic" with impact pressure control free of cfc
    9BA w/o additional electric safety package
    9EE wire assembly for 6-cylinder fuel injected engine
    9F0 without sound combination for rotating emergency light and radio antenna preparation
    9G0 without preparation for roof attachments
    9HA without additional malfunction display
    9J0 without supertone system and tone sequence control
    9K0 without intensive washing system for windshield
    9M0 without auxiliary/parking heater
    9P0 without seat belt warning light
    9PB windshield wiper arms/blades with additional guide vanes
    9Q0 without multi-function indicator/on-board computer
    9R0 WITHOUT CONTROL CHECK PACKAGE
    9S0 WITHOUT PROVISION FOR RADIO SET
    9SA WITHOUT PROGRAMMING PLUG
    9T0 without heated washer nozzles
    9V0 without anti-theft protection system
    9W0 w/o car phone preparation/installation
    9X4 without heated door lock cylinder with micro switch
    9Y0 without outdoor temperature gage
    A8S standard equipment
    B01 type approval Germany
    B0A component parts set without country-specific design requirement
    C0Z cast alloy wheels 7J x 15 eight-spoke style, offset 45 (five-hole)
    E0A no special edition
    F0A no special purpose vehicle, standard equipment
    FA0 control of standard production
    G0C 5-speed manual transmission
    H0P tires 205/60 R 15 V
    J0J battery 300 A (63 Ah)
    K8D Station Wagon Variant/Avant
    L0L left-hand drive vehicle
    M76 6-cylinder gasoline engine 2.6 L/110 kW MVEG 2 base engine is T7Y
    N0E woven fabric seat covering
    PH5
    Q1A standard front seats
    RVA
    T7Y components for base engine, unit 078.6
    U0C instrument insert with tachometer clock and km/h speedometer
  2. mager
    mager Живу я здесь
    9 апр 2005
    3.041
    Audi quattro C4
    Ответ: народ поможите перевести на русский
    электронный перевод не ахти :drunk:
    ОбычныйТерминСписокопределенийАдресЦитатыФорматированныйконецформыначалоформыRoof: W9
    Дифференцирование установки 0DT для строит статус класса транспортного средства C (АУДИ) компоненты единицы
    Дифференцирование установки 0EA для передачи компоненты транспортного средства B80
    0F2 питают систему для двигателя бензина карбюратора
    Рычаг переключения передач 0G1
    0LW специальные свидетельства пластин/этикеток/безопасности для Германии
    0MA без ярлыка для того, чтобы начинать автоматическое
    0SB маркирует/обшивает металлическим листом на немецком языке
    Циновки пола фронта 0TC
    Комплект информации 0VC на немецком языке
    0W1 маркируют для центральных электрических немецкоговорящих стран
    1AC антиблокировочная тормозная система (ABS)
    1BE спортивное поглощение приостановки/удара
    1C1 антифриз до-25 степеней терпимость Цельсия до-30 степеней C
    1D0, не буксируя приложение
    1E1 активизированная углеродистая канистра
    1EC специальный номерной знак
    1G3 сплавляют запасное колесо с оригинальными шинами оборудования
    1KD тормоза диска, тыл
    1LB тормоза диска, фронт
    1N1 рулевой привод с усилителем
    1PC болты колеса с противоугонной (неблокируемой) защитой
    1T2 предупреждение треугольника
    1VH инсталяционные части для двигателя с шестью цилиндрами
    1WD шахта передачи для соединения треноги
    1X0 передний двигатель колеса
    1YA без шахт передачи f. поднимают ось
    1Z0 подписывают стандартное топливное заполнение
    2A0 без оборудования поставки
    2B0 без дополнительного внешнего шумового подавления
    2CA без центральной гидравлической системы
    2G1 вставляют для заполнения неэтилированного топлива
    2K1 укрепленные бамперы
