всем привет.пожалуйста помогите найти pr коды по вину авто. wauzzz4b24n065659 .если не трудно скинте инфу.кто знает где их искать.спасибо.
Audi A6/Avant Дата производства 14.01.2004 Модельный год 2004 VIN WAUZZZ4B24N065659 Код двигателя BDG Код КПП FRF Код оснащения MB Цвет кузова 4Z Цвет крыши 4Z 0DS Vehicle class differentiation 4B0 0F3 Fuel system for diesel engine 0G1 Gearshift lever 0GG Emission standard EU4 0JM Weight category front axle weight range 12 0LW With special plates/labels/ safety certificates for Germany 0N1 Standard rear axle 0ST Labels/plates in German and French 0VC Information kit in German 0W1 Label for central electric German-speaking countries 0YE Weight range 5 installation control only, no requirement forecast 1BA Standard suspension/shock absorption 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C 1D0 Without trailer hitch 1E0 Without activated carbon canister 1EX Special identification plate for EC for M1 passenger vehicle 1G3 Alloy spare wheel with original equipment tires 1KD Disk brakes in rear 1LG Disk brakes in front 1N1 Power steering 1PC Wheel bolts with anti-theft protection (unlockable) 1SA Without additional front underbody guard 1T3 First aid kit with warning triangle 1VH Installation parts for six-cylinder engine 1WD Transmission shaft for tripod joints 1X0 Front wheel drive 1YA Without transmission shafts f. rear axle 1Z0 Initial standard fuel filling 2A5 Delivery equipment (transit coating) with thin seat cover 2B1 Additional exterior noise suppression 2C5 Axial and vertical adjustable steering column 2G0 Without insert for the filling up of fuel 2PG Steering wheel 2T0 Without 2-DIN 2WA Without additional tires 2Z0 Elimination of model designation 3B0 Without additional child seat anchor 3C7 3-point seat belt for center rear seat 3CA Without partition 3FA Without roof insert (standard roof) 3HA Without leather parts scope 3NZ Unsplit rear seat bench unsplit, split folding backrest 3PF Power height adjustment for both front seats 3Q6 Three rear head restraints 3S0 Without roof rails/roof load rack 3V0 Adaptive cruise control high end without Inno Drive 3X0 Without load-through hatch 3Y0 Without roll-up sunshade 4A3 Seat heater for front seats separately controlled 4E0 Tailgate/trunk lid unlocking from outside 4GH Windshield in heat-insulating glass with sunshield 4K4 Radio remote controlled central locking 4KC Side and rear windows in heat-insulatingglass 4L2 Dimming breakaway interior rearview mirror 4N0 Standard dashboard 4UE Airbag for driver and front passenger 4W0 Without cassette and CD storage unit 4X3 Side airbag in front, with curtain airbag 4ZB Bright moldings 5A5 Luggage compartment lining, with storagecompartments 5C0 Without special body measures 5D1 Carrier frequency 433.92 MHz-434.42 Mhz 5E6 Sill top with door cover 5J0 Without rear spoiler 5K1 Paint preservative (wax) 5RU Right exterior mirror: convex (large viewing field) 5SL Left exterior mirror: aspherical 5TM Decorative inserts 2D-IML, version 4 6E3 Center armrest in front 6FB Body-colored exterior mirror housings 6M1 Tie down straps 6PA Plastic hand brake lever handle 6Q1 Plastic gearshift knob/handle 6R1 Leatherette gearshift boot 6SS Luggage compartment floor covering 6U0 Without additional seals outside 6V1 Rear trim panel (ECE) 6W5 Front license plate carrier 6XD Exterior mirrors, power-adjustable/ heated 7A0 Without CD changer/CD player 7AA Electronic engine immobilizer 7E6 Electric auxiliary air heater 7K0 Without direct tire pressure monitoring system 7M1 Scuff plates in door apertures with metal cores 7P1 Power-adjustable lumbar support in frontseats 7Q9 Navigation system 7QB CD ROM (Germany) 7X1 Park distance control 8GU Alternator 140 A 8JH Ellipsoidal headlamps for driving on the right 8K0 Without special headlamp activation 8N4 Windshield wiper intermittent control with potentiometer (four speeds) 8Q1 Headlight range adjustment 8T1 Cruise control system (CCS) 8TC Rear fog lamp for driving on the right 8UD Radio "concert" 8X0 Without headlamp washer system 8Z5 Not hot country 9AK Climatronic with impact pressure control, CFC-free 9B0 Without telepay device 9M0 Without auxiliary heater/fuel-fired parking heater 9NX Without electronic logbook 9P0 Without seat belt reminder 9Q2 Multi-function display/on-board computerwith check control 9VD Speaker (active) 9ZF Mobile phone interface with handsfree set A00 No self-collection A8S Standard equipment B01 Type approval country Germany B0A Component parts set without country-specific building regulation C24 Operating permit, alteration C9B Alloy wheels 7J x 16 D1P 6-cyl. turbo diesel engine 2.5 l/120 kW V6 24V, distributor injection pump base engine is T5T/T1K E0A No special edition F0A No special purpose vehicle, standard equipment FA0 Control of series production FC0 Without customized installation FQ0 Production wheels G0K 6-speed manual transmission GS0 Without applications H6U Tires 205/55 R16 91W J1R Battery 420 A (82 Ah) K8B Notchback L0L Left-hand drive N4J Seat trim covers in fabric "Sports 4B0" NT0 Transit coating (type 1) Q1A Standard seats in front QA0 Without child seat QH0 Without voice control QV0 Without TV reception/digital radio reception T1K 6-cylinder diesel engine 2.5 l unit 059.E U2B Instrument cluster w/ km/h speedometer, radio-controlled clock, tachometer, tripodometer and additional instruments V0A Tires without specification of tire brand VC0 Without remote-controlled garage door opener VJ1 Reinforced bumpers VX0 Without hands-free system VY0 Without danger alarm system WDC WDE С расшифровкой.
