  1. Mikheev89
    Mikheev89 Новичок
    19 апр 2011
    64
    A6 2.8 2010
    привет
    помогите пожалуйста разобраться :shock:
    пробовал скидывать, но появляются заново:confused:
    Monday,24,December,2012,20:08:05:10074
    VCDS Version: Beta 11.3.0
    Data version: 20110801
    Chassis Type: 8T0
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
    VIN: WAUZZZ8K09N074460 Mileage: 20020km/12439miles
    09-Cent. Elect. -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H26 0253
    Revision: 05026001 Serial number: 00000000245328
    Coding: 260050954034AF010001000300001D0D4F1C430800010141000000
    Shop #: WSC 02391 823 56573
    VCID: 306B14F3DF07
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119
    Component: WWS 070409 H06 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
    Component: E1 - LDS H07 0090
    1 Fault Found:
    00156 - Control Circuit for Windshield Washer Pump
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 19614 km
    Time Indication: 0
    Date: 2012.12.20
    Time: 13:53:00
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 930 A HW: 8K0 920 930 A
    Component: KOMBIINSTR. H18 0224
    Revision: 00200000 Serial number: 9DZ50K649
    Coding: 0007080002000008010000
    VCID: 2B51039FF621
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 20
    Mileage: 17445 km
    Time Indication: 0
    Date: 2012.09.26
    Time: 14:59:30
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0095
    Revision: GB300043 Serial number: 4300G094038205
    Coding: 000303
    VCID: 4B91631F56E1
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H06 0160
    1 Fault Found:
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 15
    Reset counter: 109
    Mileage: 19201 km
    Time Indication: 0
    Date: 2012.12.15
    Time: 07:56:00
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000008687068
    Coding: 011C02204000410001
    VCID: 418D413764AD
    No fault code found.
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Part No SW: 8K0 907 064 AL HW: 8K0 907 064 AL
    Component: BCM2 1.1 H80 0145
    Revision: 00002001 Serial number: 0117726778
    Coding: 0100062000390400033001
    VCID: 7AFFF6DB49FB
    2 Faults Found:
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 55
    Reset counter: 79
    Mileage: 11618 km
    Time Indication: 0
    Date: 2012.08.11
    Time: 12:29:37
    02616 - Fuel Tank Cap; Unlock
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 2
    Fault Frequency: 101
    Reset counter: 122
    Mileage: 11819 km
    Time Indication: 0
    Date: 2012.08.12
    Time: 21:17:05
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000008741339
    VCID: 408B44336FA7
    2 Faults Found:
    00110 - Right Mirror Turn Signal Lamp (L132)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 89
    Mileage: 18705 km
    Time Indication: 0
    Date: 2012.10.17
    Time: 20:05:09
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 25
    Reset counter: 120
    Mileage: 18707 km
    Time Indication: 0
    Date: 2012.10.18
    Time: 18:05:20
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
    Component: Concert3 H02 0310
    Revision: 00000005 Serial number: AUZ5Z6I1197912
    Coding: 0503008001010500835B070003
    VCID: 448348237BBF
    Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
    Component: Display
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 122
    Mileage: 20028 km
    Time Indication: 0
    Date: 2012.12.24
    Time: 19:37:15
    Freeze Frame:
    Bin. Bits: 00000000
    Bin. Bits: 00000001
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    End ---------------------------------------------------------------------
  2. YooHaa
    YooHaa Участник форума
    7 фев 2012
    140
    A4B5 1.8TQ USA St2
    Привет всем!
