Ответ: Пробейте пожалуйста вин!!! VIN Number WAUZZZ4B52N148662; Sales type 4B202H; Exterior color 4Z Roof color 4Z Interior trim code QF; Engine code & No. ASN 25726; Transmission code FSA; Date of production 23.06.2002; Model year 2002; PR number: Код Опция 9B0 without telepay device 4X3 side airbag front with curtain airbag 9Q2 multi-function indicator/on-board computer with check control 0LW special plates/stickers/ safety certificates for Germany 8T1 cruise control system (CCS) FQ0 standard production wheels 1YA without transmission shafts f. rear axle 1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C 0F2 fuel system for carburetor gasoline engine L0L left-hand drive vehicle 8TC rear fog light for driving on the right QH0 without voice control 7P1 power adjustable lumbar support in frontseats 1Z0 initial standard fuel filling B01 type approval Germany 8ED bi-functional headlight with gas discharge lamp, for driving on the right 7A2 CD changer Q1D sports front seats N2L fabric seat covering "Speed" leather bolsters 0N6 rear axle with reduced tread VX0 without hands-free system 2WA without additional tires QA0 without child seat B0A component parts set without country-specific design requirement 7AA electronic vehicle immobilization device 7X2 ultrasonic park distance control front and rear FC1 customized installation 1D0 without towing attachment 2A5 delivery equipment (transit coating) with thin seat cover 1KD disc brakes, rear G0Z variable gearing ratio T15 components for base engine, unit 06C.B (aluminum) 0G7 Tiptronic 8N4 windshield wiper intermittent control with potentiometer (four speeds) D2H 6-cyl. gasoline engine 3.0 L/162 kW 30V V6 base engine is T15 7Q2 navigation system with color screen 1SA without additional engine guard 6SS luggage compartment floor covering 6E3 center armrest front 0VC information kit in German 0GG emissions concept EU 4 VY0 without danger alarm system 4K4 radio remote controlled central locking operated from inside and separate trunk release 3FA without roof insert (standard roof) VJ1 reinforced bumpers 2B0 without additional exterior noise suppression 7QB CD ROM (Germany) 9ZJ car phone installation (D-net) J0L battery 340 A (70 Ah) 6M1 tie down straps 1T3 first aid kit and warning triangle 1E1 activated carbon canister 0W1 label for central electric German-speaking countries E0A no special edition 4ZB bright moldings 1LG disc brakes, front 3V0 without child bench seat 4KC side and rear windows tinted 5A5 trunk lining, with stowage trays VC0 w/o remote-controlled garage door opener 6U0 without additional seals outside 3GA without cargo area 8GR alternator 150A 4L6 breakaway inside rear view mirror automatically dimming 7K0 without tire pressure warning light 6FB body-colored outer rear view mirror housings 3NZ rear seat bench unsplit, backrest split folding 2C5 axial and vertical adjustable steering column 9M0 without auxiliary/parking heater 4E0 tailgate/trunk lid unlocking from outside 1EX special identification plate for EC 2Z0 deletion of model designation 6V1 rear trim panel (ECE) 1N3 speed-related variable steering assist (Servotronic) NT0 transit coating (type 1) H8A tires 235/45 R 17 93Y 8X1 headlight washer system 3HA without leather parts scope 1G3 alloy spare wheel with original equipment tires 5C0 without special body measures 3X0 without load-through provision 2ZQ leather trimmed multi-function steering wheel for airbag system 8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving) 7E0 w/o heat accumulator/auxiliary heating C19 operating permit, alteration 19 8AY radio/navigation system 6W5 front license plate bracket 3PN electric seat adjustment for both front seats with memory system 1VH installation parts for six-cylinder engine 4N0 standard dashboard 0YF weight category rear axle weight range 6 5K5 transit protective film (instead of paint preservative) 4UE airbag f. driver a. front seat passenger 3B0 without additional child seat anchor 2T1 double-sized standard (DIN) 7M1 scuff plates in door apertures with metal inserts 0JL weight category front axle weight range 11 3Q6 three rear headrests A00 no self-collection F0A no special purpose vehicle, standard equipment K8B notchback U1U instrument insert w/ km/h speedo, clock tachometer, trip odometer, additional instruments with special color trim 5D1 carrier frequency 433.92 MHz 5RU outer right rear view mirror: convex (large viewing field) 3Y0 without roll-up sun screen 9NX without electronic logbook C1X alloy wheels 7 1/2J x 17 five-arm spider style, offset 45 6PC leatherette hand brake lever handle 1WG transmission shaft w/ 88mm in diameter 8K0 without special low beam mode 8Z5 engine cooling system, type 1 5SL outer left rear view mirror: non-spherical 1X0 front wheel drive 4GH windshield tinted with windshield sunshield 6Q2 leather gearshift knob/handle 3C7 3-point seat belt for center rear seat 1PC wheel bolts with anti-theft protection (unlockable) 4W0 without cassette and CD storage unit 9P0 without seat belt warning light 5E6 sill top with door cover 6XL outer rear view mirrors: powered, heatedelectrically foldable, automatically dimming, with memory function 3CA without partition FA0 control of standard production V0A tires w/o specification of tire brand 8RY speakers with BOSE sound A8S standard equipment 0ST labels/plates in German and French 0DS installation differentiation for build status of vehicle class 4B0 (AUDI) 3S0 without roof rails/roof load rack 4A3 seat heater for front seats separately controlled QV1 TV reception 5TL decorative inserts in piano lacquer 2G1 insert for the filling up of unleaded fuel 6R0 selector lever cover 1BA standard suspension/shock absorption 9AK Climatronic with impact pressure control free of cfc Нераспознанные коды RLB PRV WV6 PT3 PSV PNB WQI P21 PWF PPB PX4
Ответ: Пробейте пожалуйста вин!!! Пробейте пожалуйста и этот TRUUC28N9Y1055210, интересует сколько коней: 180 или 225?
