Пожалуйста сделайте расшифровку по ВИН
Тема в разделе "Allroad 4B С5", создана пользователем lexus625, 27 мар 2010.
  1. lexus625
    lexus625 Завсегдатай
    24 мар 2010
    735
    Audi Allroad A4
    Пожалуйста сделайте расшифровку по ВИН WAUYP64B31N139585.
    Большое спаисбо
  2. Немон
    Немон Участник форума
    23 ноя 2009
    218
    Audi 80 b4 2,0E AB
    VIN: WAUYP64B31N139585
    Model: Audi A6 Allroad qu. 01>
    Сборка: Америка
    Код страны: X9A
    Дата выпуска: 06/04/2001
    Наружн.цв.: 4A
    Внутр.цв.: HA
    Цв.Крыши: 7F
    Двигатель: APB 43778 (Цил.:6 Объем:2.70л Мощность:187кВт)
  3. Немон
    23 ноя 2009
    218
    Audi 80 b4 2,0E AB
    0DS installation differentiation for build status of vehicle class 4B0 (AUDI) vehicle class differentiation units/platform components
    0F2 fuel system for carburetor gasoline engine fuel systems
    0G7 Tiptronic transmission types/gearshift mechanisms
    0GL emissions concept TLEV emissions concept
    0JZ without determination of weight categoryfor front axle weight category front axle
    0L2 electric throttle actuation throttle actuation
    0LB special plates/stickers/ safety certificates for USA safety certificate
    0N6 rear axle with reduced tread rear axle
    0SS labels/plates in English and French special labels/plates
    0TD front and rear floor mats floor mats
    0VM information kit in American English owner's manuals
    0W2 label for central electric English-speaking countries label for central electric
    0YZ without determination of weight categoryfor rear axle weight category rear axle
    1AT electronic stabilization program (ESP) braking systems
    1BY 4-corner air suspension for rough-road design shock absorption/suspension, chassis
    1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C antifreeze
    1D0 without towing attachment towing attachment
    1E4 activated charcoal canister acc. to ORVRand siphoning device for filling up activated carbon canister
    1EP special identification plate (USA) identification plates
    1G8 breakdown set spare wheel
    1KD disc brakes, rear brake type, rear
    1LX disc brakes, front brake type, front
    1N3 speed-related variable steering assist (Servotronic) steering
    1PA standard wheel bolts lockable wheel bolts
    1SE additional engine guard (body-dependent) engine guard
    1T3 First aid kit with warning triangle First aid kit / warning triangle
    1VH installation parts for six-cylinder engine installation parts for engine (engine mount system)
    1WD transmission shaft for tripod joints transmission shafts
    1X1 four wheel drive drive layout
    1YD transmission shafts for rear axle diameter 108 transmission shafts, rear axle
    1Z5 increase in initial standard fuel filling fuel quantity for initial filling
    2A4 delivery equipment for shipment (transitcoating) with thick seat cover delivery equipment
    2B5 additional exterior noise suppression exterior noise suppression measures
    2C5 axial and vertical adjustable steering column steering column systems
    2G1 insert for the filling up of unleaded fuel insert for the filling up of unleaded fuel/fuel type
    2K9 reinforced bumpers bumper systems
    2T1 double-sized standard (DIN) double-sized standard slot (DIN)
    2WA without additional tires additional tires (winter tires)
    2Z1 type sign at rear and "Quattro" nameplates respectively type sign
    2ZD heated leather trimmed multi-function steering wheel with Tiptronic steering wheels
    3B2 child seat anchor according to Australian requirements additional child seat anchors
    3C7 3-point seat belt for center rear seat center rear seat belts
    3CB removable net partition partition
    3FE electric slide/tilt sunroof with sun screen/sunblind roof insert/convertible top
    3GD plane rear cargo area rear cargo area
    3HA without leather parts scope leather parts scope
    3NZ rear seat bench unsplit, backrest split folding rear seats
    3PN electric seat adjustment for both front seats with memory system seat adjustment
    3Q6 three rear headrests rear headrests
    3S1 bright roof rails roof rails/roof load rack
    3V0 without child bench seat child bench seat
    3X1 load-through provision with ski bag ski bag
    3Y1 roll-up sun screen for rear window roll-up sun screen for rear and side windows
    4A4 seat heater for front and rear seats separately controlled seat heater
    4E2 tailgate/trunk lid release from inside (electrically) lock operation for tailgate/trunk lid
    4GP windshield tinted with sun band and viewing window for vehicle identification number windshield glass type
    4K2 radio remote controlled central locking (safety radio remote control) door and lid locking system
    4KC side and rear windows tinted side and rear windows
    4L6 breakaway inside rear view mirror automatically dimming breakaway inside rearview mirror
    4N0 standard dashboard dashboard
    4UB airbag for NAR air bag
    4W0 without cassette and CD storage unit cassette and CD storage unit
    4X3 side airbag front with curtain airbag side airbag
    4ZB bright moldings moldings
    5A5 trunk lining, with stowage trays luggage compartment lining
    5C3 body measures for increased safety requirements body measures
    5D2 carrier frequency 315 MHz carrier frequency for radio remote control
    5E4 sill top with door cover sill top/sill cover
    5K5 transit protective film (instead of paint preservative) paint preservative/transit coating
    5RW outer right rear view mirror: convex, USlarge viewing field outer right rear view mirror
    5SG outer left rear view mirror: flat outer left rear view mirror
    5TS decorative burr walnut inserts, natural, high-gloss inserts
