замена штатного дифференциала торсен
Тема в разделе "Тюнинг", создана пользователем Parradox, 21 ноя 2011.
  1. Parradox
    Parradox Старожил
    21 июл 2006
    6.681
    A4B6 1.8TQ 250Hp
    #1 Parradox, 21 ноя 2011
    http://www.stasisengineering.com/pr...s-torsen-center-a4-5-speed-01a-late-2002-2005
    какие мысли ?
    TaSIS differentials give you a big bang for your buck, increasing traction and improving handling to significantly enhance your vehicle’s performance. Our differentials automatically adjust power to all four wheels, delivering torque where you need it and when you need it so that you can put power to the ground for real-world performance gains from the engine enhancements you already have.
    For all-wheel-drive (AWD) vehicles, our high-bias torsen center differential improves the factory’s 2:1 and 4:1 torque distribution ratios, and can reach up to 6:1 depending on driving conditions. Our differential can deliver up to 88 percent of the available power to the wheels that need it most, translating to a significant reduction of wheel spin. This capability changes how your vehicle approaches each part of a turn by transferring power to the front or rear of the car as necessary:
    Hard braking leading into a turn—Car acts like a front wheel drive. Wheels turn independently and car control is improved.
    Mid corner, throttle on—Car acts like an all wheel drive. STaSIS differential delivers equal amounts of power to front and rear wheels. This maximizes grip, allowing more power to be applied at this stage of a turn.
    Corner exit, hard acceleration—Car acts like a rear-wheel-drive car. Front wheel slip is reduced because the STaSIS differential delivers up to 88% of the engine torque to the rear wheels where the most traction is.
    также предлагают диф повышенного трения на заднюю ось
  2. REDLINE61
    REDLINE61 Bad e-mail
    28 янв 2006
    4.286
    VWTIGUAN 2.0TDI CR
    мысли - нафига я по английски не понимаю))
  3. ches
    ches Завсегдатай
    15 апр 2008
    847
    Audi А4/B6 1.8T AMB Quattro
    В кратце: Перекидывает момент при торможении больше на перед, в повороте пополам, при выходе из поворота больше на зад :)
    Пы.сы. не пинать если неправильно понял :umnik:
  4. figo
    figo Старожил
    31 дек 2007
    5.653
    OOOO
    во замута)
  5. Parradox
    Parradox Старожил
    21 июл 2006
    6.681
    A4B6 1.8TQ 250Hp
    ага, и по деньгам вполне сносно
  6. VIK40
    VIK40 Bad e-mail
    10 янв 2011
    613
    A4 1.8tq,sti,A4TQ
    :thumbup:ездил на тачке с таким дифом,ощущения другие после своей,иногда похоже на поведение заднеприводной машины,очень вообщем понравилось!
  7. Parradox
    Parradox Старожил
    21 июл 2006
    6.681
    A4B6 1.8TQ 250Hp
    то есть зимой на старте закинуть жопу в соседнюю машину можно ?
  8. VIK40
    VIK40 Bad e-mail
    10 янв 2011
    613
    A4 1.8tq,sti,A4TQ
    с места вряд ли,а вот в повороте с отключенной ЕСП на влажном асфальте вполне)))
  9. DioTrixX
    DioTrixX Живу я здесь
    28 окт 2007
    1.287
    Audi S4 b8
    #9 DioTrixX, 21 ноя 2011
    А в чем вопрос ? Два дифа один в центр , другой в мост , уже 100 лет там продаются.... токо тот что 550 стоит это если ты им свой отдаешь.... что-то в мост не вижу убрали что ли
  10. Parradox
    Parradox Старожил
    21 июл 2006
    6.681
    A4B6 1.8TQ 250Hp
    есть опыт использования ?
  11. melodic
    melodic Живу я здесь
    23 июн 2009
    1.066
    A4 DTM 2007
    я бы торсен на жопу с радостью повесил