    А4 В5 АВС 5АКПП 96год
    проблемы:
    При резком ускорение,обгоне примерно с 40-50км/ч до 130,после завершение маневра переключаю на N и ХХ держиться в районе 3500-4000 об/мин. Далее через минуту уходит резко в низ к 1000,и начинает плавать от 900-1400,выключаю,включаю все оК.Вчера посмотрелтемы, снял патрубки и в жарил по трассе итог след ошибки
    Версия VAG-COM: Релиз 311.2-N
    Номер Контроллера: 4A0 907 473 D
    Компонент и/или версия: 2,6l V6 MPFI HS D05
    Кодирование: 00036
    Код Сервиса: WSC 85555
    4 Найдены неисправности:
    00537 - Лямбда-регулирование
    19-10 - нижнее предельное значение - Спорадическая
    00535 - Первичное регулирование зажигания по детонации
    00536 - Вторичное регулирование зажигания по детонации
    17978 - Блокирован блок управления двигателя
    P1570 - 35-10 - - - Спорадическая
    Стер их и снова по газам, опять повторилось но ошибок нет!
    Весь в расстерянности, ах да началось это после чистки коллектора и походания на улице, заметил такое проявление начиная от -10 и т.д.
    ГРМ менялся 10 тыс назад,свечи так же, масло свежее, провода высоковольтные тыс 4 назадпоменяны, форсунки чистые, фильтра все заменяны. Еще нюанс в городе небывает такого, только трасса...но у меня работа в другом городе, и постоянно борюсь с этим :(
  3. Hitman
    Hitman Завсегдатай
    22 май 2004
    903
    Audi-Q7,15г,3tdi
    Позавчера еду домой, тачка еще не прогрета до конца (гр 70 показывает) морозец, висели две ошибки (самые первые), так вот неожиданно тачка затроила и загорелась EPC, остановился, троит, заглушил. Завел, все ок. доехал до дома, подключил и вот еще ошибки добавились. Подскажите они все взаимосвязаны, первые две уже висят сначала морозов, стирал несколько раз...
  4. $BAKS$
    $BAKS$ Участник форума
    7 сен 2012
    259
    A6C6 2.0T 07г.
    Ребят подскажите по ошибкам а/м А6С6 3,0D 2005г.в.
    Что копать куда смотреть
    19804, 17953, 18358, 17471, 17981
  5. Hitman
    Hitman Завсегдатай
    22 май 2004
    903
    Audi-Q7,15г,3tdi
    для начала сотри, и посмотри, что появится снова, а там уже искать решения..
  6. $BAKS$
    7 сен 2012
    259
    A6C6 2.0T 07г.
    Уже стирал, потом они снова появляются.
    Начинает моргать спиралька и машина начинает глохнуть на ХХ все ок
  7. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    Краткость -сестра таланта, только здесь наоборот. Почему то некоторые полностью протокол кладут, а некоторые цифры напишут , как шифровки.
  8. svv75
    svv75 Участник форума
    16 дек 2005
    307
    а6 4f 3.2 Q 07г
    вопрос а6 3.2 07г...
    вчера при заводке появился нехарактерный звук- треск-лязг ...
    загорелся чек...
    я в свое время начитался про проблемы цепей-натяжителей, поэтому заглушил нахрен пошел за компом....
    ошибка вылазит (сбрасываю, снова вылазит)
    Контроллер 01: Двигатель Описания: Нет
    Номер детали контроллера: 4F2 910 559 E HW: 4F1 907 559 D
    Компонент и/или Версия: 3.2l V6 FSI 0020
    Код ПО: 01050003190F0120
    Код СТО: WSC 02325 758 00200
    VCID: 2E5919C8B90C649
    1 Ошибка найдена:
    000870 - Датчик положения распредвала=>датчик-G300
    P0366 - 006 - недостоверный сигнал
    Момент неисправности:
    Статус ошибки: 00010001
    Приоритет ошибки: 4
    Частота ошибки: 1
    Сброс счетчика: 40
    Пробег:: 97184 km
    Индикация времени: 0
    Дата: 2012.12.26
    Время: 20:30:59
    Об/мин: 1248 /min
    Масс.расх/ Rev.: 305.2 mg/str
    Температура: -3.0°C
    Холостой ход
    Биты: 00010000
    Скорость: 0.0 km/h
    смотрю 93 группу там 3.8 7.5 31.9!!!! 4.1
    прогревать, газовать не стал...
    вопрос- новый год отменять?:shock:, это что перескок цепи?... или... чето-то еще может быть....
