Всем привнет Сделал вчера диагностику и вот её результаты: Thursday,23,January,2014,12:18:30:32264 VCDS Version: Release 11.11.3 Data version: 20120401 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 57 61 62 72 76 VIN: WAUZZZ4F66N116862 Mileage: 167410km/104023miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06C-909-559-ASN.lbl Part No SW: 4F0 910 559 A HW: 4F0 907 559 Component: 3.0L V6/5V 0030 Revision: --H01--- Serial number: Coding: 0008772 Shop #: WSC 02325 785 00200 VCID: 2855E6799BE83A9 2 Faults Found: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28) P1340 - 001 - Incor. Correlation - MIL ON 19760 - B1 P3304 - 002 - Exhaust Cam Pos. Sensor (G300) / Crank Pos. Sensor (G28) Incorr. Correl. - MIL ON Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H04 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0021407 Shop #: WSC 02331 785 00200 VCID: 2D5B176DB40A1F1 2 Faults Found: 00493 - ESP-Sensor Unit (G419) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 65 Mileage: 167311 km Time Indication: 0 Date: 2014.01.23 Time: 09:51:55 Freeze Frame: Hex Value: 0x0040 Hex Value: 0x4282 Hex Value: 0x0043 Hex Value: 0x018D Hex Value: 0x00FF 00473 - Control Module for Elect. Park/Hand Brake (J540) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 7 Reset counter: 102 Mileage: 167263 km Time Indication: 0 Date: 2014.01.19 Time: 13:07:11 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4282 Hex Value: 0x002D Hex Value: 0x058D Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0220 Revision: 31050601 Serial number: 10604000297437 Coding: 0000007 Shop #: WSC 00351 935 53945 VCID: E3CF3155224E191 Part No: 4F0 910 131 C Component: FBSAUDIC6 EZS H45 0070 Part No: 4F0 910 335 Component: FBSAUDIC6 KSG H27 0080 Part No: 4F0 910 220 F Component: FBSAUDIC6 IDG H45 0060 4 Faults Found: 00193 - Right Rear Door Handle Touch Sensor (G418) 007 - Short to Ground Freeze Frame: Fault Status: 01110111 Fault Priority: 3 Fault Frequency: 6 Reset counter: 184 Time Indication: 0 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 3 Fault Frequency: 6 Reset counter: 18 Mileage: 155864 km Time Indication: 0 Date: 2011.11.01 Time: 18:40:38 00193 - Right Rear Door Handle Touch Sensor (G418) 011 - Open Circuit Freeze Frame: Fault Status: 01111011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 112 Mileage: 157810 km Time Indication: 0 Date: 2011.12.24 Time: 17:06:27 00191 - Passenger's Door Handle Touch Sensor (G416) 011 - Open Circuit Freeze Frame: Fault Status: 01111011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 113 Mileage: 157819 km Time Indication: 0 Date: 2012.01.06 Time: 11:07:07 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 C HW: 4F0 907 279 A Component: ILM Fahrer H15 0190 Revision: 00000000 Serial number: 4F0907279 Coding: 0002122 Shop #: WSC 02335 785 00200 VCID: 2953E37D80E2031 Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH11 0050 Coding: 00141886 Shop #: WSC 02335 1 Fault Found: 01834 - Bulb for Side-Blinkers; Left (M18) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 94 Mileage: 166996 km Time Indication: 0 Date: 2014.01.14 Time: 11:21:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE8010940 Shop #: WSC 00000 000 00000 VCID: 1C3DCAA9DFB0E69 1 Fault Found: 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 7 Fault Frequency: 2 Reset counter: 159 Mileage: 157873 km Time Indication: 0 Date: 2005.03.03 Time: 08:21:58 Freeze Frame: Text: 00000000 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 792 E Component: TSG BF H12 0080 Revision: 00-00000 Coding: 0016906 Shop #: WSC 02327 785 00200 VCID: 2C5D1A698F10169 1 Fault Found: 02112 - Window Regulator Over-Temp Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 105 Mileage: 167403 km Time Indication: 0 Date: 2014.01.23 Time: 11:26:20 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0004021 Shop #: WSC 02334 785 00200 VCID: DDBB07AD042A2F1 1 Fault Found: 02432 - Supply Voltage for Left Parking Brake Motor (V282) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00111011 Fault Priority: 2 Fault Frequency: 4 Reset counter: 102 Mileage: 167256 km Time Indication: 0 Date: 2014.01.19 Time: 13:07:09 Freeze Frame: Voltage: 10.56 V Count: 116 