Ответ: Пробейте пожалуйста вин!!! А буковки двигателя неизвестны? Да и вин какой то мифический.. Американка штоль?
Ответ: Пробейте пожалуйста вин!!! А мне мона: ауди 80 1993 г/в VIN wauzzz8czpa129999, дрыгун №ABT150814 (по крайней мере так в ПТС написано) Заранее спасибо и респект немеряных размеров...
Ответ: Пробейте пожалуйста вин!!! 180 сил мотор VIN-номер: TRUUC28N9Y1055210; Название модели: 8N355N; Цвет кузова: 5B; Цвет крыши: 5B; Код отделки салона: JL; Обозначение и № двигателя: ATC 8410; Код коробки передач: DXW; Дата изготовления: 07.12.1999; Код страны эксплуатации: X9A; Модельный год: 2000; Код Опция 5F0 without hardtop 1QE special plates/stickers safety certificates for Massachusetts 4X1 side airbag front 2G9 filler neck module 2 with insert 9Q2 multi-function indicator/on-board computer with check control MS3 4-cyl. gasoline engine 1.8 L/132 kW 20V turbo base engine is T8C 8T2 cruise control system (CCS) electronic 3L3 manual height adjustment for front seats 1C2 antifreeze up to -35 degree celsius tolerance up to -40 degree C 0F2 fuel system for carburetor gasoline engine 9Y1 outdoor temperature gage L0L left-hand drive vehicle 8TA without rear fog light 8M0 w/o rear window wiper and washer system 2W0 fuel filler cap 1JL rear shock absorption 7P0 without lumbar support in front and rear seats 7A2 CD changer Q1D sports front seats 1Z5 increase in initial standard fuel filling 0FA standard manufacturing sequence C4N alloy wheels 7 1/2J x 17 6-arm style, offset 32 0N5 standard rear axle 9JD smoking version, ashtray front G0N five-speed manual transmission for four-wheel drive vehicle (three-shaft transmission) 7X0 without park distance control 2WA without additional tires B0A component parts set without country-specific design requirement FC0 without customized installation 1D0 without towing attachment 2A4 delivery equipment for shipment (transitcoating) with thick seat cover 1KE disc brakes, rear T8C components for base engine, unit 06A.C 4R1 power windows 0G4 cable gearshift 7Q0 without navigation device 8N4 windshield wiper intermittent control with potentiometer (four speeds) 1SA without additional engine guard 6E0 without center armrest front 9D0 without preparation for two-way radio installation 4K2 radio remote controlled central locking operated from inside and separate trunk release 8UQ radio "concert" for USA 3FA without roof insert (standard roof) 7QA without CD ROM 0VM information kit in American English 2B1 additional exterior noise suppression 0GL emissions concept TLEV 1T3 first aid kit and warning triangle E0A no special edition 0W2 label for central electric English-speaking countries 1E4 activated charcoal canister acc. to ORVRand siphoning device for filling up VC0 w/o remote-controlled garage door opener 1LT disc brakes, front 8GL alternator 120A 0A1 two doors 9T1 heated washer nozzles, front 4SD left vanity mirror illuminated 8W1 washer fluid level indicator 7CA without label for radio remote control J1L battery 280 A (60 Ah) 6N0 without mud flaps 1EP special identification plate (USA) 2C5 axial and vertical adjustable steering column 9M0 without auxiliary/parking heater N5D Valcona leather seat covering C00 operating permit, initial registration 2Z1 type sign at rear and "Quattro" nameplates respectively 7S0 without wind blocker 4E6 tailgate/trunk lid release from inside only 3H5 backrest release for front seats with additional backrest release on the innerside B34 legal requirements USA 0AN stabilizer, front 6V2 rear trim panel 2K5 reinforced bumpers 1N4 power steering 9U1 brake pad wear indicator 4TD right vanity mirror illuminated 8X1 headlight washer system 7L0 without inertia benefit system/ deceleration fuel cut-off/idle stop valve 2D1 complete cd enhancing underbody panel 4M9 cup holder 5C1 body measures for increased safety requirements 2ZN leather trimmed sports steering wheel with aluminum appearance 1G9 space-saving spare wheel for temporary use, radial tire (5-hole) 8Q2 automatic headlight-range adjustment static 0BJ rear stabilizer H8V tires 225/45 R 17 91Y 7E0 w/o heat accumulator/auxiliary heating U1B instrument insert with mph speedometer, clock, tachometer and trip odometer 6W3 