+1 Carfax . Выдам все инфо по любому.. вину
Тема в разделе "Выбор Audi с пробегом", создана пользователем AudiA, 18 сен 2006.
  1. Milka
    Milka Живу я здесь
    21 июн 2005
    4.308
    все продал( а4 2005 2.0TFSI,а4 2002
    Ответ: +1 Carfax . Выдам все инфо по любому.. вину
    А посмотри вот этот плиз ...WAUZZZ8E02A260927
  2. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    The VIN you supplied, "WAUZZZ4AZTN070154", is invalid. Please check the number for accuracy and try again below.
  3. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    The VIN you supplied, "WAUZZZ4B52N050005", is invalid. Please check the number for accuracy and try again below.
  4. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    The VIN you supplied, "WAUZZZ8E02A260927", is invalid. Please check the number for accuracy and try again below.
  5. Milka
    Milka Живу я здесь
    21 июн 2005
    4.308
    Прикольная программа..........))))
  6. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    1999 NISSAN PATHFINDER LE/SE/XE
    JN8AR07Y4XW355500
    4 DR. WAGON/SPORT UTILITY
    3.3L V6 SFI SOHC 12V / 4 WHEEL DRIVE
    Salvage | Junk | Rebuilt Guaranteed
    No Problem Fire/Flood | Hail Damage | Buyback/Lemon
    Guaranteed
    No Problem Not Actual Mileage | Exceeds Mechanical Limits Guaranteed
    No Problem
    Date:Mileage:Source:Comments:06/16/1999 Ontario
    Ministry of Transportation Registration issued or renewed
    Passed safety inspection
    Vehicle color noted as Black 08/18/1999 8,762 Service Facility Vehicle serviced
    Oil and filter changed chassis lubricated 09/22/1999 Service Facility Vehicle serviced
    Oil and filter changed chassis lubricated 10/19/1999 12,803 Service Facility Vehicle serviced
    Oil and filter changed chassis lubricated 11/13/1999 Service Facility Vehicle serviced
    Washed/detailed 11/23/1999 16,358 Service Facility Vehicle serviced
    Weather stripping serviced 11/30/1999 Service Facility Vehicle serviced
    Washed/detailed 01/06/2000 17,858 Service Facility Vehicle serviced
    Oil and filter changed chassis lubricated 01/17/2000 Service Facility Vehicle serviced
    Washed/detailed 01/31/2000 24,526 Service Facility Vehicle serviced
    Windshield washer checked
    Air filter checked
    Antifreeze/coolant checked 04/05/2000 Service Facility Vehicle serviced
    Cab/sheet metal serviced
    Bumper serviced
    Recommended maintenance service performed
    Air filter checked
    Antifreeze/coolant flushed/changed
    Fuel filter replaced
    Engine serviced
    Suspension system serviced
    Safety inspection performed 05/17/2000 24,944 Service Facility Vehicle serviced
    Oil and filter changed chassis lubricated 05/31/2000 Service Facility Vehicle serviced
    Washed/detailed 11/22/2000 Service Facility Vehicle serviced
    Tires replaced
    Tires balanced 02/21/2001 Service Facility Vehicle serviced
    Bumper serviced 05/03/2001 43,456 Service Facility Vehicle serviced
    Rear brakes serviced/adjusted
    Tires rotated
    Tires balanced
    Safety inspection performed 05/07/2001 Service Facility Vehicle serviced
    Brake fluid flushed/changed
    Air filter checked
    Fuel injector checked 05/30/2001 44,807 Service Facility Vehicle serviced
    Engine serviced 06/15/2001 Service Facility Vehicle serviced
    Washed/detailed 06/28/2001 76,519 Service Facility Vehicle serviced
    Automatic transmission fluid and filter changed
    Oil and filter changed chassis lubricated 08/31/2001 Ontario
    Central Ontario Registration issued or renewed 01/08/2002 Service Facility Vehicle serviced
    Washed/detailed 04/09/2002 102,029 Auto Auction Sold at auction in
    Ontario
    Listed as a
    fleet vehicle with
    Odometer reported as 164,201 kilometers
    1 человеку нравится это.
  7. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    прикольный европейский вин
  8. raudi
    raudi Участник форума
    13 май 2006
    244
    A6 qu 3.0 2001 ASN
    Правильный вроде бы!
    Указан в фашистском ПТС
    WAUZZZ4B52N050005 - последние 6 знаков - цифры!
