покупаем машинку VW TRANSPORTER помогите пробить комплектацию и что там ещё можно по VIN. заранее спасибо. VIN: WV1ZZZ70Z1X031822??????
Ответ: помогите с VIN Держи! VIN Number WV1ZZZ70Z1X031822; Sales type 7DA1H2; Exterior color T7 Roof color T7 Interior trim code BX; Engine code & No. ABL248837; Transmission code DQL; Date of production 10.08.2000; Model year 2001; Расшифровка кодов комплектации Код Опция 9Q0 without multi-function indicator/ on-board computer 4PA without seat belts in first row of seats 8T0 without cruise control system (CCS) 8E0 without interference suppression S2D control no. for in-plant PL-5/6 control 6K0 without lock washers for padlock 3SH seat in cab, right 1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C 9QA without identification light preparation 9J0 without supertone system and tone sequence control L0L left-hand drive vehicle 8M0 w/o rear window wiper and washer system 5FF console under dashboard, center 3E0 w/o stacking panel in load compartment 8TC rear fog light for driving on the right 7A0 without CD changer/CD player G0C 5-speed manual transmission 1Z3 double initial standard fuel filling 5V0 without hinges for side and tail gates 1K2 hydraulic clutch actuation 5G0 without curtains 5NC standard tailgate stay 3LN unpainted door trim panel 3EA without roof insert in cab (closed) T0G components for base engine, unit 028.F 2WA without additional tires B0A component parts set without country-specific design requirement 7AA electronic vehicle immobilization device 2A0 without delivery equipment 6L0 without C-rails 3TH seat in cab, left 1S1 tool kit and jack 0FM Poland manufacturing sequence 1D0 without towing attachment K4A delivery van 5GA without pickup bodywork/tarpaulin 0G1 gearshift lever 0NB nameplate set in base trim 4R0 mechanical window regulator SC0 payload 700kg 4JA w/o side window aperture in load comp. rear right 9CC two standard interior lights in passenger/load compartment 8FA without second battery 7Q0 without navigation device H5T tires 195/70 R 15 C 104/102R 7B0 without socket 2AA without compressor or preparation respectively AC0 short frame forestructure 1L0 standard air cleaner 1SA without additional engine guard 6LD fresh air unit with center outlet and recirculation door, without load/ passenger compartment ventilation 4RA without seat belts second row of seats 0GD emissions concept EU 2 (MVEG 2) 9KA without identification lights 4CB cab side window in clear glass 3UA without seats 8G0 without antenna cable for radio system 7QA without CD ROM 7J0 without additional ventilation system J0L battery 340 A (70 Ah) 1E0 without activated charcoal canister M6Z 4-cylinder diesel engine 1.9 L/50 kW ecodiesel f. com. veh., turboch. a. EGR base engine is T0G 5P0 w/o mounting fixture for oxygen bottle 5HA without pickup bodywork/cargo area E0A no special edition 4S0 without armrests for front seats 8GD alternator 90A 2BA without hydraulic pump 6U0 without additional seals outside 1LP disc brakes, front 9T0 without heated washer nozzles 5AC rubber floor covering in cab 4SA without left vanity mirror 9LA without rotating emergency lights 4DA without side window aperture in load compartment, front left 3VA without seats in second row of seats in passenger compartment 2JB standard bumpers 1U0 without table 6N0 without mud flaps 6FA components without special surface appearance 5Q0 without door in load/passenger compartment left (closed side panel) 1ME steering wheel (hollow rim) 0AB front stabilizer 9M0 without auxiliary/parking heater 1EY special identification plate with weight data, but without general operating permit (ROW) 8WA without front fog light 4E3 without tailgate release lever inside 8HA without second alternator or preparation B31 type approval the Netherlands FM0 basic equipment variant 3W6 additional interior noise suppression 5Y0 w/o additional heating/air conditioning system in passenger compartment C09 operating permit, alteration 9 U0C instrument insert with tachometer clock and km/h speedometer 5BA without floor covering in passenger/loadcompartment 4M0 without cup holder 4EA without side window aperture in load compartment front right 4TB vanity mirror right 8X0 without headlight washer system 3P0 without bracket for first aid kit and warning triangle 3WA without bench seat 3HA without leather parts scope 8AA without radio C7X steel wheels 6J x 15 H2 load rating 810kg, offset 55 0Y1 standard climatic zones 1G2 steel spare wheel with original equipment tires 0J1 reduced payload 0BA without rear stabilizer 1NE wheel center cover 5R2 sliding door right in load/passenger compartment 9N0 without step illumination 4F0 mechanical locking system 8Q1 headlight-range adjustment 5K1 paint preservative (wax) 4UA without airbag 9NA without tachograph 4FA w/o side window aperture in load comp. rear left 4N2 standard dashboard 8Y0 single-tone horn 3Q0 without rear headrests 3B0 without additional child seat anchor 8BB halogen headlight for left-hand drive 1W0 without refrigerator/glove compartment cooling system 2E2 15-inch chassis 5CL roof interior trim in cab as comfort molded headlining, in load/passenger compartment with hardboard F0A no special purpose vehicle, standard equipment 5RQ outer right rear view mirror: convex 5S0 without tail and side gate(s) 5D0 without carrier frequency 4G0 w/o storage trays, first row of seats 9GA interior light with door pillar switches 8R0 without center high-mounted stop light 3J1 height-adjustable headrests for front seats 3QC 3-point seat belts, front 1P0 standard suspension 6AA without second heat exchanger 0CN vehicle class differentiation 7D0 0KA without stickers and badges 5DA side trim panel for basic equipment 0D1 cab doors 9W0 w/o car phone preparation/installation 4VA without seat belts in third row of seats 9H0 without roof turn signal lights N0A woven fabric seat covering 3R0 standard roof (plane) 8RA without speakers 8K0 without special low beam mode 3JA without roof insert in load and passenger compartment 3YC door pocket, front left 8CC speedometer sensor without seal (electronic speedometer sensor) 5SL outer left rear view mirror: non-spherical 1X0 front wheel drive 0ZN transmission ratio, high geared 6XA outer rear view mirrors: manually adjustable from outside A8B basic equipment 6B0 without tie-down eyes for load restraint 1AB power brake 5T0 without retaining cables for tailgate 9P0 without seat belt warning light 0SE labels/plates in Dutch 4H0 w/o child lock in passenger compartment 9HA without additional malfunction display 3Z0 without stowage box 4GS clear glass windshield, bonded 3CA without partition 3RC trunk lid with window aperture 2N1 standard anti-drum measures V0A tires w/o specification of tire brand 1B1 standard spare wheel bracket 5M0 without warning strip and films 5EA without different vehicle equipment 0E1 short wheelbase 4WA w/o storage trays, second row of seats 9AA manually controlled heating system 4A0 without seat heater 8L0 without antenna 4HD rear window clear glass, heated QG0 without service interval prolongation 2G0 without insert for the filling up of fuel 1Y0 without differential lock 1J0 without additional sound absorbing measures 1BA standard suspension/shock absorption 5U0 standard underseal
