Гидрокомпенсаторы ставить только родные или можно что то еще?? Под ними надо тоже менять?? Пружины, тарелки, маслосъемные колпачки?? Это по теме))))))
ну как обычно, исчерпывая запасы ) он 95 литров по паспорту в реале побольше. чего вдо и не скрывает. в реале я бы под такой запрос ставил 130литров при 5.5бара
Короче снял тут логи своего газового чуда. Первый на газу, второй на бензе. И ошибочки по мотору. Это газ: Tuesday,17,January,2012,20:47:57 4Z7 907 551 H,,2.7l V6/5VT 0002, ,Group A:,'020,,,,Group B:,'093,,,,Group C:,'115 ,,Timing Retardation,Timing Retardation,Timing Retardation,Timing Retardation,,Engine Speed,Engine Load,Phase Position,Phase Position,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure ,TIME,Cylinder 1,Cylinder 2,Cylinder 3,Cylinder 4,TIME,(G28),,Bank 1,Bank 2,TIME,(G28),,(specified),(actual) Marker,STAMP,°KW,°KW,°KW,°KW,STAMP, /min, %,°KW,°KW,STAMP, /min, %, mbar, mbar ,0.30,0.0,0.0,0.0,0.0,0.60,1800,43.6,-4.0,-2.0,0.01,1600,51.1,1000.0,1000.0 ,1.24,0.0,0.0,0.0,0.0,1.51,2040,82.0,-4.0,-2.0,0.90,1920,51.1,1000.0,1000.0 ,2.11,0.0,0.0,0.0,0.0,2.41,2600,95.5,-4.0,-2.0,1.81,2160,85.7,1810.0,1100.0 ,3.03,0.0,0.0,0.0,0.0,3.35,4760,103.8,-4.0,-2.0,2.71,3600,101.5,1690.0,1310.0 ,4.05,0.0,0.0,0.0,0.0,4.42,6400,96.2,-4.0,-2.0,3.70,5360,103.0,1620.0,1300.0 ,5.11,0.0,0.0,0.0,0.0,5.42,4440,109.0,-4.0,-2.0,4.78,5520,108.3,1580.0,1310.0 ,6.06,0.0,0.0,0.0,0.0,6.39,4960,106.8,-4.0,-2.0,5.73,4640,109.8,1620.0,1320.0 ,7.07,0.0,0.0,0.0,0.0,7.42,5520,103.0,-4.0,-2.0,6.73,5120,106.0,1600.0,1320.0 ,8.14,0.0,4.5,3.0,0.0,8.51,5840,105.3,-4.0,-2.0,7.78,5720,103.8,1560.0,1280.0 ,9.16,0.0,4.5,3.0,0.0,9.49,4640,109.8,-4.0,-2.0,8.84,4720,115.8,1590.0,1380.0 ,10.13,0.0,4.5,3.0,0.0,10.46,4960,106.0,-4.0,-2.0,9.80,4720,109.8,1600.0,1340.0 ,11.14,0.0,4.5,3.0,0.0,11.48,5240,106.0,-4.0,-2.0,10.80,5040,106.8,1590.0,1350.0 ,12.18,0.0,3.8,2.3,0.0,12.52,5560,103.0,-4.0,-2.0,11.82,5360,106.0,1580.0,1320.0 ,13.23,0.0,3.8,2.3,0.0,13.55,4160,86.5,-4.0,-2.0,12.89,5680,106.0,1540.0,1300.0 ,14.17,0.0,3.8,2.3,0.0,14.48,4280,87.2,-4.0,-2.0,13.85,4200,92.5,1190.0,1380.0 ,15.08,0.0,0.0,0.0,0.0,15.38,3120,11.3,-4.0,-2.0,14.78,3920,64.7,1000.0,1280.0 ,15.99,0.0,0.0,0.0,0.0,16.28,3080,10.5,-4.0,-2.0,15.69,3120,10.5,1000.0,1080.0 ,16.89,0.0,0.0,0.0,0.0,17.19,2920,10.5,-4.0,-2.0,16.58,3040,11.3,1000.0,1040.0 ,17.79,0.0,0.0,0.0,0.0,18.09,2760,11.3,-4.0,-2.0,17.49,2880,10.5,1000.0,1030.0 ,18.70,0.0,0.0,0.0,0.0,19.00,2600,10.5,-4.0,-2.0,18.40,2720,10.5,1000.0,1020.0 ,19.60,0.0,0.0,0.0,0.0,19.90,2520,10.5,-4.0,-2.0,19.30,2560,11.3,1000.0,1020.0 ,20.51,0.0,0.0,0.0,0.0,20.81,2760,82.0,-4.0,-2.0,20.21,2600,20.3,1000.0,1010.0 ,21.42,0.0,0.0,0.0,0.0,21.71,2680,103.0,-4.0,-2.0,21.11,2720,93.2,1340.0,1230.0 ,22.33,0.0,0.0,0.0,0.0,22.62,2680,18.8,-4.0,-2.0,22.02,2680,103.0,1320.0,1380.0 ,23.22,0.0,0.0,0.0,0.0,23.52,2600,10.5,-4.0,-2.0,22.92,2600,9.8,1000.0,1090.0 ,24.13,0.0,0.0,0.0,0.0,24.43,2480,10.5,-4.0,-2.0,23.83,2560,10.5,1000.0,1030.0 ,25.03,0.0,0.0,0.0,0.0,25.33,2440,10.5,-4.0,-2.0,24.73,2480,15.8,1000.0,1020.0 ,25.94,0.0,0.0,0.0,0.0,26.24,2400,10.5,-4.0,-2.0,25.64,2440,10.5,1000.0,1010.0 ,26.84,0.0,0.0,0.0,0.0,27.14,2320,10.5,-4.0,-2.0,26.54,2360,11.3,1000.0,1010.0 ,27.75,0.0,0.0,0.0,0.0,28.05,2240,11.3,-4.0,-2.0,27.45,2320,10.5,1000.0,1010.0 ,28.65,0.0,0.0,0.0,0.0,28.95,2200,10.5,-4.0,-2.0,28.35,2240,11.3,1000.0,1010.0 ,29.56,0.0,0.0,0.0,0.0,29.86,2120,11.3,-4.0,-2.0,29.26,2160,10.5,1000.0,1010.0 ,30.46,0.0,0.0,0.0,0.0,30.77,2080,11.3,-4.0,-2.0,30.16,2080,11.3,1000.0,1010.0 ,231.65,0.0,0.0,0.0,0.0,231.95,680,29.3,-4.0,-1.0,231.34,640,29.3,1000.0,1000.0 ,232.54,0.0,0.0,0.0,0.0,232.85,640,30.1,-4.0,-1.0,232.24,640,29.3,1000.0,1000.0 ,233.46,0.0,0.0,0.0,0.0,233.76,640,29.3,-4.0,-1.0,233.16,680,30.1,1000.0,1000.0 ,234.36,0.0,0.0,0.0,0.0,234.65,640,30.1,-4.0,-1.0,234.06,640,29.3,1000.0,1000.0 ,235.26,0.0,0.0,0.0,0.0,235.57,640,29.3,-4.0,-1.0,234.96,640,29.3,1000.0,1000.0 ,236.16,0.0,0.0,0.0,0.0,236.46,640,29.3,-4.0,-1.0,235.87,640,29.3,1000.0,1000.0
Бензин Tuesday,17,January,2012,21:01:05 4Z7 907 551 H,,2.7l V6/5VT 0002, ,Group A:,'020,,,,Group B:,'093,,,,Group C:,'115 ,,Timing Retardation,Timing Retardation,Timing Retardation,Timing Retardation,,Engine Speed,Engine Load,Phase Position,Phase Position,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure ,TIME,Cylinder 1,Cylinder 2,Cylinder 3,Cylinder 4,TIME,(G28),,Bank 1,Bank 2,TIME,(G28),,(specified),(actual) Marker,STAMP,°KW,°KW,°KW,°KW,STAMP, /min, %,°KW,°KW,STAMP, /min, %, mbar, mbar ,0.25,0.0,0.0,0.0,0.0,0.54,680,31.6,-4.0,-2.0,0.84,680,30.8,1000.0,1000.0 ,1.17,0.0,0.0,0.0,0.0,1.45,1680,76.7,-4.0,-2.0,1.75,2040,82.7,1410.0,1020.0 ,2.06,0.0,0.0,0.0,0.0,2.36,2680,100.0,-4.0,-2.0,2.66,3200,111.3,1580.0,1330.0 ,2.97,0.0,0.0,0.0,0.0,3.27,4320,112.0,-4.0,-2.0,3.60,4920,107.5,1610.0,1320.0 ,3.95,0.0,3.0,0.0,0.0,4.30,5880,103.0,-4.0,-2.0,4.63,4640,118.0,1600.0,1380.0 ,4.95,0.0,3.0,0.0,0.0,5.25,4160,112.0,-4.0,-2.0,5.56,4360,110.5,1600.0,1350.0 ,5.88,0.0,2.3,0.0,0.0,6.20,4680,109.8,-4.0,-2.0,6.52,4840,109.0,1590.0,1340.0 ,6.87,3.0,2.3,0.0,0.0,7.20,5200,110.5,-4.0,-2.0,7.55,5400,108.3,1570.0,1310.0 ,7.89,3.0,4.5,3.0,0.0,8.25,5800,104.5,-4.0,-2.0,8.62,6040,103.0,1510.0,1280.0 ,8.99,2.3,4.5,3.0,0.0,9.37,6400,98.5,-4.0,-2.0,9.74,6080,105.3,1500.0,1300.0 ,10.07,2.3,4.5,3.0,0.0,10.40,4880,110.5,-4.0,-2.0,10.74,4920,110.5,1590.0,1340.0 ,11.08,5.3,4.5,3.0,0.0,11.41,5120,106.8,-4.0,-2.0,11.75,5240,107.5,1440.0,1340.0 ,12.09,5.3,3.8,2.3,0.0,12.45,5440,101.5,-4.0,-2.0,12.79,5520,103.0,1400.0,1320.0 ,13.14,4.5,3.8,5.3,0.0,13.50,5680,103.0,-4.0,-2.0,13.86,5760,105.3,1530.0,1300.0 ,14.23,4.5,6.0,5.3,0.0,14.56,5200,114.3,-4.0,-2.0,14.89,4360,112.0,1330.0,1420.0 ,15.20,4.5,6.0,5.3,0.0,15.51,4200,14.3,-4.0,-2.0,15.81,4120,11.3,1000.0,1120.0 ,16.11,0.0,0.0,0.0,0.0,16.40,3120,10.5,-4.0,-2.0,16.71,2800,9.8,1000.0,1050.0 ,17.01,0.0,0.0,0.0,0.0,17.31,2760,9.8,-4.0,-2.0,17.61,2680,9.8,1000.0,1030.0 ,17.91,0.0,0.0,0.0,0.0,18.22,2600,10.5,-4.0,-2.0,18.52,2560,10.5,1000.0,1020.0 ,18.82,0.0,0.0,0.0,0.0,19.12,2480,10.5,-4.0,-2.0,19.42,2640,66.2,1170.0,980.0 ,19.72,0.0,0.0,0.0,0.0,20.04,3800,104.5,-4.0,-2.0,20.34,3880,115.0,1650.0,1400.0 ,20.64,0.0,0.0,0.0,0.0,20.94,3920,115.0,-4.0,-2.0,21.24,3960,116.5,1620.0,1380.0 ,21.54,3.0,3.0,0.0,0.0,21.85,3880,115.0,-4.0,-2.0,22.14,3840,115.0,1600.0,1400.0 ,22.45,3.0,3.0,3.0,0.0,22.76,4080,115.0,-4.0,-2.0,23.09,5560,108.3,1560.0,1320.0 ,23.45,2.3,3.0,0.0,0.0,23.81,5840,104.5,-4.0,-2.0,24.17,5880,106.0,1520.0,1290.0 ,24.53,1.5,5.3,3.0,0.0,24.90,6040,103.0,-4.0,-2.0,25.27,6040,103.8,1500.0,1300.0 ,25.62,1.5,5.3,3.0,0.0,25.95,4520,116.5,-4.0,-2.0,26.27,4400,114.3,1590.0,1370.0 ,26.57,4.5,5.3,3.0,0.0,26.90,4440,113.5,-4.0,-2.0,27.22,4480,113.5,1590.0,1370.0 ,27.52,4.5,5.3,3.0,0.0,27.85,4480,43.6,-4.0,-2.0,28.16,4120,15.0,1000.0,1200.0 ,28.45,0.0,0.0,0.0,0.0,28.75,3240,10.5,-4.0,-2.0,29.06,3200,10.5,1000.0,1060.0 ,29.36,0.0,0.0,0.0,0.0,29.66,3160,10.5,-4.0,-2.0,29.96,3120,10.5,1000.0,1040.0 ,30.26,0.0,0.0,0.0,0.0,30.57,3080,10.5,-4.0,-2.0,30.87,3040,10.5,1000.0,1030.0 ,31.17,0.0,0.0,0.0,0.0,31.47,2960,10.5,-4.0,-2.0,31.77,2960,10.5,1000.0,1020.0
Ошибки Tuesday,17,January,2012,19:59:19:13314 VCDS Version: Release 908.0 Data version: 20090911 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.lbl Control Module Part Number: 4Z7 907 551 H Component and/or Version: 2.7l V6/5VT 0002 Software Coding: 26752 Work Shop Code: WSC 02325 Additional Info: WAUZZZ4B12N046517 AUZ7Z0A1932658 4 Faults Found: 17538 - Fuel Trim; Bank 2 (Mult): System too Lean P1130 - 35-00 - - 17887 - Brake Boost Vacuum System: Mechanical Failure P1479 - 35-10 - - - Intermittent 17536 - Fuel Trim; Bank 1 (Mult): System too Lean P1128 - 35-10 - - - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-10 - - - Intermittent Readiness: 0000 0000
недодув бедная смесь в тему про логи с таким букетом надо идти если только на бензине то ошибки по смеси интересно есть?
нет но кучка компрессоров лежит. хочу его после дроселя вонзить а это не удобно на 1.8. ставить пару турбу + компрессор на 1.8т не вижу смысла.
