A6 C6 Адаптивные фары AFS - функционал, ошибки, неисправности
Тема в разделе "4F C6", создана пользователем Канибал, 6 окт 2008.
  1. Leonov
    Leonov Новичок
    29 апр 2009
    85
    Ауди-А6
  2. АндрейР
    АндрейР Желаю чтобы все!
    19 апр 2004
    63.915
    A3\8P\2,0Т\Q
    #102 АндрейР, 10 дек 2013
    Нет там ничего и похожего в 55-ом блоке в адаптации.
    Coding
    0000016 = Audi A6 (4F) with Steel Suspension
    0000017 = Audi A6 (4F) with Air Suspension
    0000018 = Audi A8 (4E)
    0000019 = Audi A4 (8E)
    0000020 = Audi A3 (8P)
    0000021 = Audi Q7 (4L) with Steel Suspension
    0000022 = Audi Q7 (4L) with Air Suspension
    0000023 = Audi TT (8J) with Steel Suspension and Front Wheel Drive (FWD)
    0000024 = Audi TT (8J) with Steel Suspension and All Wheel Drive (AWD)
    0000025 = Audi TT (8J) with Magnetic Ride
    Note: Perform Security Access before Coding and Basic Setting (Headlight Adjustment) after Coding!
    Note: If coding is 0000255, then the module is NOT coded. Do not try to recode with 0000255.
    Security Access
    02000 = General Coding "Enabling"
    02000 > 03000 > 04000 > 05000 = General Adaptation "Enabling" (Enter one after another)
    Adaptation
    Channel 020: Showroom Effect
    After activating the showroom effect the dynamic cornering light at vehicle standstill can be demonstrated to the customer. The showroom effect remains active until the showroom effect is deactivated via the function program.
    0 = Disabled
    1 = Enabled
    Channel 023: Tourist Solution
    When driving in countries where driving is performed on the opposite side as in the native country the headlights must be changed over to avoid blinding the oncoming traffic.
    0 = Disabled
    1 = Enabled
    Basic Setting
    [Select]
    [55 - Xenon Range]
    [Basic Settings - 04]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
    Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
    [ON/OFF/Next]
    The adjustment should now be learned.
    [Done, Go Back]
    Don't forget to check/clear fault codes afterwards.
    [Close Controller, Go Back - 06]
  3. melkon
    melkon Суровый диагност
    21 сен 2005
    27.090
    Tuareg CR 3.0TDI
    А кто самому попробовать мешает ? Лезем в приборку и пишем что фары калоген ,потом в 19 адрес и косим оттуда блок фар... потом вынимаем пред 55 блока ... Но получаем вместо индикации на приборке косо светящие фары в итоге .
  4. forward
    forward Завсегдатай
    1 янв 2003
    756
    A6/4F 3.2Q BKH 05г
    Шнурка нет у меня
  5. Leonov
    Leonov Новичок
    29 апр 2009
    85
    Ауди-А6
    #105 Leonov, 24 янв 2014
    Может кто то еще по этой теме подскажет или у кого получилось отключить эту функцию чтоб на приборке не загоралось ошибка AFS.Да я немного не дописал у меня авто с AFS и как эту функцию убрать с панели не могу найти информацию
  6. melkon
    21 сен 2005
    27.090
    Tuareg CR 3.0TDI
    А ты что читать не пробовал что выше я написал ? Зачем раз в месяц одно и то же спрашивать то ?
  7. Андрей1232
    Андрей1232 Новичок
    26 янв 2012
    31
    A6 C6 2.0T 10г
    Привет.Такая проблема,когда заводишь линзы двигаются вверх,вниз,влево,вправо,но в движении они не поворачиваются.В чем проблема?Отключаемая ли эта функция?
    п.с. Ксенон плюс
    И такой вопрос.Имеется Адаптивный круиз в меню Car он есть,а Audi Braking Guard нет.На А6 шел ABG или нет?Если да,куда он пропал?
  8. igor33
    igor33 Заблокирован
    19 июн 2010
    19.978
    А6/С6 3.0i Q 05
    Поворачиваются с 30 или 40 км/ч.
  9. valex470
    valex470 инжеНЕГР
    24 янв 2011
    1.368
    Тюменская обл.
    Q7 4m 3.0 TDI `16 7seats
    вроде с 40
    вообще то когда заводишь, то фары только вверх-вниз двигаются... вправо-влево только через тест исполнителей
    или на рестайле по другому?
  10. Андрей1232
    Андрей1232 Новичок
    26 янв 2012
    31
    A6 C6 2.0T 10г
    Это я знаю,что они поворачиваются с определенной скорости.
  11. Андрей1232
    Андрей1232 Новичок
    26 янв 2012
    31
    A6 C6 2.0T 10г
    на А4 Б7 также было вверх,вниз,влево,вправо
  12. pa-shocka4
    pa-shocka4 Старожил
    4 ноя 2008
    8.846
    Любопытный момент! У себя наблюдаю только вверх-вниз при заводке и во время движения на малой скорости изменение угла светового луча. А как узнать адаптивные фары или нет в плане поворотов вправо/влево, в комплектации как это прописано? (фары би)
  13. АндрейР
    19 апр 2004
    63.915
    A3\8P\2,0Т\Q
    #113 АндрейР, 11 июл 2014
    Да, прописано, вот так у меня:
  14. pa-shocka4
    pa-shocka4 Старожил
    4 ноя 2008
    8.846
    Да, нашел. Только оказалось что у меня без поворотов(((
    8Q3 Регулировка угла наклона фар, в авт. режиме,
    динамическая (регулировка производится в
    движении)
  15. igor33
    igor33 Заблокирован
    19 июн 2010
    19.978
    А6/С6 3.0i Q 05
    Перестаньте сказки рассказывать, тут же не BNV форум, люди немного в курсе.
    Только вверх - вниз.
  16. Андрей1232
    Андрей1232 Новичок
    26 янв 2012
    31
    A6 C6 2.0T 10г
  17. Сергей-013
    Сергей-013 Участник форума
    27 апр 2014
    497
    2.4 BDW 04.г МКПП
    без снятия фары, как я понимаю, не решить проблему?
  18. 1.Kla$
    1.Kla$ Завсегдатай
    11 сен 2008
    695
    Германия
    AMG GT
    Снимать то в любом случае, иначе не подлесть
  19. Сергей-013
    27 апр 2014
    497
    2.4 BDW 04.г МКПП
    буду надеяться что переломился проводок, потому что ошибка сначала периодически загоралась, а сейчас не гаснет и пишет что в левой фаре обрыв цепи или замыкание на массу.
  20. allroad_fan
    allroad_fan Новичок
    22 янв 2013
    56
    allroad c6 3.0tdi
    новый моторчкик стоит 40 евро .
    Зачем покупать новую фару...
