провел диагностику шнурком. Помогите расшифровать VCDS Version: Release 11.11.3 Data version: 20120401 Saturday,11,May,2013,12:45:16:32264 Chassis Type: 4B - Audi A6 C5 Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67 75 76 77 VIN: WAUZZZ4BX4N088848 Mileage: 140280km/87165miles ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 4D0 907 560 BG HW: 8E0 907 560 Component: 4.2L V8/5V 0020 Coding: 0008755 Shop #: WSC 00999 444 64523 VCID: 6CDDDA694C90D69 6 Faults Found: 16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit P0030 - 004 - Malfunction / Open Circuit - MIL ON 17887 - Brake Boost Vacuum System P1479 - 008 - Mechanical Failure - Intermittent 16537 - Oxygen (Lambda) Sensor B2 S1 P0153 - 002 - Response too Slow - MIL ON 18010 - Power Supply Terminal 30 P1602 - 002 - Voltage too Low - Intermittent 18080 - Coolant Fan Control 1 P1672 - 004 - Open or Short to Ground - Intermittent 18339 - Coolant Fan Control Module (J293) P1931 - 004 - Malfunction - Intermittent Readiness: 0000 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.lbl Part No: 4Z7 927 156 R Component: AG5 01V 4.2l5V RdW 2224 Coding: 00001 Shop #: WSC 00000 VCID: 55AB9F8DAF1A771 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4Z7 907 389 A Component: ABS/ESP allrad D56 Coding: 06387 Shop #: WSC 02334 VCID: 4A917CF176A4289 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl Part No: 4B0 820 043 AP Component: A6-Klimavollautomat 0208 Coding: 00100 Shop #: WSC 02335 VCID: 68D5A6790868FA9 1 Fault Found: 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4B0-959-655-AI84.lbl Part No: 4Z7 959 655 M Component: Airbag 8.4EP 1000 Coding: 0000106 Shop #: WSC 02335 785 00200 VCID: 59B393BD9302531 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4B0-920-xxx-17.lbl Part No: 4B0 920 933 P Component: KOMBI+WEGFAHRS. VDO D15 Coding: 04183 Shop #: WSC 00000 VCID: 30650E19F038729 WAUZZZ4BX4N088848 AUZ7Z0D2599449 1 Fault Found: 01327 - Control Module for Parking Aid (J446) 49-00 - No Communications ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No: 4D0 265 105 K Component: Standheizung Benzin D52€ Coding: 00111 Shop #: WSC 02334 VCID: 2649E841C2FC2C9 2 Faults Found: 01406 - No Flame 35-10 - - - Intermittent 01408 - Under-Voltage Shut-Off (fixed Value) 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4Z7-907-553.lbl Part No: 4Z7 907 553 F Component: - 2C1A1 D060 Coding: 25500 Shop #: WSC 51300 VCID: 489546F968A8DA9 4 Faults Found: 00668 - Supply Voltage Terminal 30 31-00 - Open or Short to Ground 01769 - Sensor for Vehicle Leveling; Front Right (G289) 57-10 - Electric Circuit Failure - Intermittent 01400 - Suspension Level Control 11-10 - Control Limit Not Reached - Intermittent 01772 - Signal from Level Control Pressure Sensor (G291) 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 4B0-962-258.lbl Part No: 4B0 962 258 N Component: Zentralverrieg.,DWA D38 Coding: 06991 Shop #: WSC 00404 VCID: 346D020904204E9 3 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01134 - Alarm Horn (H12) 76-10 - Terminal 30 missing - Intermittent ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: None Part No: 4B0 951 178 A Component: Innenraumueberw. D04 Coding: 00102 Shop #: WSC 02334 VCID: 2649E841C2FC2C9 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 4B0 035 186 S Component: concert II GRO 0001 Coding: 02003 Shop #: WSC 02334 VCID: 30650E19F038729 2 Faults Found: 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 00858 - Connection; Radio ZF Output to Antenna Amplifier 29-10 - Short to Ground - Intermittent End ---------------------------------------------------------------------
