Добрый день! прошу посмотреть отчет, нихрена не понял шо не так с моей машинкой ))) VCDS Version: 19.6.2.0 Data version: 20190930 DS308.0 www.Ross-Tech.com Mileage: 121807km-75687mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8V-AU37 (5Q0) Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F Mileage: 121807km-75687miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (J623-CXSA) Labels:. 04E-907-309-V1.clb Part No SW: 04E 906 016 DF HW: 04E 907 309 A Component: 1.4l R4 TSI H08 5673 Revision: WAH08--- Coding: 02250032230401082000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_ECM14TFS01104E906016DF 002002 ROD: EV_ECM14TFS01104E906016DF.rod VCID: 69D3E0668879EB0710-803C 2 Faults Found: 5463 - Starter Control; Returned Message P3052 00 [036] - 50 Short to Plus Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 21 Mileage: 120466 km Date: 2020.09.15 Time: 08:19:48 Engine speed: 242.00 /min Normed load value: 69.0 % Vehicle speed: 0 km/h Coolant temperature: 45 °C Intake air temperature: 41 °C Ambient air pressure: 990 mbar Voltage terminal 30: 10.578 V Unlearning counter according OBD: 40 Starter control: terminal 50 acknowledgment-Bits 0-7: 32 Starter control: relay 1-Bits 0-7: 0 Starter control: release conditions-Bits 0-7: 0 Starter control: release conditions-Bits 0-7: 2 Starter control: shut-off conditions 1-Bits 0-7: 0 Starter control: shut-off conditions 1-Bits 0-7: 0 Number of manual engine starts-Bits 0-7: 0 Number of manual engine starts-Bits 0-7: 0 Number of manual engine starts-Bits 0-7: 0 Number of manual engine starts-Bits 0-7: 73 Number of automatic engine starts-Bits 0-7: 0 Number of automatic engine starts-Bits 0-7: 0 Number of automatic engine starts-Bits 0-7: 28 Number of automatic engine starts-Bits 0-7: 0 7150 - Implausible Data Received from Steering Angle Sensor Module (G85) U0428 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 121748 km Date: 2020.09.28 Time: 00:02:17 Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 20 °C Intake air temperature: 18 °C Ambient air pressure: 990 mbar Voltage terminal 30: 11.779 V Unlearning counter according OBD: 35 CAN status - engine control module-Bits 0-7: 0 selected gear-Bits 0-7: 0 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb Part No SW: 0CW 300 047 S HW: 0AM 927 769 K Component: GSG DQ200-MQB H43 5201 Revision: 00043014 Serial number: CU501704245228 Coding: 0014 Shop #: WSC 04940 001 00001 ASAM Dataset: EV_TCMDQ200021 001001 ROD: EV_TCMDQ200021_VW31.rod VCID: 4B9F3AEEE2C5191702-801E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G Component: ESC H31 0457 Revision: 00000000 Serial number: 63133000000238 Coding: 13F16AA224211271037C060141C729C8562448C0608294F3002100080608 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001 ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod VCID: 7BFFAA2EF2E56997F2-802E 2 Faults Found: 0297 - Steering angle sensor B1168 16 [008] - Voltage Too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 43 Mileage: 121748 km Date: 2020.09.28 Time: 00:02:17 32928 - Function Restricted due to Insufficient Voltage U1400 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 21 Reset counter: 48 ------------------------------------------------------------------------------- Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb Part No SW: 8V0 820 043 D HW: 8V0 820 043 D Component: AC Automat H13 0052 Revision: 20025000 Serial number: 00000000165582 Coding: 03000004000000001000000000001000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_AirCondiFrontVaAU37X 008020 ROD: EV_AirCondiFrontVaAU37X.rod VCID: 336F420E9A3561D76A-8066 Relative humidity sensor in fresh air intake duct: Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: 481989D6000000000001 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE Component: BCM MQBAB H H16 0124 Serial number: 00011328800887 Coding: 04041A46C24122F543A04004001807080000000000000000000000000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_BCMCONTI 012001 ROD: EV_BCMBOSCH_012.rod VCID: 7BFFAA2EF2E56997F2-802E Control Unit For Wiper Motor: Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB Component: WWS371 131108 041 0585 Serial number: 131111095215 Coding: 0A47F7 Rain Light Recognition Sensor: Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 21916679 Coding: 00006C Light switch: Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K Component: E1 - LDS MQB H05 0032 Serial number: 05 07 2013 00000250 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb Part No SW: 5Q0 919 283 B HW: 5Q0 919 283 Component: PARKHILFE 4K H09 0033 Revision: -------- Serial number: 60831329900047 Coding: 0000040011 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_EPHVA14AU3700000 002018 ROD: EV_EPHVA14AU3700000_002_VW37.rod VCID: 387575228353828F5F-806C 1 Fault Found: 13637426 - Databus U1123 00 [008] - Received Error Message [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 3 Reset counter: 43 Mileage: 121748 km Date: 2020.09.28 Time: 00:02:17 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB Component: AirbagVW20 014 0385 Serial number: 003MMR00F0HK Coding: 98CCC000000000005C540000004800000065 