Всем привет!!! Помогите у кого есть информация по приборке на машинку a6 c5 2000г. Интересует распиновка разъемов приборки. Заранее спасибо!!!
Blue 32-Pin Connector 1 - Terminal 15 2 - Break pad wear 3 - Speedometer output 1 4 - not used 5 - Tank sensor 6 - Tank warning OBD 2 7 - Terminal 31 (Sensor ground) 8 - Coolant temperature 9 - Terminal 31 (Load ground) 10 - Oil pressure 2 (high) 11 - RPM signal 12 - A/C disconnect 13 - E-Gas/Preheat control 14 - Level regulator 15 - Terminal 58d 16 - Trailer signal 17 - High beam 18 - Signal left 19 - not used 20 - Terminal 58s 21 - Driver door contact switch 22 - Low coolant 23 - Terminal 30 24 - Terminal 31 (Load ground) 25 - Consumption signal 26 - Parking light right 27 - Parking light left 28 - Speedometer input 29 - Brake 30 - S-Terminal 31 - Speedometer output 2 32 - ESP/ASR Green 32-Pin Connector 1 - not used 2 - Transponder 3 - not used 4 - not used 5 - W-wire 6 - not used 7 - Signal right 8 - External buzzer 9 - External chime 10 - Airbag 11 - Auxiliary heater 12 - Terminal 61 13 - Parking brake/BRAKE 14 - CHECK 15 - Oil level/Oil temperature 16 - not used 17 - Transponder 2 18 - CAN low speed (Drive) (high +) 19 - CAN low speed (Drive) (low -) 20 - CAN low speed (Drive) (screen) 21 - ABS 22 - CAN low speed (Comfort) (high +) 23 - CAN low speed (Comfort) (low -) 24 - CAN low speed (Comfort) (screen) 25 - Engine hood 26 - Gas tank door 27 - Seat belt lock 28 - K-wire 29 - Ambient temperature-input 30 - Terminal 58de (ext. Dimmer potentiometer) 31 - Selector scale display 32 - LWR Gray 32-Pin Connector, Vertically Installed on VDO 1 - Switch for menu control (Menu) 2 - Switch for menu control (out A) 3 - Switch for menu control (out B) 4 - Switch for menu control (Enter) 5 - CAN high speed Display (high +) 6 - CAN high speed Display (low -) 7 - CAN high speed Display (screen) 8 - not used 9 - not used 10 - not used 11 - Enable 12 - Clock- 13 - Data- 14 - Brake light 15 - Wash water level 16 - Tail light/Low beam (Light control) 17 - On board computer left 18 - On board computer right 19 - On board computer reset 20 - Remote control input for auxiliary heater 21 - Summer /Winter Switch 22 - Auxiliary heater on 23 - Push button branch 1 Navigation 24 - Push button branch 2 Navigation 25 - Push button branch Telematik 26 - not used 27 - not used 28 - not used 29 - not used 30 - not used 31 - not used 32 - not used
Да. Приборка разъём синий Т32 контакт 8. Провод синий-коричн. 0.35. Далее через чёрный разъём в коробе ЭБУ под капотом T10p контакт 9 на датчик темп. охл. жидк. в моторной косе G62 контакт 1.
Народ подскажите по распиновке , есть audi a6 c5 v6 акпп с такой приборкой постоянно горит лампа колодок , и сразу включается подсветка при включении зажигания , с подсветкой ладно а вот как вылечить индикатор колодок ? перерыл уже кучу инета , нашел много разных схем и от b5 a4 a6 но мне они не подходят, у меня крышка приборки сзади белая , два разьема по краям синий и зеленый и один снизу по центру черный маленький . колодки искал и на синем разьеме 2 - Break pad wear (не они ) и на зеленом под 7 пином , тоже не они . коротил датчик тормозухи на бачке , тоже толку ноль .
Подскажите, ставлю иммобилайзер дополнительный и хочу заодно порвать антенну заводского иммо чтобы даже если ключ сопрут то блок блокировал. 2 - Transponder 17 - Transponder 2 Я правильно понимаю это Конци антенны иммобилайзера? 25 - Engine hood а это концевик капота? 8 - External buzzer а это что? Сигнал на управление сиреной сигнализации? Не знаете где находится реле управление сиреной сигналки. Знаю что сирена в багажнике в левой фальш панели .
Подскажите пожалуйста распиновку на приборной панели от ауди а3 1999г вот зачем мне надо http://www.drive2.ru/l/3969072/#a74412363
Ну попробуй. Приборка поди, ММ М73 глючная. Если так-топик долгоиграющий http://www.audi-club.ru/forum/showthread.php?t=281983
у меня есть такая распиновка. только почемуто там указано 3 разъема. а на моей как на гольфовской 2 разьема, красного нет
посмотри тему мою пожалуйста http://www.drive2.ru/l/3981724/ на первом фото видна надпись штрихом 97г
Ауди А6, С5 АКПП 2002г рейсталинг . Панель vdo 110.080.128/002 , где найти распиновку , да и полную схему бы...
Здравствуйте парни. Имею audi a6 c5 2.5tdi 2000 года. После перепайки четырех диодов на спидометре отвязались ключи от иммо. Приборка VDO с иммо3 ключи с транспондерами id48. Логин от прибоки вытащил.но привязать ключи не получается. Иммо моргает часто. Взял приборку от a4 и закатал в нее eeprom от родной и к ней мои ключи привязались за 2 минуты. А к родной не хотят. Электронщики сказали что я при перепайки повредил иммо и на антенну в замке не приходит сигнал или питание по этому не обучается. Ошибки 1 key too low signal. 2 incorrect key programing. 3. 02336 switch for lumbar support fore atf adjustment (E336) 32 00 resistance too high. Что и где искать на приборке. Что я мог запороть. Какие пины проверить в зеленом разъеме? Где чип иммо на приборке? Каков алгоритм действия? Приборка дает питание на антенну? Или как? Очень прошу помощи!!!! Мозги ебу ЕDC15.
