Ребят помогите узнать полные данные авто Нигде не нашёл инфы как это сделать Вин: WAUZZZ8E62A139612 Приложил фотку что нужно
Вообще для этого есть (был) специальный раздел и тема 0CS Vehicle class differentiation 8E0 0F2 Fuel system for SI engine 0G1 Gearshift lever 0GG Emission standard EU4 0JE Weight category front axle weight range 5 0LW With special plates/labels/ safety certificates for Germany 0TD Floor mats in front and rear 0VC Information kit in German 0W1 Label for central electric German-speaking countries 0YH Weight range 8 installation control only, no requirement forecast 1BA Standard suspension/shock absorption 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C 1D2 Trailer hitch, removable and lockable 1EX Special identification plate for EC for M1 passenger vehicle 1G0 Without spare wheel 1KD Disk brakes in rear 1LZ Disk brakes in front 1N1 Power steering 1PA Standard wheel bolts 1SA Without additional front underbody guard 1T3 First aid kit with warning triangle 1VG Installation parts for four-cylinder engine 1W0 Without refrigerator/glove compartment cooling system 1WB Transmission shafts 100 mm in diameter 1X0 Front wheel drive 1YA Without transmission shafts f. rear axle 1Z0 Initial standard fuel filling 2G1 Insert for the filling up of unleaded fuel 2K1 Reinforced bumpers 2KR Labels/plates in English and German 2PG Steering wheel 2T0 Without 2-DIN 2V1 Dust and pollen filter 2WA Without additional tires 2Z1 Type sign at rear and "Quattro" nameplates respectively 3B0 Without additional child seat anchor 3C1 Static lap belt, center rear 3FA Without roof insert (standard roof) 3L3 Manual height adjustment for front seats 3NZ Unsplit rear seat bench unsplit, split folding backrest 3Q1 Rear head restraints 3S0 Without roof rails/roof load rack 3X0 Without load-through hatch 3Y0 Without roll-up sunshade 4A0 Without seat heater 4E0 Tailgate/trunk lid unlocking from outside 4GH Windshield in heat-insulating glass with sunshield 4K4 Radio remote controlled central locking 4KC Side and rear windows in heat-insulatingglass 4L2 Dimming breakaway interior rearview mirror 4N0 Standard dashboard 4P2 Rear floor panel module, type 3 4R5 Power windows with comfort operation andcircuit breaker, mechanical window regulators rear 4UE Airbag for driver and front passenger 4W0 Without cassette and CD storage unit 4X3 Side airbag in front, with curtain airbag 4ZE Black moldings 5C0 Without special body measures 5D1 Carrier frequency 433.92 MHz-434.42 Mhz 5K5 Transit coating film with additional transport protection measures 5MA Decorative inserts 5RU Right exterior mirror: convex (large viewing field) 5SL Left exterior mirror: aspherical 6E0 Without center armrest in front 6FB Body-colored exterior mirror housings 6M0 Without tie down straps/net/pocket 6PA Plastic hand brake lever handle 6Q1 Plastic gearshift knob/handle 6R1 Leatherette gearshift boot 6SS Luggage compartment floor covering 6U0 Without additional seals outside 6V1 Rear trim panel (ECE) 6W5 Front license plate carrier 6XC Exterior mirrors: power-adjustable 7A0 Without CD changer/CD player 7AA Electronic engine immobilizer 7B0 Without socket 7K0 Without direct tire pressure monitoring system 7M0 Plastic scuff plates in door apertures 7P0 Without lumbar support in seat backrests 7Q0 Without navigation device 7QA Without CD/DVD for navigation 7X0 Without park distance control 8GR Alternator 150 A 8JH Ellipsoidal headlamps for driving on the right 8K0 Without special headlamp activation 8N4 Windshield wiper intermittent control with potentiometer (four speeds) 8Q1 Headlight range adjustment 8T0 Without cruise control system (CCS) 8TC Rear fog lamp for driving on the right 8UC Radio "chorus" 8X0 Without headlamp washer system 8Z5 Not hot country 9AA Manually controlled heater 9M0 Without auxiliary heater/fuel-fired parking heater 9NX Without electronic logbook 9P0 Without seat belt reminder 9Q3 Multi-function display, without on-boardcomputer and check control 9T0 Without heated washer nozzles 9VD Speaker (active) 9W0 Without car phone preparation/ installation A00 No self-collection A8S Standard equipment B01 Type approval country Germany B0A Component parts set without country-specific building regulation C03 Operating permit, alteration CR7 Steel wheels 6.5J x 15 E0A No special edition F0A No special purpose vehicle, standard equipment FA0 Control of series production FC0 Without customized installation FM0 Basic equipment variant FQ0 Production wheels G0C 5-speed manual transmission H7F Tires 195/65 R15 91H J1L Battery 280 A (60 Ah) K8B Notchback L0L Left-hand drive MW6 4-cylinder SI engine 1.6 l/75 kW with MPI base engine is T0B/T53/TC3/TL2 N3A Seat trim covers in fabric NT0 Transit coating (type 1) PAA Q1A Standard seats in front QE0 Without storage compartment package/box QH0 Without voice control QQ0 Without add. lights (interior lighting) QV0 Without TV reception/digital radio reception T0B 4-cylinder SI engine 1.6 l unit 06B.2 (aluminum) U1A Instrument cluster with km/h speedometer, clock, tachometer, and trip odometer V0A Tires without specification of tire brand VC0 Without remote-controlled garage door opener VR0 Without impact protection measures YMH Дата производства 23.10.2001 Модельный год 2002 VIN WAUZZZ8E62A139612 Код двигателя ALZ Код КПП ENL Код оснащения LD Цвет кузова P1 Цвет крыши P1