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: J0644 BEM H12 0590 Revision: 00000000 Serial number: 00000000159829 Shop #: WSC 00422 935 80828 VCID: 234FF155E2CED91 Subsystem 1 - Part No: 4F0 915 105 B Component: von MLA 0511180438 Coding: 34463039313531303542204D4C4130353131313830343338 Shop #: WSC 00000 384 00290 5 Faults Found: 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 35 Mileage: 165098 km Time Indication: 0 Date: 2012.07.22 Time: 06:34:50 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 78 Mileage: 165098 km Time Indication: 0 Date: 2012.07.21 Time: 19:18:31 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 24 Mileage: 151094 km Time Indication: 0 Date: 2005.02.02 Time: 13:49:19 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 18 Mileage: 151094 km Time Indication: 0 Date: 2005.02.02 Time: 22:13:50 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 5 Mileage: 167279 km Time Indication: 0 Date: 2014.01.21 Time: 10:10:32 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 C HW: 4F0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 11820532000658 Coding: 0201006 Shop #: WSC 02331 785 00200 VCID: 244DF249E7C0DE9 2 Faults Found: 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 33 Reset counter: 105 Mileage: 163378 km Time Indication: 0 Date: 2013.11.13 Time: 10:51:43 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 5 Reset counter: 104 Mileage: 167012 km Time Indication: 0 Date: 2014.01.15 Time: 08:31:28 End --------------------------------------------------------------------- Интересует вот что: 1. по какой причине может отсутствовать связь с ESP, где находится этот блок, как это лечить? 2. что может быть не так с датчиком распредвала, кстати у меня плавают обороты в районе 1500-2000, может это быть из-за него? С остальным разобрались. Заранее благодарю!!!
поизучай вот тут http://www.audi-club.ru/forum/showthread.php?t=142982 только не надо весь отчет сразу вываливать, сначала почитай внимательно как минимум первый пост.
плавать обороты начинают в районе 1500 и заканчивают после 2000, ну допустим хочешь держать 1700, а они плавно скачут 1700-1900 и не зависит едешь или стоишь
Масло точно не помню (какой-то мобил), на горячую точно плавают, а вот на холодную внимания не обращал. Мне диагност то же сказал попробовать для начала сменить масло, потому как если не то масло залито, то могут фазики шалить и соответственно выдавать ошибку по р.валам. Вот думаю теперь заменить масло (как раз уже пора менять), может и уйдёт этот недуг. Меня больше то беспокоит ошибка по ESP, то что связи нет с блоком это я понял, а вот где он расположен никак не могу найти. Получается если с ним нет связи, значит где-то обрыв в проводке или плохой контакт или мог сам блок умереть?
да быть то может все что угодно, про есп не сталкивался, не скажу. а вот про фазы да, начни со смены масла.
Насчёт диагноста я уверен, он человек толковый (разбирался в том что не могли сделать официалы и многие другие сервисы), да и работает он в этой области уже более 10-ти лет. Кстати он сказал что на датчике может образоваться какая-то пыль/cтружка и её нужно почистить.
Правильная работа фазорегуляторов зависит от давления/качества масла или я ошибаюсь? И мне интересно насчёт смены диагноста, если я сделаю диагностику в другом месте, то у меня другие ошибки покажет?
от давления. у меня решали некоторые вопросы по движку и для повышения давления плюхнули 5в60. прогретое двигло колбасило маманегорюй. учитывая что других факторов на это влияющих на тот момент не выявлено, и тот факт что произошла только смена масла - в60 сделало свое дело. да, эти муфты снимаются, разбираются, чистятся. раз уж снимут желательно осмотреть валы на предмет отсутствия выработок в каналах подачи этого самого масла в эти самые регуляторы.
нет, судя по всему, выискивай допуск vw 502.0 - 505.0 http://yandex.ru/yandsearch?lr=65&t...е+масла+с+допуском+vag+фольксваген+volkswagen
я лил motul specific 502 505. Есть еще подходящие. Понятно что они подороже, но для начала попробуй залить мобил с соответствующими допусками, чтоб стало понятно в чем причина, и если мобил устроит, по расходу, заводимости в холодную погоду и т.д. можно и на нем остаться, многие тут его хвалят.
