Помогите с ошибками
Тема в разделе "Allroad 4B С5", создана пользователем DOS, 23 апр 2010.
  1. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Клубни, помогите пожалуйста с расшифровкой ошибок.
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 4Z7 907 551 K
    Component: 2.7l V6/5VT G 0001
    Coding: 06752
    Shop #: WSC 02325
    WAUYP64B31N088539 AUZ7Z0Y1634231
    6 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - - Intermittent
    16688 - Cylinder 4: Misfire Detected
    P0304 - 35-10 - - - Intermittent
    16689 - Cylinder 5: Misfire Detected
    P0305 - 35-10 - - - Intermittent
    16690 - Cylinder 6: Misfire Detected
    P0306 - 35-10 - - - Intermittent
    16685 - Cylinder 1: Misfire Detected
    P0301 - 35-10 - - - Intermittent
    16686 - Cylinder 2: Misfire Detected
    P0302 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 06: Seat Mem. Pass Labels: None
    Part No: 4B0 959 760 C
    Component: Sitzmemory R1 BF 0102
    Coding: 00003
    Shop #: WSC 00000
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    07-10 - Signal too Low - Intermittent
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Part No: 4Z7 907 553 B
    Component: - 2C1A1 X031
    Coding: 25500
    Shop #: WSC 11111
    2 Faults Found:
    01400 - Suspension Level Control
    11-00 - Control Limit Not Reached
    01772 - Signal from Level Control Pressure Sensor (G291)
    27-10 - Implausible Signal - Intermittent
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 J
    Component: Central Lock/Alarm D33
    Coding: 15885
    Shop #: WSC 02325
    5 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01559 - Drivers Door
    58-00 - Can't Lock
    Address 36: Seat Mem. Drvr Labels: None
    Part No: 4B0 959 760 B
    Component: Sitzmemory R1 F 0101
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
  2. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Как я понимаю - в первом разделе ошибки по пропускам зажигания... проблема с троением и тряской движка была прошлым летом, после замены клап крышек, свечей и катушек двиг стал работать ровно и тихо, откуда тогда у этой ошибки могут ноги расти?
    Ещё вопрос не по теме, дабы не плодить темы - вчера появился странный пружинный звук при торможении, особенно на неровной дороге. происходит это оч редко, но крайне неприятно, и при чём эффективность торможения в такие моменты очень падает. По АБС ошибок нет, поэтому выкладывать и не стал... Было у кого нечто похожее?
  3. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    По 30-му терминалу ошибка - либо дохлый аккум, либо предстоит серьезная работа с проводкой, скорее 1-е. По пневме ошибка по датчику давления - замена компрессора. По центральному замку ошибки - забей:nod:. Насчет пропусков воспламенения - ошибки стирал после замены свечей, катушек и т.д.?
  4. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Нет, Дань, ошибки не стирал... Понял, сотру... По пневме ошибка эта которая G291?
    А что такое 06 и 36 адрес? Вроде инфа перекликается по ним....
  5. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    А что понимается под серьёзной работой с проводкой? Какие симптомы? И ещё, дань, ошибки по датчикам ОГ сразу вылазят обычно?
  6. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    Это память настроек седла пассажира и водителя соответственно. Кстати, если ты никогда ошибки не стирал, то сперва потри всё и через некоторое время опять почитай - глядишь и проблем меньше будет, а что нарисуется по новой - то уже твое.
  7. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Ок, завтра сделаю, спасибо:thumbup:
  8. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    По проводке тоже пока не парься - проверь боеспособность аккумулятора нагрузочной вилкой, если тест не пройдет - поменяй и ошибка исчезнет.
  9. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Ну да, акку я после зимы заряжал практически с нуля, дохленький он уже...
  10. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    А про ОГ что скажешь, пост №5?
  11. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    А ты их пропаивал? Я про датчики ОГ.
  12. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Нет, я по этому и спрашиваю, стоит пропаивать или нет?
  13. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    Пока ошибки нет, лезть туда не стоит.
  14. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Ок. В целом то я так понимаю, за исключением компрессора, у меня всё неплохо?
  15. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    Ага:thumbup:
  16. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Ну спасиб))) успокоил)))
  17. igorjek
    igorjek Живу я здесь
    18 авг 2007
    3.115
    AUDI ALLROAD C5
    с мерседеса подходит
  18. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    Я в курсе)
  19. DOS
    DOS Старожил
    24 июн 2009
    7.058
    VQ35DE
    To Daneli короче, Дань, стёр сёдня ошибки по двигу, покатался с ноутом часок, потом ещё раз прочитал - нового ничего не появилось...
  20. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    Дак ить это - принцип простой: отловил ошибки - сделал всё, чтоб от них избавиться - стёр ошибки - отжёг по трассе - прочёл опять. Ежели опять не появились, значит, получилось:nod:. Значит, по двигу у тебя были ооочень древние пропуски воспламенения прописаны.
