  1. ura71
    ura71 Участник форума
    23 фев 2011
    211
    А4 b8 2008
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
    VIN: WAUZZZ8K88N024419 Mileage: 108290km/67288miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (------CABB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K1 907 115 A HW: 8K1 907 115
    Component: 1.8l R4/4V TF H07 0004
    Revision: A5H07---
    Coding: 0104000318070118
    Shop #: WSC 02145 785 00200
    ASAM Dataset: EV_ECM18TFS8K1907115A A01005
    ROD: EV_ECM18TFS8K1907115A.rod
    VCID: 2C5C1834F68D
    2 Faults Found:
    2967 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
    P2015 00 [096] - Short to Ground
    2968 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
    P2015 00 [236] - Implausible Signal
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 54
    Mileage: 105723 km
    Date: 2011.11.26
    Time: 16:12:06
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 P HW: 8K0 907 379 P
    Component: ESP8 front H04 0180
    Revision: -------- Serial number: --------------
    Coding: 030500
    Shop #: WSC 02399 823 56573
    VCID: 46884A9C4821
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 212
    Mileage: 107202 km
    Time Indication: 0
    Date: 2011.12.05
    Time: 19:45:33
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x00A2
    Hex Value: 0x0221
    Hex Value: 0x168E
    Hex Value: 0x00FF
    Добрый день Помогите расшифровать ошибки сегодня загорелся чек у меня паника. Что делать
  2. melkon
    melkon Суровый диагност
    21 сен 2005
    27.088
    Tuareg NF 3.0TDI на пневме.
    Проблема с датчиками положения заслонок впускного коллектора или с самим коллектором . В теме есть описание по ним и по процедурам диагностики . Худшее что может быть это замена впускного коллектора всборе.
    По АБС звучит так "ограничение функций из-за низкого напряжения" ... Аккум в норме ?
  3. melkon
    21 сен 2005
    27.088
    Поиск рулит ,особенно в разделе по олроуду 4B . Там столько всего понаписано :nod:
  4. K.Killerovich
    K.Killerovich Новичок
    7 авг 2011
    68
    Audi Q7 S-line
    Коллеги, так а чреватость езды с моей ошибкой?
  5. melkon
    21 сен 2005
    27.088
    Аварийный режим с ограничением мощности.
  6. rammstein_andrei
    rammstein_andrei Новичок
    16 авг 2011
    11
    A4/B5 ARG 1.8 00г.
    Добрый день!
    помогите определиться... вот ошибки.
    17763 - Управление зажиганием, цил. 1: обрыв цепи
    P1355 - 35-00 - -
    17769 - Управление зажиганием, цил. 3: обрыв цепи
    P1361 - 35-00 - -
    16486 - Расходомер воздуха-G70: слишком низкий уровень сигнала
    P0102 -35 – 10 - -- спорадическая
    17524 - Ряд 1-зонд 1, обрыв электрической цепи подогрева
    Р1116 – 35 – 10 - -- спорадическая
    16518 - Ряд 1-зонд 1: нет активности
    P0134 – 35 – 10 - -- спорадическая
    дмрв, катушка зажигания, провода новые.
    На хх может заглохнуть, иногда при разгоне подтупливает, на хх вибрация. Почистил ДЗ, форсунки, ВКГ, поменял все резинки, прокладки, стало лучше, не так часто тупит...
    Теперь думаю... что дальше? Всётаки лямбда сдохла? Катализатора нет, пламягаситель.
  7. K.Killerovich
    7 авг 2011
    68
    Audi Q7 S-line
    Все нужно по слову вытаскивать....
    1.Аварийный режим чего? Коробки, двигателя? Чего?
    2.Можно ли ездить или нет?
  8. melkon
    21 сен 2005
    27.088
    Уважаемый ! Вы чего хотитите ? Ездить ? Дык ездите ,как вам может кто то это запретить ? То что мотор будет сваливаться в аварийный режим вы почуствуете собственным седалищем - Жигули когда обгонять начнут ... А так передвигаться современный авто может без двух третей компонентов навешеных на него .
  9. melkon
    21 сен 2005
    27.088
    :shock::shock::shock:
  10. rammstein_andrei
    16 авг 2011
    11
    A4/B5 ARG 1.8 00г.
    Закажу бошевскую лямбду, посмотрю...
  11. rammstein_andrei
    16 авг 2011
    11
    A4/B5 ARG 1.8 00г.
    проводку проверял...
  12. dark-86
    dark-86 Участник форума
    19 окт 2009
    298
    Audi 100 2.8AAH
    Подскажите,что это за ошибка???
    18107 - Шина данных-привод: отсутствие сообщения от блока управления рулевой колонки
    P1699 - 008 - Неправдоподобный Сигнал - Спорадическая
    Готовность: 0000 0000
  13. melkon
    21 сен 2005
    27.088
    Проверка такая - зайти в 124-127 гр приборки и посмотреть что видит она на шине КАН .потом то же самое в моторе сделай (не указал из какого блока ошибка то ..) Если в нормальных условиях руль виден то думай в каком режиме он пропадает . Сигнализация нештатная есть например ?
  14. ivan2612
    ivan2612 Участник форума
    19 окт 2011
    306
    А6С5
    добрый день
    недавно загорелся значок подушек безопасности
    сегодня пришёл кабель протестил получилось вот что
    Кодирование: 00106
    Код Сервиса: WSC 02325
    6 Найдены неисправности:
    65535 - Неисправен блок управления
    00-10 - - - Спорадическая
    00588 - Пиропатрон подушки безопасности водителя-N95
    32-10 - значение сопротивления слишком велико - Спорадическая
    00589 - Пиропатрон 1 подушки безопасности переднего пассажира-N131
    01211 - Пиропатрон преднатяжителя ремня заднего сиденья со стороны водителя-N196
    01217 - Пиропатрон боковой подушки безопасности водителя-N199
    01218 - Пиропатрон боковой подушки безопасности переднего пассажира-N200
    в чём проблема, и что делать?
  15. melkon
    21 сен 2005
    27.088
    Что вот так просто взял и загорелся ? :D
  16. ivan2612
    19 окт 2011
    306
    А6С5
    бывший хозяин сказал что перегорела или что то случилось с какой то релюшкой.
  17. melkon
    21 сен 2005
    27.088
    Бывший хозяин надо сказать жуткий шутник :lol:
    А то что возможно машина в узел была завязана он забыл упомянуть ...
    Ошибки если стереть то что остается ?
  18. ivan2612
    19 окт 2011
    306
    А6С5
    #5398 ivan2612, 13 дек 2011
    машина не была бита, только немного переднее правое крыло и всё.
    ошибки не стираются
    только позвонил бывшему хозяину, он сказал что когда ставили сигналку повредили какой то блок и сказали что теперь его надо перепрошивать.
    возможно ли такое?
  19. melkon
    21 сен 2005
    27.088
    65535 - это ошибка по чек сумме софта блока айрбэг . Можно поробовать перешить ну или заменить его . Но я бы все же посмотрел есть ли физически подушки там где по ним ошибки .
  20. ivan2612
    19 окт 2011
    306
    А6С5
    все подушки на месте, сегодня всё облазил. сколько примерно стоит перепрошивка и новый блок.
