после появления ошибки 17125 я сделал лог 7 группы. но разобраться не смог...может он чем поможет?! Saturday,07,January,2012,14:51:06 4Z7 927 156 R,,AG5 01V 4.2l5V RdW 2224, ,Group A:,'007,,,,Group B:,'001,,,,Group C:, Not Running ",,ATF Temp,Solenoid valve 7,Torque conv.,T. conv. slip spd,,Engine RPM ,Trans. Input spd,Trans. Veh.,Gear engaged,,,,," ,TIME,,,clutch,(0|20-120|0-10),TIME,,sensor signal,speed sensor,,TIME,,,, Marker,STAMP,°C, A,, /min,STAMP, /min, /min, /min,,STAMP,,,, ,0.01,62.0,0.048, TC Open,576,0.28,1280,352,96,1 ,,,,, ,0.56,62.0,0.048, TC Open,896,0.85,1856,1088,288,1 ,,,,, ,1.12,62.0,0.048, TC Open,480,1.41,2112,1824,480,1 ,,,,, ,1.69,62.0,0.048, TC Open,96,1.96,2240,1920,576,1 ,,,,, ,2.25,62.0,0.048, TC Open,512,2.53,2048,1408,704,1 ,,,,, ,2.81,62.0,0.384, Torq.Conv.Reg,608,3.09,2240,1696,832,2 ,,,,, ,3.38,62.0,0.424, Torq.Conv.Reg,448,3.65,2400,1952,960,2 ,,,,, ,3.93,62.0,0.464, Torq.Conv.Reg,352,4.21,2560,2240,1120,2 ,,,,, ,4.49,62.0,0.536, Torq.Conv.Reg,256,4.78,2784,2528,1248,2 ,,,,, ,5.05,62.0,0.640, Torq.Conv.Reg,256,5.34,3072,2816,1408,2 ,,,,, ,5.62,62.0,0.712, Torq.Conv.Reg,256,5.89,3424,3168,1568,2 ,,,,, ,6.18,62.0,0.688, Torq.Conv.Reg,224,6.46,2912,2688,1696,2 ,,,,, ,6.74,62.0,0.616, Torq.Conv.Reg,0,7.02,2496,2496,1760,2 ,,,,, ,7.31,62.0,0.608, Torq.Conv.Reg,0,7.58,2656,2592,1824,3 ,,,,, ,7.86,62.0,0.608, Torq.Conv.Reg,128,8.15,1984,1856,1856,3 ,,,,, ,8.42,62.0,0.632, Torq.Conv.Reg,32,8.71,1984,1920,1920,4 ,,,,, ,8.99,62.0,0.560, Torq.Conv.Reg,0,9.27,1728,1696,1952,4 ,,,,, ,9.55,62.0,0.496, Torq.Conv.Reg,0,9.83,1440,1440,1952,4 ,,,,, ,10.11,62.0,0.480, Torq.Conv.Reg,0,10.39,1440,1440,1952,4 ,,,,, ,10.67,62.0,0.456, Torq.Conv.Reg,0,10.95,1472,1440,1952,5 ,,,,, ,11.23,62.0,0.312, Torq.Conv.Reg,0,11.52,1440,1440,1952,5 ,,,,, ,11.79,62.0,0.320, Torq.Conv.Reg,0,12.08,1440,1440,1952,5 ,,,,, ,12.35,62.0,0.320, Torq.Conv.Reg,0,12.64,1440,1440,1952,5 ,,,,, ,12.92,63.0,0.352, Torq.Conv.Reg,0,13.19,1472,1440,1952,5 ,,,,, ,13.48,63.0,0.384, Torq.Conv.Reg,0,13.76,1600,1472,1984,5 ,,,,, ,14.04,63.0,0.488, Torq.Conv.Reg,160,14.32,1632,1504,2016,5 ,,,,, ,14.61,63.0,0.480, Torq.Conv.Reg,32,14.88,1504,1504,2048,5 ,,,,, ,15.16,63.0,0.312, Torq.Conv.Reg,0,15.45,1472,1504,2048,5 ,,,,, ,15.72,63.0,0.328, Torq.Conv.Reg,32,16.01,1408,1504,2048,5 ,,,,, ,16.29,62.0,0.328, Torq.Conv.Reg,32,16.57,1472,1504,2048,5 ,,,,, ,16.85,62.0,0.336, Torq.Conv.Reg,32,17.13,1472,1504,2016,5 ,,,,, ,17.41,62.0,0.336, Torq.Conv.Reg,32,17.69,1440,1504,2016,5 ,,,,, ,17.98,63.0,0.344, Torq.Conv.Reg,32,18.25,1440,1472,2016,5 ,,,,, ,18.53,62.0,0.344, Torq.Conv.Reg,32,18.81,1440,1472,1984,5 ,,,,, ,19.09,63.0,0.336, Torq.Conv.Reg,32,19.38,1408,1472,1984,5 ,,,,, ,19.66,62.0,0.344, Torq.Conv.Reg,32,19.94,1408,1440,1952,5 ,,,,, ,20.22,62.0,0.344, Torq.Conv.Reg,32,20.49,1376,1440,1952,5 ,,,,, ,20.78,63.0,0.344, Torq.Conv.Reg,32,21.06,1376,1440,1920,5 ,,,,, ,21.34,63.0,0.344, Torq.Conv.Reg,32,21.62,1376,1408,1920,5 ,,,,, ,21.91,63.0,0.344, Torq.Conv.Reg,32,22.18,1376,1408,1888,5 ,,,,, ,22.46,64.0,0.344, Torq.Conv.Reg,32,22.75,1376,1376,1888,5 ,,,,, ,23.02,63.0,0.352, Torq.Conv.Reg,32,23.31,1344,1376,1856,5 ,,,,, ,23.59,63.0,0.352, Torq.Conv.Reg,32,23.86,1344,1376,1856,5 ,,,,, ,24.15,63.0,0.344, Torq.Conv.Reg,0,24.43,1344,1344,1824,5 ,,,,, ,24.71,64.0,0.344, Torq.Conv.Reg,0,24.99,1344,1344,1824,5 ,,,,, ,25.28,63.0,0.352, Torq.Conv.Reg,0,25.55,1312,1344,1824,5 ,,,,, ,25.83,63.0,0.352, Torq.Conv.Reg,0,26.12,1312,1344,1792,5 ,,,,, ,26.39,63.0,0.352, Torq.Conv.Reg,0,26.68,1280,1312,1792,5 ,,,,, ,26.95,63.0,0.352, Torq.Conv.Reg,0,27.24,1248,1280,1728,5 ,,,,, ,27.52,63.0,0.360, Torq.Conv.Reg,0,27.80,1184,1184,1600,5 ,,,,, ,28.08,63.0,0.360, Torq.Conv.Reg,0,28.36,1088,1088,1472,5 ,,,,, ,28.64,63.0,0.360, Torq.Conv.Reg,0,28.92,992,992,1344,5 ,,,,, ,29.21,63.0,0.352, Torq.Conv.Reg,0,29.48,896,896,1216,5 ,,,,, ,29.76,63.0,0.336, Torq.Conv.Reg,96,30.05,992,1088,1088,5 ,,,,, ,30.32,63.0,0.336, Torq.Conv.Reg,32,30.61,896,960,960,5 ,,,,, ,30.89,63.0,0.328, Torq.Conv.Reg,32,31.17,800,832,832,4 ,,,,, ,31.45,64.0,0.328, Torq.Conv.Reg,160,31.73,864,992,704,4 ,,,,, ,32.01,63.0,0.328, Torq.Conv.Reg,64,32.29,768,832,576,4 ,,,,, ,32.58,63.0,0.048, TC Open,32,32.85,608,672,480,3 ,,,,, ,33.14,64.0,0.048, TC Open,0,33.42,608,512,352,3 ,,,,, ,33.69,64.0,0.048, TC Open,160,33.98,576,512,224,3 ,,,,, ,34.26,63.0,0.048, TC Open,224,34.54,608,352,192,3 ,,,,, ,34.82,63.0,0.048, TC Open,256,35.11,640,352,160,2 ,,,,, ,35.38,63.0,0.048, TC Open,288,35.66,736,448,160,2 ,,,,, ,35.94,63.0,0.048, TC Open,480,36.22,1504,960,256,2 ,,,,, ,36.51,64.0,0.048, TC Open,448,36.78,1728,1408,384,1 ,,,,, ,37.07,63.0,0.048, TC Open,224,37.35,2016,1760,480,1 ,,,,, ,37.62,64.0,0.048, TC Open,448,37.91,1920,1280,576,1 ,,,,, ,38.19,64.0,0.048, TC Open,672,38.47,2048,1440,704,1 ,,,,,
он даже не думает блокироваться в ремонт либо попробовать стереть ошибку и прокатиться побыстрее чтоб на верняка он заблокировался и пошло проскальзывание тогда точно в ремонт другая коробка потребует своих мозгов которые не поймут почемутам было 2.0 а стало 4.2 - как вариант от s4 b6 b7 только ставить и что там с проводкой тоже вопрос - это не вариант а вот родную починить - вариант