    6E3 center armrest front center armrest
    6FB body-colored outer rear view mirror housings components with special surface appearance
    6M2 load safety net tie down straps/net/pocket
    6PC leatherette hand brake lever handle hand brake lever handle
    6Q3 wooden gearshift knob/handle gearshift knob/handle
    6R0 selector lever cover gearshift boot/cover
    6SS luggage compartment floor covering luggage compartment floor covering
    6U7 additional dust protection measures additional dust seals
    6V2 rear trim panel rear trim panel
    6W3 license plate bracket front (small, NAR) front license plate bracket
    6XL outer rear view mirrors: powered, heatedelectrically foldable, automatically dimming, with memory function outer rear view mirrors setting
    7A1 CD changer preparation CD changer/CD player
    7CA without label for radio remote control Label for radio remote control
    7E0 w/o heat accumulator/auxiliary heating heat accumulator system/additional heater
    7K0 without tire pressure warning light tyre pressure monitoring
    7M3 scuff plates in door apertures scuff plates
    7P1 power adjustable lumbar support in frontseats lumbar support
    7Q9 navigation system navigation device
    7QA without CD ROM CD ROM / DVD
    7X1 Park distance control park distance control
    8GU alternator 140A generators
    8JD headlight with gas discharge lamp for driving on the right (US design) headlight
    8K0 without special low beam mode low beam mode
    8KB catalytic converter warning light catalytic converter control
    8N4 windshield wiper intermittent control with potentiometer (four speeds) windshield wiper intermittent control
    8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving) headlight-range adjustment
    8RY speakers with BOSE sound loudspeaker installation
    8T1 cruise control system (CCS) cruise control
    8TE rear fog light for USA rear fog light
    8WS front fog lights front fog light/additional headlight
    8X1 headlight washer system headlights washer/wiper system
    8YN radio "symphony" for USA radios
    8Z6 engine cooling system, type 2 engine cooling system
    9AK "Climatronic" with impact pressure control free of cfc heating and air conditioning system
    9B0 without telepay device telepay device
    9M0 without auxiliary/parking heater auxiliary heating
    9NX without electronic logbook tachograph/logbook
    9P1 seat belt warning light, electric contact in buckle seat belt check
    9Q2 multi-function indicator/on-board computer with check control multi-function indicator/trip computer
    9V7 electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control anti-theft protection system
    9W5 car phone preparation telephone/telematics
    A00 no self-collection self-collection / special control
    A8U executive US equipment equipment levels
    B0A component parts set without country-specific design requirement component part sets with country-specific design requirements
    B34 legal requirements USA type approval countries/countries with special requirements
    C00 operating permit, initial registration general operating permit, alterations
    CF6 cast alloy wheels 7 1/2J x 17 5-arm double-spoke style, offset 25 wheels
    E0A no special edition special editions
    F0A no special purpose vehicle, standard equipment vehicle specifications
    FA0 control of standard production handling standard production and pre-production series
    FC0 without customized installation customized installation
    G0Q five-speed automatic transmission for four-wheel drive vehicle transmission specifications
    H3H all-weather tires 225/55 R 17 H allroad tires
    J1G battery 450 A (92 Ah) batteries
    K8X Station Wagon "allroad" body style
    L0L left-hand drive vehicle steering system arrangement
    MH0 6-cyl. gasoline engine 2.7 L/187 kW 30V base engine is T7Z engine specifications
    N5A leather seat covering "Cricket" seat covering
    PBS - -
    PPD - -
    PPL - -
    PPY - -
    Q1N reinforced standard seat, front front seats
    QA0 without child seat child seats
    QH0 without voice control audio-response system/voice control
    QV0 w/o TV reception/digital radio reception TV reception/digital radio reception
    S3Q duty drawback control number (no PR-Family)
    T7Z 6-cylinder gasoline engine 2.7 L unit 078.8 base engine
    U1D instrument insert w/ mph speedo, clock, tachometer, trip odometer and additionalinstruments (voltage, oil temperature) instrument inserts
    V0A tires w/o specification of tire brand tire suppliers
    VC1 remote-controlled garage door opener remote-controlled garage door opener
    VX0 without hands-free system hands-free system
    VY0 without danger alarm system danger alarm system
  4. BOP4YH
    BOP4YH Живу я здесь
    5 мар 2009
    2.274
    Калининградская обл.
    Zeekr 001, TT 8S 2.0
    А мне такой же отчетик можно? :hi:
    WA1YD64B34N008599
    Заранее благодарен :beer:
  5. Жексон
    Жексон *******
    7 сен 2009
    6.125
    ВорЧун.... в соседней ветке все по русски.....дают расшифровку
  6. BOP4YH
    BOP4YH Живу я здесь
    5 мар 2009
    2.274
    запостил :beer:
    Что то совсем там маловато наших...
  7. Ленивый кот
    9 фев 2009
    169
    Audi Allroad 2.5 TDI 2004г.
    5 символов
  8. BOP4YH
    BOP4YH Живу я здесь
    5 мар 2009
    2.274
    Премного благодарен :beer:
  9. Ленивый кот
    9 фев 2009
    169
    Да не за что:beer:
  10. FLCL
    FLCL Завсегдатай
    7 окт 2009
    762
    EX-[100/C4 2.8]
    А можно мне вот такую машину (Штатовская)?
    WA1YD64B44N014363
  11. LNNLeon
    LNNLeon Участник форума
    24 дек 2010
    132
    Allroad 2,5TDI BAU
  12. Timakow
    Timakow Участник форума
    10 ноя 2010
    119
    Allroad 2.7T 03г.