    2L0 без более низкой защиты топливного бака
    2PG руль
    2TB решетка радиатора и бампер для горячих областей
    2V1 чистят и фильтр пыльцы
    2Z1 печатают признак в тылу и табличках с фамилией "Quattro" соответственно
    3B0 без дополнительного ребенка помещают якорь
    3C3 пояс коленей с перетрактором для центра поднимают место
    3CA без разделения
    3FA без вставки крыши (стандартная крыша)
    3GB грузовая область с непрерывной взаимной группой
    3J1 приспосабливаемые к высоте подголовники для передних мест
    3L1 ручная подстройка высоты к левому переднему месту
    3N0 без укладки окружают ботинок багажа
    3NC поднимают скамью/спинку места, сворачивание раскола
    3Q5 поднимают подголовники
    3S2 черные рельсы крыши
    3V0 без детского многоместного нераздельного сиденья
    3X0 без груза - через условие
    3Y0 без скатывают экран солнца
    3YB карманы двери, фронт
    3ZB ремни безопасности с 3 пунктами, внешний тыл с ярлыком ECE
    4A0 без нагревателя места
    4D0 без места вентиляции/массажа места
    4E0 крышка задней двери/ствола, отпирающая снаружи
    4F1 центральная система захвата
    4GH ветровое стекло, крашеное с ветровым стеклом sunshield
    4L2 опустившееся отколовшееся внутреннее тыловое зеркало представления
    4M0 без держателя чашки
    4R2 окна власти передний, механический тыл регуляторов окна
    4SA без левого зеркала тщеславия
    4TB право зеркала тщеславия
    4U1 сети/карманы багажа на спинках
    4UE воздушная камера f. водитель a. фронт помещают пассажира
    4W0 без кассеты и единицы хранения компакт-диска
    4ZB яркие лепные украшения
    5C0 без специальных мер тела
    5H3 выравнивание задней двери для автомобиля - универсала Avant
    5K1 красят консервант (воск)
    5MJ декоративные вставки
    6C1 печать окна двери как формовавшая часть
    6D1 сосредотачивают тыл подлокотника
    6E0 без фронта подлокотника центра
    6EA без дополнительных покрытий тела стороны (каменная охрана)
    6FF цветное телом внешнее тыловое зеркало представления housings и различные части добавления
    6G1 носики антиобледенителя для хватки окон стороны закрываются
    6-КИЛОГРАММОВАЯ решетка радиатора
    6M0 без связывают ремни/сеть/карман
    6N0 без откидных створок грязи
    6Q1 пластмассовая кнопка/ручка переключения передач
    6R1 ботинок переключения передач искусственной кожи
    6RA приборная панель и дверь урезают групповой единственный цвет состоящий из одного предмета
    6T0 без внутреннего света в области ноги
    6TB внешнее правильное тыловое зеркало представления: выпуклый, включенный
    6UA внешнее левое тыловое зеркало представления: квартира, включенная
    6V1 тыл урезают группу (ECE)
    6W5 фронт лицензируют скобку пластины
    7A0 без игрока переключателя/КОМПАКТ-ДИСКА компакт-диска
    7E0 w/o нагревают нагревание сумматора / вспомогательное нагревание
    8AD радио-"гамма"
    8CC датчик спидометра без печати (электронный датчик спидометра)
    8F2 огни сигнала поворота стороны
    8FA без второй батареи
    8G0 без антенны телеграфируют для системы радиосвязи
    8GL генератор переменного тока 120A
    8JH эллипсоидальная фара для того, чтобы двигаться справа
    8K0 без специального низкого способа луча
    8KA w/o каталитический конвертер, предупреждающий свет
    8L3 антенна крыши
    8LB дополнительные инструменты (напряжение, нефтяное давление и температура)
    8NA, не оставляя легкий свет предупреждения
    8Q1 регулирование диапазона фары
    8R0 без центра высоко-установленный свет остановки
    8RN восемь (активных) спикеров
    8S0, не читая свет
    8T0 без системы системы автоматического регулирования скорости (CCS)
