J0LBattery 340 A (70 Ah) Ниже полная расшифровка твоего вина по комплектации. Äàííûå àâòîìîáèëÿ Áóêâåííîå îáîçíà÷åíèå äâè Áóêâåííîå îáîçíà÷åíèå ÊÏ Èäåíòèôèêàòîð ïðèâîäà îñå Îñíàùåíèå Öâåò êðûøè Íàðóæíàÿ êðàñêà 15:0020.02.2010 ÎðèãèíàëÑïåöèô. ïîëüçîâà AQD ECD 5A BR L5 L5 Íîìåðà PR 0YUWeight range 19 installation control only, no requirement forecast 1ATElectronic stabilization program (ESP) 1BAStandard suspension/shock absorption 1C1Antifreeze up to -25 degree celsius tolerance up to -30 degree C 1D0Without trailer hitch 1E1Activated carbon canister 1EXSpecial identification plate for EC for M1 passenger vehicle 1G3Alloy spare wheel with original equipment tires 1KDDisc brakes, rear 1LBDisc brakes, front 1N1Power steering 1PCWheel bolts with anti-theft protection (unlockable) 1S7Tool kit and aluminum jack 1SAWithout additional engine guard 1T3First aid kit with warning triangle 1VHInstallation parts for six-cylinder engine 1WDTransmission shaft for tripod joints 1X1Four wheel drive 1YCTransmission shafts for rear axle diameter 100 1Z2Increase in initial standard fuel filling 2A4Delivery equipment for shipment (transit coating) with thick seat cover 2B0Without additional exterior noise suppression 2C5Axial and vertical adjustable steering column 2G1Insert for the filling up of unleaded fuel 2K1Reinforced bumpers 2PVLeather trimmed sports steering wheel 2T0Without double-sized standard (DIN) 2WAWithout additional tires 2Z0Deletion of model designation 3B0Without additional child seat anchor 3C73-point seat belt for center rear seat 3CBRemovable net partition 3FAWithout roof insert (standard roof) 3GDPlane rear cargo area 3HAWithout leather parts scope 3L5Electric seat adjustment for both front seats 3NZRear seat bench unsplit, backrest split folding 3Q6Three rear headrests et_fd2.frm Äàííûå àâòîìîáèëÿ 15:0020.02.2010 Íîìåðà PR 3S2Black roof rails 3V0Without child bench seat 3X0Without load-through provision 3Y0Without roll-up sun screen 4A4Seat heater for front and rear seats separately controlled 4E0Tailgate/trunk lid unlocking from outside 4GKLaminated windshield with metal layer, with sunshield 4K4Radio remote controlled central locking 4KVSide and rear windows in laminated glass with metal layer 4L2Dipping breakaway interior rear view mirror 4LAWithout controls 4M0Without cup holder 4N0Standard dashboard 4SDLeft vanity mirror, illuminated 4TDRight vanity mirror illuminated 4UEAir bag for driver and front seat passenger 4W0Without cassette and CD storage unit 4X2Side air bag, front and rear 5A5Trunk lining, with stowage trays 5C0Without special body measures 5D1Carrier frequency 433.92 MHz-434.42 Mhz 5E2Sill top with door cover 5K1Paint preservative (wax) 5MZDecorative inserts, stainless steel -fabric 5RQRight exterior mirror: convex 5SLLeft exterior mirror: aspherical 6E3Front center armrest 6FBBody-colored exterior mirror housings 6M1Tie down straps 6PAPlastic hand brake lever handle 6Q2Leather gearshift knob/handle 6R0Selector lever cover 6U0Without additional seals outside 6V1Rear trim panel (ECE) 6W5Front license plate bracket 6XDExterior mirrors: electrically adjustable/heated 7A2CD changer 7CAWithout label for radio remote control 7E0W/o heat accumulator/auxiliary heating 7K0Without tire pressure warning light 7M1Scuff plates in door apertures with metal inserts 7P1Power adjustable lumbar support in front seats 7Q0Without navigation device et_fd2.frm Äàííûå àâòîìîáèëÿ 15:0020.02.2010 Íîìåðà PR 7QAWithout CD/DVD for navigation 7X0Without park distance control 8CCSpeedometer sensor without seal (electronic speedometer sensor) 8GLAlternator 120 A 8JGHeadlight with gas discharge lamp for driving on the right 8K0Without special headlight activation 8Q2Automatic headlight-range adjustment static 8RYSpeakers with BOSE sound 8T0Without cruise control system (CCS) 8TCRear fog light for driving on the right 8UDRadio "concert" 8WBFront fog lights 8X1Headlight washer system 8Z5Not hot country 9AKClimatronic with impact pressure control free of cfc 9B0Without telepay device 9M0Without auxiliary/parking heater 9P0Without seat belt reminder 9Q2Multi-function display/on-board computer with check control 9V7Electronic vehicle immobilization device with anti-theft alarm system and passenger compartment control 9W0W/o car phone preparation/installation et_fd2.frm
расшифровка у меня почему то ироглифами. я правильно понял батарейку любую на 70 ампер? там больше никаких параметров нет?
Я просто не умею по другому, иероглифы, это где русский язык был. В остальном надо скопировать и вставить в любой файл и откат-проворот перед каждым кодом сделать типа Íîìåðà PR 0YUWeight range 19 installation control only, no requirement forecast 1ATElectronic stabilization program (ESP) 1BAStandard suspension/shock absorption 1C1Antifreeze up to -25 degree celsius tolerance up to -30 degree C это Íîìåðà PR 0YU Weight range 19 installation control only, no requirement forecast 1AT Electronic stabilization program (ESP) 1BA Standard suspension/shock absorption 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C и так далее. И получится комплектация, в которой автомобиль сошел с конвеера. Батарея штатная была 70 А с пусковым током 340 А. а ставить лучше максимальной емкости, которая влезет на штатное место и на которую не жалко денег.
МУЖЧИНЫ ХЕЛП. Затупил капитально. Как снять аккумулятор. Фишку которая его фиксирует вытащил он двигается вправо в лево а вытащить никак. И второй попутный где там дренаж, в отсеке . Вода плещется - пару стаканов. Есть резиновая плямба размером со спичечный коробок. Я ее сейчас продавил - вода вылилась. Закрою Снова наберется. И третий вдогонку - что за пластиковая гофрированная трубочка направлена на аккумулятор с диаметром дырочки со спичку. Подогрев какой то? Блин - как эта сука вытаскивается? Он свободно движется но вверх не могу вытащить . По ходу что то еще открутить надо
