Всем здравствуйте! Сегодня решил проверить машину шнурком. Вылезла куча ошибок. Кто знает, что они означают? Спойлер Address 01: Engine Labels: 06C-909-559-ASN.lbl Control Module Part Number: 4F0 910 559 A HW: 4F0 907 559 Component and/or Version: 3.0L V6/5V G 0030 Software Coding: 0026582 Work Shop Code: WSC 02325 785 00200 VCID: 285BFC939BE83A3 1 Fault Found 16955 - Brake Switch (F) P0571 - 008 - Implausible Signal - Intermittent Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Control Module Part Number: 4F0 910 732 S HW: 4E0 035 729 Component and/or Version: Interfacebox H43 5150 Software Coding: 0000001 Work Shop Code: WSC 02335 785 00200 Additional Info: 4F0910609 Bedienteil MMIC6H07 0870 Additional Info: Geraet 00200 VCID: 33611BFF522E49B Fault Codes have been Erased 1 Fault Found 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 227 Mileage: 154420 km Time Indication: 0 Date: 2015.08.02 Time: 08:03:03 Address 02: Auto Trans Labels: 01J-927-156.lbl Control Module Part Number: 4F1 910 155 HW: 01J 927 156 HT Component and/or Version: V30 01J 3.0l 5V RdW 0020 Software Coding: 0000001 Work Shop Code: WSC 02327 785 00200 VCID: E0CB24B33358023 1 Fault Found 18201 - Transmission Output Speed Sensor 2 (G196) P1793 - 000 - No Signal Freeze Frame Fault Status: 01110000 Fault Priority: 0 Fault Frequency: 254 Reset counter: 40 Mileage: 142007 km Time Indication: 0 Date: 2015.02.27 Time: 13:45:07 Freeze Frame RPM: 1376 /min RPM: 100 /min (no units): 3.0 Torque: 142.0 Nm Temperature: 63.0°C T.B. Angle: 24.0° Bin. Bits: 1010 0 0 Address 08: Auto HVAC Labels: 4F0-910-043.lbl Control Module Part Number: 4F0 910 043 HW: 4F1 820 043 J Component and/or Version: KLIMABETAETIGUNGH11 0100 Software Coding: 0008198 Work Shop Code: WSC 02327 785 00200 VCID: DBB1135F1A3E21B 1 Fault Found 00256 - A/C Pressure/Temperature Sensor (G395) 001 - Upper Limit Exceeded - Intermittent Freeze Frame Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 38 Reset counter: 11 Mileage: 149631 km Time Indication: 0 Date: 2015.06.23 Time: 13:18:37 Address 46: Central Conv. Labels: 4F0-910-289.lbl Control Module Part Number: 4F0 910 289 E HW: 4F0 907 289 E Component and/or Version: Komfortgeraet H14 0090 Software Coding: 0394481 Work Shop Code: WSC 02335 785 00200 Additional Info: 1K0951605A LIN BACKUP HORN H01 0101 4F0910177 Innenraumueberw.H01 0010 VCID: 2C5300838F10163 Fault Codes have been Erased 1 Fault Found 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 227 Mileage: 135804 km Time Indication: 0 Date: 2014.12.02 Time: 10:13:06 Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Control Module Part Number: 4F0 910 852 HW: 4F0 905 852 B Component and/or Version: FBSAUDIC6 ELV H30 0180 Software Coding: 0000007 Work Shop Code: WSC 00328 935 83086 Additional Info: 4F0910131C FBSAUDIC6 EZS H43 0070 4F0910335 FBSAUDIC6 KSG H25 0070 VCID: E3C12BBF224E19B 2 Faults Found 01049 - Supply Voltage Term 50 006 - Short to Plus Freeze Frame Fault Status: 01100110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 142007 km Time Indication: 0 Date: 2015.02.27 Time: 13:41:59 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent Freeze Frame Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 8 Reset counter: 251 Mileage: 152188 km Time Indication: 0 Date: 2015.07.12 Time: 19:47:52 Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Control Module Part Number: 4F0 910 852 HW: 4F0 905 852 B Component and/or Version: FBSAUDIC6 ELV H30 0180 Software Coding: 0000007 Work Shop Code: WSC 00328 935 83086 Additional Info: 4F0910131C FBSAUDIC6 EZS H43 0070 4F0910335 FBSAUDIC6 KSG H25 0070 VCID: E3C12BBF224E19B 1 Fault Found 01049 - Supply Voltage Term 50 006 - Short to Plus Freeze Frame Fault Status: 01100110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 154420 km Time Indication: 0 Date: 2015.08.02 Time: 08:17:03 Address 19: CAN Gateway Labels: 4F0-910-468.lbl Control Module Part Number: 4F0 910 468 A HW: 4F0 907 468 B Component and/or Version: Software Coding: ECFE73C41B1104 Work Shop Code: WSC 02325 785 00200 VCID: 2759FFAF96F635B 3 Faults Found 00470 - Combination comfort Databus in Single Wire 011 - Open Circuit Freeze Frame Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 32 Mileage: 142007 km Time Indication: 0 Date: 2015.02.27 Time: 13:41:56 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 32 Mileage: 142007 km Time Indication: 0 Date: 2015.02.27 Time: 13:42:55 02076 - Media Player Position 1 (R118) 004 - No Signal/Communication - Intermittent Freeze Frame Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 8 Mileage: 154395 km Time Indication: 0 Date: 2015.07.31 Time: 15:24:38