    8TC поднимают противотуманную фару для того, чтобы двигаться справа
    8U0 без дополнительных инструментов для измерения расстояния
    8WB передние противотуманные фары
    8X0 без системы мойщика фары
    8Y1 двухцветный рожок
    8Z2 машинная система охлаждения со сверхпрочным болельщиком и радиатором
    9A0 без такси встревоживают систему
    9AK "Climatronic" с контролем давления воздействия, свободным от cfc
    9BA w/o дополнительный электрический пакет безопасности
    9EE проводное собрание для топлива с 6 цилиндрами вводило двигатель
    9F0 без звуковой комбинации для того, чтобы вращать критическое положение освещают и радио-подготовка антенны
    9G0 без подготовки к приложениям крыши
    9HA без дополнительного показа сбоя
    9J0 без контроля последовательности системы и тона супертона
    9K0 без интенсивной системы мытья для ветрового стекла
    9M0 без вспомогательного нагревателя / нагревателя стоянки
    9P0 без ремня безопасности, предупреждающего свет
    9PB оружие/лезвия стеклоочистителя с дополнительными лопастями гида
    9Q0 без многофункционального компьютера индикатора/на борт
    9R0 БЕЗ ПАКЕТА ЧЕКА КОНТРОЛЯ
    9S0 БЕЗ УСЛОВИЯ ДЛЯ РАДИО-НАБОРА
    9SA, НЕ ПРОГРАММИРУЯ ШТЕПСЕЛЬ
    9T0 без горячих носиков мойщика
    9V0 без противоугонной системы защиты
    9W0 w/o автомобиль звонят подготовке/установке
    9X4 без горячей двери захватывают цилиндр с микро выключателем
    9Y0 без наружного температурного датчика
    Оборудование стандарта A8S
    B01 печатают одобрение Германия
    Набор частей компонента B0A без определенного для страны требования проекта
    Колеса сплава броска C0Z 7J x 15 восемь - говорили стиль, погашение 45 (пять отверстий)
    E0A никакой специальный выпуск
    F0A никакое специальное транспортное средство цели, стандартное оборудование
    Контроль FA0 стандартного производства
    5 скоростей G0C ручная передача
    H0P утомляет 205/60 R 15 V
    Батарея J0J 300 (63 Ах)
    Автомобиль - универсал K8D Variant/Avant
    Транспортное средство левостороннего управления автомобилем L0L
    Двигатель бензина 6 цилиндров M76 2.6 кВт L/110 MVEG 2 основных двигателя - T7Y
    N0E ткавшее покрытие места ткани
    PH5
    Места фронта стандарта Q1A
    RVA
    Компоненты T7Y для основного двигателя, единица 078.6
    Цвет ОбычныйТерминСписокопределенийАдресЦитатыФорматированныйконецформыначалоформыRoof: W9
    2PG руль
    3CA без разделения
    8AD радио-"гамма"
    8L3 антенна крыши
    8S0, не читая свет
    PH5
    RVA
    U0C инструментуют вставку с часами тахометра и спидометром км/ч
  3. sim_a100_2.3_92
    sim_a100_2.3_92 Старожил
    6 дек 2003
    28.949
    ВАЗ 21083
    Вот это особенно порадовало:)
  4. Zeus
    Zeus Живу я здесь
    20 мар 2005
    2.504
    Q7 4.2 TDI
    спасибо, всё совпадает, кроме 8 активных спикеров
  5. mager
    mager Живу я здесь
    9 апр 2005
    3.041
    Audi quattro C4
    я сам когда себе переводил :rzunimagu :rzunimagu :rzunimagu
  6. Mihalih
    Mihalih Живу я здесь
    18 окт 2004
    1.972
    A2 1.4 BBY
    а куда можно ввести вин чтобы такую раскодировку получить?
  7. mager
    mager Живу я здесь
    9 апр 2005
    3.041
    Audi quattro C4
    в етку :nod:
  8. Mihalih
    18 окт 2004
    1.972
    A2 1.4 BBY
    эта та, ктороая через инет работает, я что то как то раз пробовал, говорит типа сервер не найден
  9. Zeus
    Zeus Живу я здесь
    20 мар 2005
    2.504
    Q7 4.2 TDI
  10. mager
    mager Живу я здесь
    9 апр 2005
    3.041
    Audi quattro C4
    еще темка как :umnik:
    http://www.audi-club.ru/forum/showthread.php?t=20664&highlight=etka