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_AirbaVW20SMEVW37X 002130 ROD: EV_AirbaVW20SMEVW37X.rod VCID: 0005DDC29B030A4FA7-8054 Side Sensor Driver Front: Subsystem 1 - Part No SW: ----------- HW: 480 001 910 13 Component: SideSensor_Df 001 0887 Serial number: 35767000000BCB881E07 Coding: 2D2D2D Side Sensor Passenger Front: Subsystem 2 - Part No SW: ----------- HW: 480 001 910 13 Component: SideSensor_Pf 001 0887 Serial number: 35867000000E6B881E05 Coding: 2D2D2D Side Sensor Driver Rear: Subsystem 3 - Part No SW: ----------- HW: 480 402 810 13 Component: SideSensor_Dr 001 6149 Serial number: 3516502B7105064522DZ Coding: 2D2D2D Side Sensor Passenger Rear: Subsystem 4 - Part No SW: ----------- HW: 480 401 810 13 Component: SideSensor_Pr 001 6149 Serial number: 3526502AF1230BB1E207 Coding: 2D2D2D Front Sensor Driver: Subsystem 5 - Part No SW: ----------- HW: 480 402 810 13 Component: FrontSensor_D 001 6149 Serial number: 35565029911FBEA3226N Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb Part No SW: 8V0 953 521 BT HW: 5Q0 953 549 C Component: Lenks. Modul 002 0110 Revision: -------- Serial number: 13101304400986 Coding: 8018 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_SMLSKLOMQB 017001 ROD: EV_SMLSKLOMQB_010_AU37.rod VCID: 0D1BF4F6DC515727DC-8058 No ASAM data for: "EV_SMLSKLOMQB" (AU37) 1 Fault Found: 617752 - ROD - Unknown Error Code - 00 [024] Intermittent - Confirmed - Not Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 19 Mileage: 120786 km Date: 2020.09.19 Time: 16:10:17 ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 8V0 920 860 E HW: 8V0 920 860 E Component: KOMBI H02 2220 Coding: 078019082A80000810008800100000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DashBoardVDDMQBAB 008031 ROD: EV_DashBoardVDDMQBAB_008_VW37.rod VCID: 3C7D6932B76BAEAFBB-8068 1 Fault Found: 9456681 - Key B104C 29 [008] - Implausible Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 11 Mileage: 114716 km Date: 2020.05.08 Time: 13:46:06 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M Component: GW MQB High 212 2163 Revision: -------- Serial number: 09111310800275 Coding: 030100042B0864005B000248180000000001000000000000000000000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_GatewConti 010015 ROD: EV_GatewConti_010.rod VCID: 3F871E3EA67DB5B79E-806A Alternator: Multi Function Steering Wheel Control Module: Subsystem 2 - Part No SW: 8U0 951 528 HW: 8U0 951 528 Component: E221 - MFL H02 0014 Serial number: 31 10 2013 B1258173 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E Component: J367-BDMHella H03 8043 Serial number: 9569801403 1 Fault Found: 8531970 - Quiescent Current U1406 00 [008] - Too High [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 7 Fault Frequency: 2 Reset counter: 15 Mileage: 120497 km Date: 2020.09.17 Time: 05:41:01 Supply voltage: Terminal 30: 12.2 V Terminal 15: OFF ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B Component: TSG FS 020 0025 Serial number: 19101302090839 Coding: 00100E204000040000001002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003 ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: 3E79633AA177BCBF95-806A Drivers Door Rear Control Module: Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_DRV 005 0004 Serial number: 00000000000000968536 Coding: 110000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P Component: EPS_MQB_ZFLS 122 1043 Coding: 0103 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_SteerAssisMQB 010031 ROD: EV_SteerAssisMQB_010.rod VCID: 418318C6D089C347E8-8014 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B Component: TSG BFS 020 0025 Serial number: 02101302090082 Coding: 001006204000040000001002 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003 ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: 3D7B6436AC71A7A78C-8068 Passengers Rear Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_PSG 005 0004 Serial number: 00000000000000970633 Coding: 090000 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb Part No SW: 5Q0 907 357 HW: 6R0 907 357 A Component: LWR-ECU 005 0080 Revision: -------- Serial number: -------------- Coding: 019A000001000000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110 ROD: EV_HeadlRegulVWLWRMQB.rod VCID: 75EBBC16D4C13FE784-8020 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-ENT1.clb Part No SW: 8V0 035 889 A HW: 8V0 035 889 Component: MU-E--ER 170 0107 Revision: -------- Serial number: 000086238701000 Coding: 01730100FF00000010110001000A0000000001040100010000 Shop #: WSC 06385 790 00016 ASAM Dataset: EV_MUEnt4CCONT 004052 ROD: EV_MUEnt4CCONT.rod VCID: 40851DC2DB83CA4FE7-8014 Display unit 1 for multimedia system: Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C Component: DU Std H48 0013 Serial number: AUZ8Z9DY3003X7 Multimedia Operating Unit: Subsystem 2 - Part No SW: 8V0 919 614 HW: 8V0 919 614 Component: ControlUnit_B H33 0037 Serial number: C1000007081300020134 1 Fault Found: 1539 - Function Restricted due to Insufficient Voltage U1400 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 43 Mileage: 121749 km Date: 2020.09.28 Time: 10:38:23 Voltage terminal 30: 8.9 V End-------------------------(Elapsed Time: 03:40)--------------------------
