Вот весь список какашек)) Машину только купили,подскажите подробнее что и где надо рыть под эти ошибки? VIN: WAUZZZ4F35N032206 Mileage: 215960km/134191miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Sporadic communication error 1000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 560 D HW: 4F0 907 559 Component: 4.2L V8/5V 0010 Revision: -------- Serial number: Coding: 0026772 Shop #: WSC 02325 785 00200 VCID: 23450907E2202306A91-8076 8 Faults Found: 17980 - Left Engine Mount Solenoid Valve (N144) P1572 - 002 - Short to Ground 17833 - EVAP Purge Valve (N80) P1425 - 002 - Short to Ground - MIL ON 17985 - Right Engine Mount Solenoid Valve (N145) P1577 - 004 - Open Circuit 17843 - Secondary Air Pump Relay (J299) P1435 - 002 - Short to Ground - MIL ON 17829 - Secondary Air Injection Solenoid Valve (N112) P1421 - 002 - Short to Ground - MIL ON 16486 - Mass Air Flow Sensor (G70) P0102 - 002 - Signal too Low - MIL ON 17475 - Intake Air Switch-Over Valve (N335) P1067 - 002 - Short to Ground 17923 - Intake Manifold Valve (N156) P1515 - 002 - Short to Ground Readiness: 0010 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 G HW: 09L 927 156 Component: AG6 09L 4.2L5V RdW 0070 Revision: --H01--- Serial number: 0039021 Coding: 0000001 Shop #: WSC 02327 785 00200 VCID: 285F1E2B9B06C05EFC3-807D 1 Fault Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU Freeze Frame: Fault Status: 01110000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 215880 km Time Indication: 0 Date: 2015.07.08 Time: 12:30:11 Freeze Frame: RPM: 1152 /min RPM: 1152 /min RPM: 0 /min (no units): 30.0 (no units): 22.0 Temperature: 84.0°C T.B. Angle: 0.0° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 E HW: 4F0 614 517 A Component: ESP8 quattro H03 0010 Revision: 00000000 Serial number: 00000000000000 Coding: 0004456 Shop #: WSC 20737 124 50634 VCID: 264310139112D62ECEF-8073 1 Fault Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 224 Mileage: 215880 km Time Indication: 0 Date: 2015.07.08 Time: 12:30:10 Freeze Frame: Hex Value: 0x0280 Hex Value: 0x4082 Hex Value: 0x0000 Hex Value: 0x0093 Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 E Component: FBSAUDIC6 ELV H05 0100 Revision: 00H05000 Serial number: 10602501480948 Coding: 0000003 Shop #: WSC 00481 935 70784 VCID: 2541171FEC14DD36C75-8070 Subsystem 1 - Part No: 4F0 910 131 A Component: FBSAUDIC6 EZS H43 0070 Subsystem 2 - Part No: 4F0 910 220 Component: FBSAUDIC6 IDG H39 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: Redir Fail! Part No SW: 4F0 910 729 P HW: 4F0 035 729 F Component: MMI Cockpit H90 0120 Revision: C41300FE Serial number: AUZ6Z3D6M707I2 Coding: 0145141 Shop #: WSC 02327 785 00200 VCID: 3663C05341B2A6AE7EF-8063 Subsystem 1 - Part No: 4F0 910 609 B Component: Bedienteil MMIC6H07 0010 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 S Component: KLIMABETAETIGUNGH12 0160 Revision: 00000027 Serial number: 00000030032598 Coding: 0008200 Shop #: WSC 00002 401 53614 VCID: DBB5F1E71AD0DBC6211-808E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 A HW: 4F0 907 279 A Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0102122 Shop #: WSC 02335 785 00200 VCID: 275D1D179618CF26F59-8072 Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0040 Coding: 00141886 Shop #: WSC 02335 1 Fault Found: 01496 - Bulb for Fog-Lamps; Left (L22) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 3 Reset counter: 8 Mileage: 215956 km Time Indication: 0 Date: 2015.07.08 Time: 17:52:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: Redir Fail! Part No SW: 4F0 910 729 P HW: 4F0 035 729 F Component: MMI Cockpit H90 0120 Revision: C41300FE Serial number: AUZ6Z3D6M707I2 Coding: 0145141 Shop #: WSC 02327 785 00200 VCID: 3663C05341B2A6AE7EF-8063 1 Fault Found: 00468 - CD-ROM Drive (R92) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 9 Mileage: 215952 km Time Indication: 0 Date: 2015.07.08 Time: 17:08:27 Freeze Frame: Bin. Bits: 01000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 D HW: 4F0 959 655 B Component: 33 AIRBAG AUDI8RH28 0250 Revision: 04H28000 Serial number: 0037LD0368T4 Coding: 0013107 Shop #: WSC 00444 935 77086 VCID: 285F1E2B9B06C05EFC3-807D Subsystem 1 - Serial number: 6332CSME04050052K Subsystem 2 - Serial number: 6342CSME0406213CX Subsystem 3 - Serial number: 6351HSME033F09298 Subsystem 4 - Serial number: 6361HSME033E0100W Subsystem 5 - Serial number: 6371VSME03060A37C Subsystem 6 - Serial number: 6381VSME03060102$ 1 Fault Found: 01219 - Rear Side Airbag Igniter; Driver Side (N201) 001 - Upper Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksдulenmodul H07 0230 Revision: 00H07000 Serial number: 90026041990009 Coding: 0012011 Shop #: WSC 02323 785 00200 VCID: E6C3D013D192962E8EF-80B3 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 900 A HW: 4F0 920 900 R Component: KOMBIINSTR. M73 H08 0630 Revision: 00100000 Serial number: 4H-708974 Coding: 0001143 Shop #: WSC 12354 123 45725 VCID: 1E3338F3C9420EEE86F-804B 1 Fault Found: 00379 - Terminal 58s 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 8 Mileage: 215888 km Time Indication: 0 Date: 2015.07.08 Time: 13:21:50 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 B Component: Gateway H09 0030 Revision: 09 Serial number: 08008047120281 Coding: ECFE73CC3B1104 Shop #: WSC 02325 785 00200 VCID: 275D1D179618CF26F59-8072 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 8 Mileage: 215914 km Time Indication: 0 Date: 2015.07.08 Time: 14:34:23 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 D HW: 4E0 035 111 A Component: CD-Changer H43 0340 Revision: 00000000 Serial number: AUZ5ZBD6000755 Shop #: WSC 00000 000 00000 VCID: 1A3B34E3D56A62CE7A7-804F 1 Fault Found: 02261 - Data Medium 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 7 Fault Frequency: 1 Reset counter: 40 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: Text: 00000000 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082946 Shop #: WSC 02327 785 00200 VCID: E1C9C30F38BCF1167BD-80B4 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 793 B Component: TSG FA H10 0020 Revision: 00000000 Serial number: p Coding: 0000654 Shop #: WSC 02327 785 00200 VCID: 29591B2F800CF956E3D-807C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 E HW: 4F0 907 289 E Component: Komfortgeraet H14 0090 Revision: 00900014 Serial number: 01000497060000 Coding: 0394481 Shop #: WSC 02335 785 00200 VCID: 2C57E23B8FFEEC7E18B-8079 Subsystem 1 - Part No: 1K0 951 605 A Component: LIN BACKUP HORN H01 1201 Subsystem 2 - Part No: 4F0 910 177 Component: Innenraumueberw.H01 0010 4 Faults Found: 02734 - Bulb for Tail Light 3; Left 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 224 Mileage: 0 km Time Indication: 0 Date: 2005.05.26 Time: 22:25:40 01502 - Bulb for Rear Fog; Left (L46) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 139 Reset counter: 224 Mileage: 214610 km Time Indication: 0 Date: 2005.02.02 Time: 13:17:40 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 224 Mileage: 145905 km Time Indication: 0 Date: 2013.01.18 Time: 14:30:25 02397 - Parking Light Rear Right (M2) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 153 Reset counter: 224 Mileage: 213586 km Time Indication: 0 Date: 2005.02.02 Time: 08:25:20 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-AS.lbl Part No SW: 4F0 910 223 B HW: 4F0 035 223 Component: Amp.