Машина начало подергивать на холостых, сделал проверку выдал такие вот ошибки: Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E04A261031 Mileage: 158720km/98624miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 079-910-560-BBK.lbl Part No SW: 8E0 910 560 F HW: 8E0 907 560 Component: 4.2L V8/5V 0020 Coding: 0008771 Shop #: WSC 00002 401 56451 VCID: 2855E98198E83B4 3 Faults Found: 16440 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit P0056 - 004 - Malfunction / Open Circuit - MIL ON 17548 - Oxygen (Lambda) Sensor; B2 S2 P1140 - 004 - Internal Resistance too High - MIL ON 16825 - EVAP Emission Control Sys P0441 - 002 - Incorrect Flow - Intermittent - MIL ON Readiness: 0010 1001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 8E0 910 156 HW: 09L 927 156 Component: AG6 09L 4.2L5V RdW 0040 Revision: 00000001 Serial number: 0060162 Coding: 0000001 Shop #: WSC 00001 401 61945 VCID: E3CF3EAD214E18C 1 Fault Found: 18275 - Powertrain Data Bus P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent Freeze Frame: RPM: 768 /min RPM: 736 /min RPM: 0 /min (no units): 30.0 (no units): 22.0 Temperature: 97.0°C T.B. Angle: 0.0° Voltage: 13.04 V ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Q Component: ABS/ESP allrad 4533 Coding: 04597 Shop #: WSC 00401 VCID: 366937F9125C5D4 2 Faults Found: 00526 - Brake Light Switch-F 36-10 - Open Circuit - Intermittent 01200 - ABS Valves Supply Voltage 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AH Component: A4 Klimaautomat 1323 Coding: 00000 Shop #: WSC 63351 VCID: 67D7AABD0576F4C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul RDW 0517 Coding: 01011 Shop #: WSC 63351 VCID: 356B30F50F5A56C 1 Fault Found: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 J Component: Airbag 8.4EP 1002 Coding: 0010602 Shop #: WSC 63351 000 00000 VCID: 3E792FD96A6C954 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenksбulenmodul 0611 Coding: 01111 Shop #: WSC 63351 VCID: 3E792FD93A6C954 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 931 A Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 01101 Shop #: WSC 00382 VCID: 2649E7B9C2FC2D4 WAUZZZ8E04A261031 AUZ6Z0D0059036 No fault code found. ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0704 Coding: 00001 Shop #: WSC 00000 VCID: EBDF568D999E50C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BC Component: Komfortgerбt T3B 1412 Coding: 06762 Shop #: WSC 00330 VCID: 73EFCEED41AE08C Subsystem 1 - Part No: 8E1959801G Component: Tхrsteuer.FS BRM 0706 Subsystem 2 - Part No: 8E1959802E Component: Tхrsteuer.BF BRM 0204 Subsystem 3 - Part No: 8E0959801A Component: Tхrsteuer.HL BRM 0204 Subsystem 4 - Part No: 8E0959802A Component: Tхrsteuer.HR BRM 0204 8 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01331 - Door Control Module; Driver Side (J386) 80-00 - Single-Wire Operation 00932 - Electric Window Motor; Drivers Side (V147) 58-10 - Can't Lock - Intermittent 01559 - Drivers Door 57-10 - Electric Circuit Failure - Intermittent 01811 - Supply Voltage for Door Controller; Drivers Side (J386) 37-10 - Faulty - Intermittent ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00060 Shop #: WSC 63351 VCID: 040D9D3114003F4 1 Fault Found: 00776 - Level Control System Sensor; Left Front (G78) 31-00 - Open or Short to Ground ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 195 M Component: symphony II NP2 0410 Coding: 01200 Shop #: WSC 65792 VCID: 316304E5FB327AC No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 8Z0-919-283.lbl Part No: 8Z0 919 283 A Component: Parkingsyst. A4 RDW D09 Coding: 01104 Shop #: WSC 63351 VCID: 438F5E2D518EF8C Подскажите с чего начать ремонт????
16825 Система вентиляции топливного бака: снижение пропускной способности смотри клапан вентиляции для начала 17548 Подогреваемый кислородный датчик 2, банк 2 - высокое сопротивление нагревателя смотри вторую лямду походу пьесы под замену
1.Задний лямбда зонд по водительской стороне вышел из строя. Менять его особого смысла нет, лучше если время пришло удалить каты и отключить лямбды. 2.Датчик положения кузова для ксеноновых фар тоже накрылся. 3.Накрывается тормозная лягушка
Большое спасибо за ответ. Решено заменить лямбду и тормозную лягушку. Подскажите где можно посмотреть каталожные номера запчастей???
Поменял лягушку, ошибки по АБС и ЕСП исчезли. Теперь осталось поменять лямбду. Стоя в пробке за бортом было + 27, начала расти температура, стрелка выросла до середины (90 и след. риской), что это может быть??? После включении печки на полную температура встала на 90 граб.
В этот момент, по всей видимости, еще работал кондиционер. Зимой скорее всего температура не поднималась до рабочей - у меня было так. Термостат приказал долго жить.
1.Нужно рассоединить радиаторы и промыть их от шапки пыли между ними 2.Смотри датчик включения вентиляторов работает ли на двух скоростях. 3.Визуально осмотри крутятся оба вентилятора или нет.
Нужно ли мыть всю систему??? Радиаторы только продуть или отмачивать (начитался разных статей ) Датчик решил поменять (Был случай ехал про трассе температура резко упала до 70 град потом поднялась и так раза три за 600 км), термостат тоже на замену. Подскажите какие фирмы производителей выбрать??? или только оригинал???
попробуй для начала поменять датчик температуры который показывает температуру на панель.бампер снимай раделяй радиаторы и вымывай их и не забудь промыть два боковых радиатора под фарами