да не..раз такая пьянка...замысел был чтобы на дальних расстояниях не думать о расходе...с моими данными-очевидно ,что выливаю 25 % бензина в никуда...если при исправной коробке будут обороты про которые вы говорите,то смысл заморачиваться... p/s лог снят был после стирания ошибки сразу.(((
с мануала к коробке "Муфта работает следующим образом: Рабочая жидкость АТР постоянно циркулирует внутри гидротрансформатора. При разомкнутой муфте ее поток направляется вдоль передней стенки диска муфты и затем возвращается внутрь гидротрансфо р матора. При этом давления с обеих сторон диска муфты равны. Чтобы включить муфту блокирования гидротрансформатора, прибор управления трансмиссией меняет направление течения рабочей жидкости. При этом жидкость вытекает из пространства перед муфтой и притекает к ее тыльной стороне. Под действием разности давлений, действующих на диск муфты, она замыкается." я так понимаю,комп даёт сигнал и жидкость выходит в обратном направлении,тут муфта замыкается и у нас полное сцепление двигатель-коробка... Можно как нить ручками с вагкома это включить,посмотреть идёт ли сигнал?
Да не надо тут ниче смотреть логами- все предельно ясно-пинцет бублику. Если ошибка лезет, то уже точно усе.
Я посмотрел видео, у тебя точно что-то не то с коробкой. У мменя таким оборотам соответствует где-то 130-140 км. Могу тоже видео снять и выложить
самое интересное что езжу так пол года. как купил.16 тысяч км..без изменений.это определённо точно,так как с первых дней обратил внимание.а как купил шнурок,так сразу начал вокруг ошибки копать... Полгода-не показатель для этой неисправности?
Один в один. Я то-же пол года с этой ошибкой катался, пока не заморочился на замену бублика. А в последующем ремонт АКПП, аж два раза.
первый раз в сервисе, а потом сам. Когда сам перебирал АКПП понял что АКПП не ремонтировали под ключ, а всего лишь устраняли явную неисправность.
в общем спасибо за ответы по теме.Много полезного узнал и сам посмотрел куда двигаться. Надеюсь дотянуть до апреля.Благо есть вторая машина.забетонирую пол в гараже.Гараж длинный и двойной.стапеля сделаю,так как хочу ещё цепи поменять(время пришло). Благо гараж в 100 метрах от кунцевского рынка на горбунова.Так,что вопросы быстро решаться+есть хороший поставщик+во дворе экзист... Да и в апреле не так холодно+день длиннее...Подготовлюсь к работе с фотоотчётом...
Ошибка есть, но я не замечаю при езде никаких симптомов Заканчивается это так http://audi-club.ru/forum/showthrea...ght=%F2%E5%F7%FC+%EC%E0%F1%EB%E0+%C0%CA%CF%CF http://www.audi-club.ru/forum/showpost.php?p=3655305&postcount=3
у меня так выходит если только ехать не более 100. км в час...сами понимаете-300 лошадей ,убийца азонового слоя,внутри hi-fi от bose и мертвые коровы на сиденьях,а я еду как пенсионер на таврии...
