Почитал ошибки, помогите расшифровать
Тема в разделе "4F C6", создана пользователем SadovnikovDen, 17 дек 2014.
  1. SadovnikovDen
    SadovnikovDen Новичок
    13 авг 2014
    65
    Выбираю а6 с6
    Ребят, с английским не дружу, оригинальным Васей поскупился)
    Помогите пожалуйста расшифровать ошибки:
    Additional Info: 4F0915105E von VA0 1610260865
    Additional Info: Geraet 87503
    VCID: 2345090EE275F506A91-8076
    4 Faults Found:
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 9
    Reset counter: 255
    Mileage: 156413 km
    Time Indication: 0
    Date: 2014.11.20
    Time: 14:35:45
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 156413 km
    Time Indication: 0
    Date: 2014.11.20
    Time: 14:50:10
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 156413 km
    Time Indication: 0
    Date: 2014.11.20
    Time: 14:50:21
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 156413 km
    Time Indication: 0
    Date: 2014.11.20
    Time: 14:52:18
    Tuesday,01,October,2013,13:01:25:40973
    VCDS Version: Release 12.12.0
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Control Module Part Number: 4F0 910 043 A HW: 4F1 820 043 AG
    Component and/or Version: KLIMABETAETIGUNGH30 0020
    Software Coding: 0534534
    Work Shop Code: WSC 02335 785 00200
    VCID: 1C3732F2DF0BCAFE68B-8049
    2 Faults Found:
    01273 - Fresh Air Blower (V2)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 73
    Mileage: 157462 km
    Time Indication: 0
    Date: 2014.11.28
    Time: 21:19:42
    Freeze Frame:
    Temperature: 1.0°C
    Speed: 6.0 km/h
    (no units): 24.0
    (no units): 220.0
    00739 - Coolant Circulation Pump (V50)
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 157885 km
    Time Indication: 0
    Date: 2014.12.03
    Time: 07:03:11
    Freeze Frame:
    Temperature: 57.0°C
  2. Sergey4
    Sergey4 Живу я здесь
    14 окт 2012
    4.497
    2.7тди
  3. unknown630
    unknown630 Участник форума
    6 май 2014
    482
    A6/C6 2.4 06г
    #3 unknown630, 17 дек 2014
    02272 Ток покоя, режим 1
    02273 Ток покоя, режим 2
    02276 Ток покоя, режим 5
    02274 Ток покоя, режим 3
    01273 Приточный вентилятор-V2,Открыть или короткое замыкание на массу
    00739 Циркуляционный насос ОЖ -V50,Нижний Предел Превышен
  4. sonic_a4
    sonic_a4 Живу я здесь
    25 авг 2013
    4.491
    A6/C6 3.2Q 05г.
    По первым четырем: стереть и забыть:)
    По последней стереть и следить; по вентилятору V2 - разбираться
  5. ASushkov69
    ASushkov69 Новичок
    19 мар 2012
    42
    A6/c6 2.0tdi 07г.
    Первые четыре возникли скорее всего из-за снятия/разрядки аккумулятора, на них можно не обращать внимания