license plate bracket front (small, NAR) U93 suspension range 192 5K5 transit protective film (instead of paint preservative) 8Y1 two-tone horn 4UG driver's and front passenger airbag withkneebar a. passenger airbag deactivation 9V7 electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control 3B2 child seat anchor according to Australian requirements 2LB fuel tank with special material treatment (fluorination) F0A no special purpose vehicle, standard equipment A00 no self-collection 1H0 without proportioning valve 0YQ weight category rear axle weight range 14 K8C Coupe 1GS front shock absorption (AUDI TT) 0RA without ignition/starter switch locking system 5D2 carrier frequency 315 MHz 5RW outer right rear view mirror: convex, USlarge viewing field 8JD headlight with gas discharge lamp for driving on the right (US design) 6PA plastic hand brake lever handle 0CV vehicle class differentiation 8N0 5SG outer left rear view mirror: flat 8K0 without special low beam mode 9W5 car phone preparation 8CC speedometer sensor without seal (electronic speedometer sensor) 8Z6 engine cooling system, type 2 1X1 four wheel drive 1PA standard wheel bolts 6XD outer rear view mirrors: powered, heated 0L2 electric throttle actuation 4GP windshield tinted with sun band and viewing window for vehicle identification number 6Q7 leather gearshift knob with aluminum appearance 9P1 seat belt warning light, electric contact in buckle 1AH electronic differential lock (EDL) V0A tires w/o specification of tire brand FA0 control of standard production 8RY speakers with BOSE sound A8U executive US equipment 0SS labels/plates in English and French 4P0 rear floor panel module, type 1 QV0 w/o TV reception/digital radio reception 4A3 seat heater for front seats separately controlled SA6 inventory control model 1 QG1 service interval prolongation 2V1 dust and pollen filter 9AK Climatronic with impact pressure control free of cfc 6R3 rubber gearshift boot Нераспознанные коды PCC PPF PAS
Ответ: Пробейте пожалуйста вин!!! Извини, что так долго VIN Number WAUZZZ8CZPA129999; Sales type 8C20A8; Exterior color C6 Roof color C6 Interior trim code SX; Engine code & No. ABT150814; Transmission code ; Date of production 10.11.1992; Model year 1993; Код Опция 5MA decorative inserts 9Q0 without multi-function indicator/ on-board computer 8T0 without cruise control system (CCS) 0LW special plates/stickers/ safety certificates for Germany 8LA without additional instruments/switches 3L1 manual height adjustment for left front seat 8E1 WITH AIR AND WINDSCREEN WIPER INTER- FERENCE SUPPRESSION M4U 4-cylinder gasoline engine 2.0 L/66 kW single-point injection, closed-loop cat base engine is T4D 1YA without transmission shafts f. rear axle 6CB rear heating duct 1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C 0MB label f. starting an automatic (German) 9Y0 without outdoor temperature gage 0F2 fuel system for carburetor gasoline engine 9J0 without supertone system and tone sequence control 9BA w/o additional electric safety package 4B1 protective side molding L0L left-hand drive vehicle S2S control number (in-plant) 8TC rear fog light for driving on the right N2G seat coverings in leather, G grain pattern/leatherette, G grain pattern 7A0 without CD changer/CD player 1Z0 initial standard fuel filling Q1A standard front seats 6KA radiator grille G0E four-speed automatic transmission 6D1 center armrest rear C4J cast alloy wheels 7J x 17 offset 38 (1C0 601 025 R) 0N1 standard rear axle 5NB hood gas prop 9R0 WITHOUT CONTROL CHECK PACKAGE 3LN unpainted door trim panel 8U0 without additional instruments for distance measurement 8F0 without side lights B0A component parts set without country-specific design requirement 1D0 without towing attachment 2A5 delivery equipment (transit coating) with thin seat cover 1KD disc brakes, rear 4R0 mechanical window regulator 0G2 selector lever 9RA w/o special signal system preparation 3U0 without luggage compartment cover 8FA without second battery 6E0 without center armrest front 5H0 without tailgate lining 9S0 WITHOUT PROVISION FOR RADIO SET 9D0 without preparation for two-way radio installation 8NA without parking light warning light 8G0 without antenna