B8 2.0TDI 125kw CAHA 2011 жрёт масло не по детски :/
Тема в разделе "Дизельные двигатели", создана пользователем android22, 25 сен 2017.
  1. UTUG
    UTUG Властелин 8-ми колец
    7 ноя 2005
    22.136
    Allroad AKE МКПП
    Да, не много, но ездить можно еще.
    Изза этого масло жрать не должно.
  2. android22
    android22 Новичок
    25 сен 2017
    39
    Германия
    Audi A4 Avant B8 2.0TDI CAHA 125kw
    Или я тупой или лыжи не едут.....вот что нашол:
    2.0 R4 16v TDI CR 81-176kW[edit]
    The EA189 engine is the focus of the Volkswagen emissions scandal.[17][18]
    identification
    Motor type: EA189 / parts code prefix: 03L, ID codes: CAGA, CAGC, CAHA, CBEA, CBAB, CFFB, CFFD, CBBB, CBDB, CBDC, CEGA, CFGB, CFCA, CFJB, CJAA, CLJA
    Motor type: EA288[19]
    engine configuration & engine displacement
    inline four-cylinder (R4/I4) Turbocharged Direct Injection (TDI) turbodiesel; 1,968 cubic centimetres (120.1 cu in); bore x stroke: 81.0 by 95.5 millimetres (3.19 in × 3.76 in), stroke ratio: 0.85:1 - undersquare/long-stroke, 492.1 cc per cylinder, compression ratio: 18:1 (103 kW), 16.5:1 (125 kW)
    cylinder block & crankcase
    grey cast iron; five main bearings, die-forged steel crankshaft, fracture-split forged steel connecting rods, two counter-rotating gear-driven balance shafts turning at half crankshaft speed, Alcan or Federal-Mogul pistons, cast aluminium alloy oil sump
    cylinder head & valvetrain
    cast aluminium alloy; four valves per cylinder, 16 valves total, low-friction roller finger cam followers with automatic hydraulic valve clearance compensation, timing belt and gear-driven (relay method: belt drives exhaust camshaft from front of engine, inlet camshaft is driven at rear of engine by gear from exhaust camshaft) double overhead camshaft (DOHC)
    aspiration
    hot-film air mass meter, electronically regulated variable geometry turbocharger integrated into cast iron exhaust manifold, central front-mounted intercooler (FMIC)
    aspiration (147 kW)
    twin registered turbochargers with different diameters[citation needed]
    fuel system & engine management
    low-pressure fuel tank mounted fuel lift pump with underfloor electric fuel relay pump, timing belt-driven high-pressure injection pump delivering up to 1,850-bar (26,830 psi) pressure for the common rail(CR) fuel rail, direct injection (DI) with eight-nozzle output piezo fuel injectors; Bosch EDC 17 electronic engine control unit (ECU)
    exhaust system
    water-cooled exhaust gas recirculation (EGR), catalytic converter, diesel particulate filter (DPF), nitrogen oxide catalytic converter, sulphur catalytic converter.[4]
    получается, что в мастер ошибся сказав мне что компрессия у меня на минимуме?
  3. android22
    android22 Новичок
    25 сен 2017
    39
    Германия
  4. Мазаи
    Мазаи Старожил
    13 окт 2013
    5.477
    A8/D2 2,5 TDI AFB
    Это степень сжатия.
  5. UTUG
    7 ноя 2005
    22.136
    Allroad AKE МКПП
    #25 UTUG, 29 сен 2017
    Чувак, загугли "степень сжатия и компрессия различия" !
    Например на моторах 2.5 степень сжатия от 18.5 до 19.5, а коспрессия с завода при этом 28-32 бара.
    делай выводы.
    На вскидку, для твоего движка с завода скорей всего было около 25 бар.
    20 бар, в твоем случае не айс (среднеизношен), но ездить можно.
    Советую перемерить в другом месте, да и кстати, измерения нужно делать на теплом движке.
  6. Мазаи
    Мазаи Старожил
    13 окт 2013
    5.477
    A8/D2 2,5 TDI AFB
    В первоисточнике было "исчо".
  7. nostoy
    nostoy Живу я здесь
    20 окт 2016
    1.461
    Ку 5 CAHA МКПП
    не путай человека :)
  8. android22
    android22 Новичок
    25 сен 2017
    39
    Германия
    так сколько должна быть нормальная компрессия на CAHA 125kw? Не-где в интернете нечего не нашол про CAHA компрессию.
