Подскажите пожалуйста счет этих ошибок. что может быть и как это можно исправить без поездки k любимому дилеру. Ауди а6 c6 2.0 TFSI. Address 01: Engine Labels: 06F-907-115-AXX.lbl Control Module Part Number: 4F2 910 115 B HW: 4F2 907 115 Component and/or Version: 2.0l R4/4V TFSI 0040 Software Coding: 010D000302070120 Work Shop Code: WSC 02325 785 00200 VCID: 1F4D05F7CE4807E68D9-804A 3 Faults Found: 004506 - Fuel Pressure Sensor (G247) P119A - 001 - Malfunction Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 5 Reset counter: 255 Mileage: 185865 km Time Indication: 0 Date: 2015.03.17 Time: 10:49:59 Freeze Frame: RPM: 749 /min Load: 17.6 % Speed: 0.0 km/h Temperature: 69.0°C Temperature: 22.0°C Absolute Pres.: 980.0 mbar Voltage: 13.208 V 008583 - Bank 1; System too Lean at Idle P2187 - 004 - - Intermittent - MIL ON Freeze Frame: Fault Status: 10100100 Fault Priority: 0 Fault Frequency: 3 Reset counter: 255 Mileage: 185866 km Time Indication: 0 Date: 2015.03.17 Time: 10:51:16 Freeze Frame: RPM: 749 /min Load: 20.4 % Speed: 0.0 km/h Temperature: 70.0°C Temperature: 16.0°C Absolute Pres.: 1020.0 mbar Voltage: 13.335 V 001089 - EVAP Emission Control Sys P0441 - 001 - Incorrect Flow - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 185972 km Time Indication: 0 Date: 2015.03.21 Time: 11:15:47 Freeze Frame: RPM: 744 /min Load: 14.1 % Speed: 0.0 km/h Temperature: 68.0°C Temperature: 25.0°C Absolute Pres.: 980.0 mbar Voltage: 12.827 V Readiness: 0000 0001