  9. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    все правельно только вин европейский в карфаксе такое непроходит, аирборна спроси в соседней ветке он имеет доступ к етке там или где чекается
  10. Milka
    Milka Живу я здесь
    21 июн 2005
    4.308
    Все понял! Ссорри)))
  11. raudi
    13 май 2006
    244
    A6 qu 3.0 2001 ASN
    Ок спасибо!
  12. FUNTIK
    FUNTIK Bad e-mail
    1 сен 2006
    38
    AUDI-100/45
    Ответ: +1 Carfax . Выдам все инфо по любому.. вину vin
    Здравствуйте. Пробейте пожалуйста этот VIN WAUZZZ4AZMN081013. Суважением Funtik.:hi:
  13. DIESELBOY
    DIESELBOY Завсегдатай
    26 авг 2003
    672
    Туарег 13г.
    ВСЕ VINы В КАРФАКСЕ ТОЛЬКО АМЕРИКАНСКИХ АВТО!
    Т.Е. ТЕ КОТОРЫЕ ЕЗДИЛИ В США!
    Это я так на всякий случай, чтоб люди знали! :love:
  14. Verhne_Vyatsky
    Verhne_Vyatsky Новичок
    8 май 2006
    62
    Audi 100 2.3 92г.
    блин а уменя немка :(
  15. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    The VIN you supplied, "WAUZZZ4AZMN081013", is invalid. Please check the number for accuracy and try again below.
  16. FUNTIK
    FUNTIK Bad e-mail
    1 сен 2006
    38
    AUDI-100/45
    С горем пополам перевёл Ваш английский. Понял, что с номером что-то не так.Проверил ещё раз, WAUZZZ4AZMN081013. Во всяком случаи в ПТС отпечатано иммено так. Может быть меня обманули и подсунули машину которой не существует?:confused:
  17. Nick242000
    Nick242000 Участник форума
    15 янв 2005
    419
    Audi A4 2000г. 1,8
    А пробейти плиз ентот вин
    Должен быть фольц американец
    3vwse69mx2m142940
    Спасибо :beer: :beer: :beer: :beer:
  18. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    машина европейская и этим все сказано =)
  19. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    2002 VOLKSWAGEN JETTA GLS
    3VWSE69MX2M142940
    SEDAN 4 DR
    1.8L L4 PFI DOHC / FRONT WHEEL DRIVE
    Year purchased2002 Type of ownerLease Estimated length of ownership
    3 yrs. 5 mo. Owned in the following states/provincesNew Jersey Estimated miles driven per year20,075/yr Last reported odometer reading70,394
    Guaranteed
    No Problem
    О уже интересней :
    Frame Damage Check
    No frame damage reported to CARFAX. No Issues Reported
    Airbag Deployment Check
    Airbag deployment reported on 12/24/2002. Airbag Deployment
    Odometer Rollback Check
    No indication of an odometer rollback.
    No Issues Indicated
    Accident Check
    Accident reported on 12/24/2002. Accident Indicator
    Manufacturer Recall Check
    Check with an authorized Volkswagen dealer for any open recalls.
    No Recalls Reported
    Basic Warranty Check
    Original warranty estimated to have expired. View Info
    Interested in an extended warranty?
    Warranty Expired
    Date:Mileage:Source:Comments:Not Reported NICB Vehicle manufactured
    and shipped to original dealer 03/15/2002 New Jersey
    Motor Vehicle Dept.
    Libertyville, IL Registered as
    lease vehicle 03/26/2002 2 Service Facility Vehicle serviced
    Electrical system serviced 04/10/2002 91 New Jersey
    Motor Vehicle Dept.
    Libertyville, IL
    Title #RD20021000357 Title issued or updated
    First owner reported
    Registered as lease vehicle 12/24/2002 New Jersey
    Police Report
    Case #02-15540 Accident Reported
    in Sussex County
    Involving front impact
    It hit another motor vehicle
    Front area primarily damaged
    Airbag deployed CARFAX began reporting information from this source on 05/03/2006.
    CARFAX Airbag Tips 02/01/2005 57,952 Service Facility Vehicle serviced
    Transmission serviced 09/13/2005 70,394 Auto Auction Sold at auction
    in New England Region
    Listed as
    a fleet vehicle
  20. Nick242000
    15 янв 2005
    419
    Audi A4 2000г. 1,8