    своим ходом до сервиса не ехать?
    до вчерашнего дня симптомов никаких не было...
    вообщем растроился -голова не соображает
  9. melkon
    melkon Суровый диагност
    21 сен 2005
    27.088
    Tuareg NF 3.0TDI на пневме.
    Думаю что тут обрадовать будет нечем . Надо вскрывать крышки задние и определять величину потерь ... Судя по тому что видно в 093 гр выпускной вал по правой стороне стоит раком так что мама не горюй ...
  10. svv75
    16 дек 2005
    307
    а6 4f 3.2 Q 07г
    спасиб...
  11. Тото
    Тото Новичок
    20 ноя 2012
    33
    audi80 В3 1.8 88г
    Всем привет. И мне подскажите, пожалуйста.
    А4/Б7 1.8Т BFB
    Адрес 08: авто HVAC (отопл.вент.кондиц.)
    00474 – Блок управления иммобилайзера
    49-10 – нет связи – прерывистый
    27-10 – недостоверный сигнал – прерывистый
    Адрес 17: инструменты
    01179 – неправильное программирование ключа
    000 - -
    Адрес 46: Центр.Комфорт
    00955 – Ключ 1
    35-10 - - - прерывистый
    00956 – Ключ 2
    00932 – Электродвигатель стеклоподъемника на стороне водителя (V147)
    62-10 – отсутствует или неверная подборка – прерывистый
    00933 – Электродвигатель стеклоподъемника на стороне пер. пас. (V148)
    00935 – Электродвигатель заднего правого стеклоподъемника (V27)
    62-10 – отсутствует или неверная подборка - прерывистый
  12. Goba Jaba
    Goba Jaba Живу я здесь
    16 апр 2006
    1.961
    с машиной-то что делали, как она себя вообще чувствует?
  13. Hitman
    Hitman Завсегдатай
    22 май 2004
    903
    Audi-Q7,15г,3tdi
    повторяю вопрос
  14. melkon
    21 сен 2005
    27.088
    Ошибки в какой то мере связаны ,в последней старина Росс даже дал наводку по одному из компонентов что проверять ... Ты мой вопрос про фото места расположения датчика давления почему игноришь ,нет желания понять проблему или просто лень ?
  15. Hitman
    Hitman Завсегдатай
    22 май 2004
    903
    Audi-Q7,15г,3tdi
    #8715 Hitman, 28 дек 2012
    Выкладываю фото
  16. Тото
    Тото Новичок
    20 ноя 2012
    33
    audi80 В3 1.8 88г
    Да с машиной все нормально, тьфу 3-и раза. Просто один ключ старый владелец потерял и делал новый за день до оформления документов. Вот мне и интересно, что эти ошибки могут значить.
  17. evgeny1503
    evgeny1503 Участник форума
    14 ноя 2011
    311
    A6_C4 ABC 1996
    Народ, есть audi 100 2.3 1992. Есть штекеры под шнур ваг-ком. Соединяю, включаю зажигание, но комп видит только тормоза, это у всех так? Кроме тормозов ничего не проверить? или у меня косяк какой-то?
  18. Mikheev89
    Mikheev89 Новичок
    19 апр 2011
    64
    A6 2.8 2010
    помогите((((
  19. melkon
    21 сен 2005
    27.088
    1 Fault Found:
    Переодически глючит мотор стеклоомывайки
    последний раз было Date: 2012.12.20
    Замерз небось ...
    1 Fault Found:
    Приборка не верно адаптирована/настроена - надо переделать правильно .
    1 Fault Found:
    Сработала защита энергоменеджера ,возможно АКБ дохлая . Было это 15-го декабря .
    Ошибка в блоке 56 радио как раз и есть ограничение по потреблению тока. Ошибка по лючку бака стандартна на в8 . Зайди в тему по ним в разделе А4 и почитай что и как
  20. melkon
    21 сен 2005
    27.088
    Ну тут вроде на вид все в норме ,надо пробовать подменить датчик .