-ASK H09 0270 Revision: 14S00001 Serial number: 01207040019438 Coding: 0000006 Shop #: WSC 02335 785 00200 VCID: 1D313FFFC44415F69F5-8048 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H07 0040 Revision: Serial number: 00000000020424 Coding: 0011114 Shop #: WSC 02323 785 00200 VCID: DEB3F8F309C2CEEE46F-808B No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 792 B Component: TSG BF H10 0020 Revision: 00000000 Serial number: d‰ Coding: 0000654 Shop #: WSC 02327 785 00200 VCID: 29591B2F800CF956E3D-807C No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 C HW: 4F0 907 801 A Component: EPB CDEC0080 H04 0080 Revision: --H04--- Coding: 0006021 Shop #: WSC 20737 124 50634 VCID: 204F060BF336381EB43-8075 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 184 Reset counter: 8 Mileage: 215880 km Time Indication: 0 Date: 2015.07.08 Time: 13:06:39 Freeze Frame: Voltage: 13.46 V Count: 236 ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 8P0-907-357.lbl Part No: 8P0 907 357 A Component: Dynamische LWR H01 0010 Revision: 00000000 Serial number: Coding: 0000003 Shop #: WSC 02327 785 00200 VCID: 387FCE6B4BA650DE6C3-806D No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: Redir Fail! Part No SW: 4F0 910 729 P HW: 4F0 035 729 F Component: MMI Cockpit H90 0120 Revision: C41300FE Serial number: AUZ6Z3D6M707I2 Coding: 0145141 Shop #: WSC 02327 785 00200 VCID: 3663C05341B2A6AE7EF-8063 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H11 0490 Revision: 00000000 Serial number: 00000000038031 Shop #: WSC 00001 401 61945 VCID: 23450907E2202306A91-8076 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 390811B1N8 Coding: 344630393135313035442056413033393038313142314E38 Shop #: WSC 00444 935 77086 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 795 A Component: TSG HL H09 0010 Coding: 0000006 Shop #: WSC 02327 785 00200 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 794 A Component: TSG HR H09 0010 Coding: 0000006 Shop #: WSC 02327 785 00200 VCID: 2A5BE423850AF24EEA7-807F No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 A HW: 4F0 919 283 A Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 11830420200137 Coding: 0001006 Shop #: WSC 02327 785 00200 VCID: 224B0C03FD3A2A0EA27-8077 2 Faults Found: 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 224 Mileage: 215880 km Time Indication: 0 Date: 2015.07.08 Time: 13:05:32 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 224 Mileage: 215880 km Time Indication: 0 Date: 2015.07.08 Time: 13:05:32 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 B HW: 4E0 862 335 Component: Handyvorb2 H09 0080 Revision: 00000000 Serial number: 00000007511819 Coding: 0010900 Shop #: WSC 02335 785 00200 VCID: 2149030FF83C3116BBD-8074 No fault code found.
В целом ничего серьезного. Некоторые ошибки по-моему занесены кривыми руками. Например про G70. Явно 80 км назад завели авто с отсоединенным впускным патрубком, из за этого в ABS и акпп ошибки по сигналу нагрузки. Ошибки потёр, поезди 100-200 км и сними снова.
Проблема в том что авто стоял на штраф стоянке 1,5 года....вот после этого и вылезли все ошибки эти) Если не сложно.можешь немного подробнее подсказать: горит ЕСП,Подушка,Ручник...не допирает мой мозг) П.С как понял по ручнику сдох левый моторчик.
По подушкам снимишь задний диван, найдешь желтый разъем слева и откроешь закроешь его раз 10, все должно пройти, только не сломай фиксатор на нем. По ручнику не вижу ошибки по моторчику... Там жгут переломился, купишь новый жгут и все заработает.
утром найду документ где приговорило моторчик...за подушки огромное спасибо,завтра пойду делать! а что именно за жгут?
И это, в редактировании спрячь протокол диагностики в "cut", а то экран на огрызке уже дымится от пальцев.