Стирал, проехал. Вот эти остались Спойлер Address 01: Engine Labels: 06C-909-559-ASN.lbl Control Module Part Number: 4F0 910 559 A HW: 4F0 907 559 Component and/or Version: 3.0L V6/5V G 0030 Software Coding: 0026582 Work Shop Code: WSC 02325 785 00200 VCID: 285BFC939BE83A3 1 Fault Found 16955 - Brake Switch (F) P0571 - 008 - Implausible Signal - Intermittent Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Control Module Part Number: 4F0 910 732 S HW: 4E0 035 729 Component and/or Version: Interfacebox H43 5150 Software Coding: 0000001 Work Shop Code: WSC 02335 785 00200 Additional Info: 4F0910609 Bedienteil MMIC6H07 0870 Additional Info: Geraet 00200 VCID: 33611BFF522E49B Fault Codes have been Erased 1 Fault Found 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 227 Mileage: 154420 km Time Indication: 0 Date: 2015.08.02 Time: 08:03:03 Address 02: Auto Trans Labels: 01J-927-156.lbl Control Module Part Number: 4F1 910 155 HW: 01J 927 156 HT Component and/or Version: V30 01J 3.0l 5V RdW 0020 Software Coding: 0000001 Work Shop Code: WSC 02327 785 00200 VCID: E0CB24B33358023 1 Fault Found 18201 - Transmission Output Speed Sensor 2 (G196) P1793 - 000 - No Signal Freeze Frame Fault Status: 01110000 Fault Priority: 0 Fault Frequency: 254 Reset counter: 40 Mileage: 142007 km Time Indication: 0 Date: 2015.02.27 Time: 13:45:07 Freeze Frame RPM: 1376 /min RPM: 100 /min (no units): 3.0 Torque: 142.0 Nm Temperature: 63.0°C T.B. Angle: 24.0° Bin. Bits: 1010 0 0 Address 08: Auto HVAC Labels: 4F0-910-043.lbl Control Module Part Number: 4F0 910 043 HW: 4F1 820 043 J Component and/or Version: KLIMABETAETIGUNGH11 0100 Software Coding: 0008198 Work Shop Code: WSC 02327 785 00200 VCID: DBB1135F1A3E21B 1 Fault Found 00256 - A/C Pressure/Temperature Sensor (G395) 001 - Upper Limit Exceeded - Intermittent Freeze Frame Fault Status: 00100001 Fault Priority: 3 Fault Frequency: 38 Reset counter: 11 Mileage: 149631 km Time Indication: 0 Date: 2015.06.23 Time: 13:18:37 Address 46: Central Conv. Labels: 4F0-910-289.lbl Control Module Part Number: 4F0 910 289 E HW: 4F0 907 289 E Component and/or Version: Komfortgeraet H14 0090 Software Coding: 0394481 Work Shop Code: WSC 02335 785 00200 Additional Info: 1K0951605A LIN BACKUP HORN H01 0101 4F0910177 Innenraumueberw.H01 0010 VCID: 2C5300838F10163 Fault Codes have been Erased 1 Fault Found 01134 - Alarm Horn (H12) 012 - Electrical Fault in Circuit Freeze Frame Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 227 Mileage: 135804 km Time Indication: 0 Date: 2014.12.02 Time: 10:13:06 Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Control Module Part Number: 4F0 910 852 HW: 4F0 905 852 B Component and/or Version: FBSAUDIC6 ELV H30 0180 Software Coding: 0000007 Work Shop Code: WSC 00328 935 83086 Additional Info: 4F0910131C FBSAUDIC6 EZS H43 0070 4F0910335 FBSAUDIC6 KSG H25 0070 VCID: E3C12BBF224E19B 2 Faults Found Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Control Module Part Number: 4F0 910 852 HW: 4F0 905 852 B Component and/or Version: FBSAUDIC6 ELV H30 0180 Software Coding: 0000007 Work Shop Code: WSC 00328 935 83086 Additional Info: 4F0910131C FBSAUDIC6 EZS H43 0070 4F0910335 FBSAUDIC6 KSG H25 0070 VCID: E3C12BBF224E19B 1 Fault Found 01049 - Supply Voltage Term 50 006 - Short to Plus Freeze Frame Fault Status: 01100110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 227 Mileage: 154420 km Time Indication: 0 Date: 2015.08.02 Time: 08:17:03
лягушка, скорей всего под замену; датчик выходного вала АКПП - похоже проблема с проводкой; G395 - проверять герметичность и наличие хладагента PS 00003 ошибка с какого блока??