cable for radio system 3FA without roof insert (standard roof) 2B0 without additional exterior noise suppression 1T0 w/o first aid kit and warning triangle 1LA disc brakes, front 1E1 activated carbon canister 0W1 label for central electric German-speaking countries E0A no special edition 9SA WITHOUT PROGRAMMING PLUG 9L1 engine compartment lighting 4D0 without seat ventilation/massage seat 4KC side and rear windows tinted 6U0 without additional seals outside 1M1 towing attachment with removable and lockable trailer hitch ball increased towing capacity 1EC special identification plate 9T0 without heated washer nozzles 8GM alternator 70A 4SA without left vanity mirror 9LA without rotating emergency lights 4L2 dipping breakaway inside rear view mirror J1F battery 265 A (50 Ah) 2R1 radiator installation position, front 6N0 without mud flaps 1MA steering wheel 6FA components without special surface appearance 3NZ rear seat bench unsplit, backrest split folding 9EB wire assembly for 4-cylinder fuel injected engine 8WD integrated front fog light 2Z1 type sign at rear and "Quattro" nameplates respectively 2K0 standard bumpers 2CA without central hydraulic system 6V1 rear trim panel (ECE) 1N1 power steering U0B instrument insert with clock km/h speedometer 5J0 without rear spoiler 4M0 without cup holder 9F0 without sound combination for rotating emergency light and radio antenna preparation 4TB vanity mirror right 8X0 without headlight washer system H0P tires 205/60 R 15 V 8AB radio "alpha" 6GA without add-on kit 1G3 alloy spare wheel with original equipment tires 5C0 without special body measures 4U0 without luggage nets/pockets on backrests 4F1 central locking system 3X0 without load-through provision 8Q1 headlight-range adjustment 3AD outer right rear view mirror: convex, manually adjustable from inside 1VA installation parts for four-cylinder engine (two-valve) 6W1 license plate bracket front (large) 5K1 paint preservative (wax) 9V0 without anti-theft protection system 4UA without airbag 9G0 without preparation for roof attachments T4D components for base engine, unit 048.D 8Y0 single-tone horn 3Q0 without rear headrests 3XA WITHOUT BASIC CARRIER FOR ROOF RACK 3B0 without additional child seat anchor 8BB halogen headlight for left-hand drive F0A no special purpose vehicle, standard equipment K8B notchback 6A0 without fire extinguisher 3Y0 without roll-up sun screen 8R0 without center high-mounted stop light 3J1 height-adjustable headrests for front seats 3BC outer left rear view mirror: flat, manually adjustable from inside 1WD transmission shaft for tripod joints 9W0 w/o car phone preparation/installation 9H0 without roof turn signal lights 8Z0 standard engine cooling system 3YB door pockets, front 8K0 without special low beam mode 3C1 static lap belt, center rear 2U0 without additional assist-starting device 8RD 2 loudspeakers (passive) 8CC speedometer sensor without seal (electronic speedometer sensor) 1X0 front wheel drive 4GH windshield tinted with windshield sunshield 1PA standard wheel bolts 6Q1 plastic gearshift knob/handle 0L0 mechanical throttle actuation 1AC anti-lock brake system (ABS) 0SB labels/plates in German 4W0 without cassette and CD storage unit 9P0 without seat belt warning light 9HA without additional malfunction display 9A0 without taxi alarm system 8S0 without reading light 3K0 without safety headrest system 3CA without partition 8KA w/o catalytic converter warning light A8S standard equipment 0DR installation differentiation for build status of vehicle class B (AUDI) unit components 9X0 without heated door lock cylinder 9PB windshield wiper arms/blades with additional guide vanes 9AA manually controlled heating system 4A0 without seat heater 3S0 without roof rails/roof load rack 2V1 dust and pollen filter 8L4 window antenna 2G1 insert for the filling up of unleaded fuel 6R0 selector lever cover 1BA standard suspension/shock absorption 0TA without floor mats
Ответ: Пробейте пожалуйста вин!!! Респект огромный :drunk2: Щас попробую перевести и сравнить с натурой!
Ответ: Пробейте пожалуйста вин!!! А мафынка то почти в первозданном виде А что значит N2G seat coverings in leather, G grain pattern/leatherette, G grain
