Посмотрите ошибки по Аллроад - больной будет жить?
Тема в разделе "Allroad 4B С5", создана пользователем repz, 6 авг 2010.
  1. repz
    repz Участник форума
    11 сен 2005
    358
    A4 1.9TDI(AHU)98г.
    уважаемые - вот перечень ошибок
    кто нибудь может сказать чем это грозит ?
    Thursday,05,August,2010,20:14:37:13314
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
    76 77
    VIN: WAUZZZ4BZ1N****** Mileage: 187760km/116668miles
    Address 01: Engine Labels: 059-907-401-AKE.lbl
    Part No: 4Z7 907 401 A
    Component: 2.5l/4VTEDC G200AG D00
    Coding: 01016
    Shop #: WSC 00000
    Part No: 00010059
    Component: 130 106EC150_1.R75908179084
    WAUZZZ4BZ1N****** AUZ7Z0Y1499500
    2 Faults Found:
    00575 - Intake Manifold Pressure
    08-00 - Control Limit Surpassed
    18062 - Please check DTC Memory of Instrument Cluster
    P1654 - 35-00 - -
    Readiness: N/A
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4Z7 927 156 D
    Component: AG5 01V 2.5lTDI RdW 1010
    Coding: 00001
    Shop #: WSC 00000
    2 Faults Found:
    18169 - Shift Lock Solenoid (N110): Short to Ground
    P1761 - 35-00 - -
    18258 - Powertrain Data Bus: Missing Message from ECU
    P1850 - 35-10 - - - Intermittent
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 4Z7 907 389
    Component: ABS/ESP allrad D47
    Coding: 06357
    Shop #: WSC 00012
    No fault code found.
    Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
    Part No: 4B0 820 043 L
    Component: A6-Klimavollautomat D64
    Coding: 00063
    Shop #: WSC 02325
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    29-00 - Short to Ground
    Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
    Part No: 4Z7 959 655 B
    Component: Airbag Front+Kopf 1000
    Coding: 00406
    Shop #: WSC 02325
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4Z7 920 930 C
    Component: C5-KOMBIINSTR. VDO D12
    Coding: 00160
    Shop #: WSC 00001
    WAUZZZ4BZ1N023356 AUZ7Z0Y1499500
    1 Fault Found:
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Part No: 4Z7 907 553 G
    Component: - 2C1A1 D052
    Coding: 25500
    Shop #: WSC 00001
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 D
    Component: Zentralverriegelung D35
    Coding: 06721
    Shop #: WSC 23582
    6 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    00955 - Key 1
    09-10 - Adaptation Limit Surpassed - Intermittent
    01559 - Drivers Door
    58-10 - Can't Lock - Intermittent
    01562 - Right Rear Door
    59-10 - Can't Unlock - Intermittent
    60-10 - Won't Safe - Intermittent
    61-10 - Won't De-Safe - Intermittent
    Address 37: Navigation Labels: Redir Fail!
    Part No: 4B0 035 192 F
    Component: Navigation BNO 0102
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D03
    Coding: 00030
    Shop #: WSC 02325
    2 Faults Found:
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    30-00 - Open or Short to Plus
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
    Address 56: Radio Labels: Redir Fail!
    Component: Radio BNO 0001
    Coding: 00117
    Shop #: WSC 23582
    1 Fault Found:
    00852 - Loudspeaker(s); Front
    36-00 - Open Circuit
    Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
    Part No: 8E0 919 283
    Component: Parkingsyst. A6 RDW D04
    Coding: 01186
    Shop #: WSC 02325
    2 Faults Found:
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
    31-00 - Open or Short to Ground
    01626 - Sensor for Parking-Aid; Front Right (G252)
    End ---------------------------------------------------------------------
    Address 01: DTCs cleared
  2. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    в принципе ничего такого, что мешало бы машине ездить - надо все стереть и посмотреть что останется
  3. repz
    11 сен 2005
    358
    A4 1.9TDI(AHU)98г.
    спасибо за быстрый ответ - ошибки стирал - потом ездил 20 км до 120 разгонял - и они снова появились
    суть в том что ее VIN код специ с данного форума цитирую "не можем найти в базе"
    это плохо ???
    ну и еще - машина жутко тупит на разгоне и при кикдауне идет удар сильный
    кстати - при каждом торможении сзади идет звук стравливаемого воздуха
    это все нормально ?
    PS я эту машину собираюсь забирать завтра
  4. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    про вин - иди лучше не к спецам, а к официалам.
    тупит - вполне возможно по ошибке в моторе.
    ударов быть не должно в АКПП
  5. daneli
    daneli мастер
    4 мар 2008
    7.824
    2х2,7бт на пневме
    Загляни хоть в масляную горловину и оцени износ видимых кулачков распредвала.