    И главний вопрос остался......куда деётся МАСЛО?!!!!!! Окей, перемерю компрессию. Что если замеры будут такими же? Где искать жыробаса который всё сжирает?
    Может кто знает на 100% какой должна быть компрессия на исправном CAHA двигателе? Думаю завтро опять разобрать воздушник глянуть тырбу, и замерить точно на сколько там всё плохо, потомы хто Я етим чертам не доверяю. Германия (мне нравится, но когда дела доходит до авто ремонта) хочется уехать отсюда :evil_wife: 102 евро за проверку турбины и замер компрессии :hot:
  9. ВасиличЪ43
    ВасиличЪ43 Старожил
    19 фев 2015
    7.298
    Кировская обл.
    Безлошадный..
    Да. Пару раз делал. Для профилактики.
    После удаления ЕГР.
  10. nostoy
    nostoy Живу я здесь
    20 окт 2016
    1.461
    Ку 5 CAHA МКПП
    Это двигло, оно всегда что то жрет. Не думаю, что через поршневую будет уходить большое количество масла. Смотри резинки, прокладки, сальники, колпачки, коль турбину отмели. Если масло поступает в цилиндр, видно по выхлопу
  11. UTUG
    7 ноя 2005
    22.136
    Allroad AKE МКПП
    У него не много жрет пока еще, по выхлопу не заметить.
  12. android22
    android22 Новичок
    25 сен 2017
    39
    Германия
    1 литр на 800 километров, по мне так ето зверски! :dizzy: учитавая что масло стоит 5 литров 39.95 евро
  13. android22
    android22 Новичок
    25 сен 2017
    39
    Германия
    забыл добавить....что если попробывать не Лонглаиф 5в30 а 5в40 залить? И что может случится с сажевым фильтром из за такова обьёма выхлопных газов? Просто я считаю что выхлопа не видно по тому что сажевик всё поглощает.
  14. sl1220
    sl1220 Старожил
    15 сен 2011
    8.260
    A6/C5 2.5 AKE 01г.
    У друга, правда на Ниссане, что-то тож заметили дикий расход. Катался он на Кастроле. Сменили масло и все вернулось в норму. Может палево не только у нас продается.
    А насчет компрессии, ориентируйся на такое степень сжатия * 1,4 или 1,5 т.е. 16,5*1,4~ 23; 16,5*1,5~25. Соотношение примерное, но вполне рабочее.
  15. android22
    android22 Новичок
    25 сен 2017
    39
    Германия
    понятно, тогда UTUG прав был насёт компрессии, что среднеизношен. До етого у меня был, Кастрол. Но на прошлой замене залил ЛиквиМоли. Теперь долеваю Кастрол, уже 3 литра долил - незнаю, наверна масло не виновата в моём случае.
    Сегодня снова глянул турбину, и видно присутствие масло, хотя когда в прошлую суботу смотрел. И перед тем как соберать всё назад патрубки все вытер и поставил всё сухое.
  16. sl1220
    sl1220 Старожил
    15 сен 2011
    8.260
    A6/C5 2.5 AKE 01г.
    Масло в патрубках в виде налета это нормально. Тебе б интеркуллер снять да глянуть, если оттуда польется, то на турбу можно грешить.
    А вообще, на 2 л. Ваговских моторах даже заводом признан большой расход масла, слышал такое.
  17. android22
    android22 Новичок
    25 сен 2017
    39
    Германия
    Большой ражод масло на TFSI двигательях. А на TDI не должно быть, тем более такой.
  18. UTUG
    7 ноя 2005
    22.136
    Allroad AKE МКПП
    Слава не путай масложер на TSI до 2011 гг, это отдельная история.
    С TDI таких проблем не было.
    Андроид22, кстати насчет масла, Касторол и Ликви-Моли оооочень сильно страдают от подделок, так что эта версия довольно вероятна.
    Залей для проверки Лукойла, например покруче Genesis 5-30, неплохое масло, покатайся. Хуже точно не будет.
  19. юрий.в.
    юрий.в. Старожил
    25 сен 2010
    5.458
    A6/C5 2.5TDI AQ 99
    В Германии он его не найдёт!)))
  20. юрий.в.
    юрий.в. Старожил
    25 сен 2010
    5.458
    A6/C5 2.5TDI AQ 99
    HESSOL найди вот такое масло,отличное масло,делается в Германии.