  6. repz
    11 сен 2005
    358
    A4 1.9TDI(AHU)98г.
    в горловину глядел - выроботка есть - но не большая
    хотя там всего полтора кулачка видно :D
    может от износа ГРМ мошьность упасть ?
  7. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    если ГРМ изношен - то также изношены и все остальные детали в моторе - откуда у него мощность?
    а вообще ошибок многовато и все разношерстные какие-то... думаю придется вложиться потом и поработать - я б не стал себе такой брать.
    как минимум - удары в КПП - беги от нее...
  8. repz
    11 сен 2005
    358
    A4 1.9TDI(AHU)98г.
    я смотрел несколько вариантов - это лучший из них
    вложится это в любом случае прийдется - смотри машину в профиле - брал дрова - но немного терпения и она стала летать как самолет - и до сих пор летает (меняю только потому что хочется места побольше в салоне - и полный привод)
    мотор в любом случае на полную дефектовку с заменой ремней и прочего - а там видно будет что с головами
    коробка при нормальном режиме не дергается и переключает незаметно,
    при кикдауне какойто удар идет - но я блин на автомате в жизни ездил всего 2 раза - так что может я что то не понимаю
    по поводу пшиканья сзади при торможении не чего не скажите ?
  9. Dr.KiLLeR
    Dr.KiLLeR Завсегдатай
    30 авг 2004
    694
    Allroad А4B5-B7-B8
    #9 Dr.KiLLeR, 6 авг 2010
    да ну ее в пень, практически по всем блокам ошибки... даже в радио ошибки есть )))
    собиралась похоже не коленке
  10. Dzuba
    Dzuba Старожил
    8 дек 2008
    13.393
    ALLROAD 2.7Т мкпп
    Я так понял что машина дизель. Коробка может давать толчок при кик дауне, но не всегда. На счет пшиканья, то уже обсуждалось, что при каждом торможении система сравливает воздух, а потом опять подкачивает. Почему это сделали ваговцы-я не знаю, но думаю им лучше знать.
  11. Dzuba
    Dzuba Старожил
    8 дек 2008
    13.393
    ALLROAD 2.7Т мкпп
    Не ну если человек ее берет за 400-430руб, то нормально, ну а если за 600, то конечно ну ее в пень.
    Автор, а она на авто ру висит? Нам хоть глянуть.
  12. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    это парни владельцы тебе расскажут - я не знаю - могу только предположить что при торможении в задние баллоны воздух засасывает :)
  13. repz
    11 сен 2005
    358
    A4 1.9TDI(AHU)98г.
    беру за 450 тыс рублей
    + зимняя резина
    + все старые баллоны
    но как я понимаю ремонт тоже нужен будет
    двигло
    + 15 тыс замена ГРМ + помпы
    + 40 тыс замена валов толкателей
    + покраска пару деталей
    я по ценам верно написал (при условии что все делать буду сам - кроме как лезть в автомат) ?
  14. Dr.KiLLeR
    30 авг 2004
    694
    Allroad А4B5-B7-B8
    у тебя корбасу висит ошибка по связи с мозгами и соленоид на замену просится
    все траты что посчитал умножай в 3 раза...
  15. Dzuba
    Dzuba Старожил
    8 дек 2008
    13.393
    ALLROAD 2.7Т мкпп
    Замена валов явно не 40 тыс будет стоить. Скидывай еще хотя бы 30 тыс. Ремонту явно на 100 штук точно будет.
  16. Pafnut76
    Pafnut76 Новичок
    11 апр 2010
    43
    Allroad 2.5 2002г.
    на своей менял 1.5 года назад ГРМ+помпа+демпфер+ролики и натежители (оригинал по закупочным ценам) = 25-27 тыс. без работы
    в марте сего года: 2 распреда+все гидрики+все рокера+все распылители+сальники+прокладки = около 61тыс. без работа (что-то оригинал что-то нет по закупочным ценам)
  17. repz
    11 сен 2005
    358
    A4 1.9TDI(AHU)98г.
    после ремонтов изменилось ли поведение машины ?
  18. pau
    pau Живу я здесь
    2 фев 2006
    3.795
    А4 TDI
    Ничем. Хотя, если продолжать так ездить, для коробки не гуд.
    По мотору смотреть 75-й и геометрию турбины.
  19. repz
    11 сен 2005
    358
    A4 1.9TDI(AHU)98г.
    простите - смотреть 75-й это что означает ?
  20. pau
    pau Живу я здесь
    2 фев 2006
    3.795
    А4 TDI
    Вот здесь почитай: http://audi-club.ru/forum/showthread.php?t=67379
    В сотый раз повторять неохота...
