Тема в разделе "Ремонт Ауди", создана пользователем melkon, 26 фев 2009.
  1. e.davidz
    e.davidz Новичок
    11 дек 2013
    44
    А6/С6 2,4 2006
    Доброй ночи, ребята. Помогите, пожалуйста с А6С6 2.4 BDW. Какого рода действия предпринимать для устранения такого рода ошибок:
    Address 01: Engine Labels: 06E-910-552-BDW.clb
    Control Module Part Number: 4F0 910 552 S HW: 4F0 907 552 D
    Component and/or Version: 2.4l V6 MPI 0020
    Software Coding: 0105000002070020
    Work Shop Code: WSC 02325 785 00200
    VCID: 3365F94752C0B386591-8066
    4 Faults Found:
    000017 - Bank 1: Camshaft A (Intake)
    P0011 - 008 - Retard Setpoint not Reached (Over-Advanced)
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 146232 km
    Time Indication: 0
    Date: 2015.10.21
    Time: 17:06:20
    Freeze Frame:
    RPM: 1152 /min
    Mass Air / Rev.: 87.2 mg/str
    Temperature: 43.5°C
    Overrun
    Bin. Bits: 00000000
    Steering Angle: 112.79°
    000016 - Bank 1: Camshaft A (Intake)
    P0010 - 008 - Position Actuator Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 146232 km
    Time Indication: 0
    Date: 2015.10.21
    Time: 17:07:55
    Freeze Frame:
    RPM: 2208 /min
    Mass Air / Rev.: 158.1 mg/str
    Temperature: 52.5°C
    Part Throttle
    Bin. Bits: 01000000
    Steering Angle: 90.47°
    000033 - Bank 2: Camshaft A (Intake)
    P0021 - 008 - Retard Setpoint not Reached (Over-Advanced)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 146258 km
    Time Indication: 0
    Date: 2015.10.22
    Time: 10:22:08
    Freeze Frame:
    RPM: 1152 /min
    Temperature: 45.0°C
    Overrun
    Bin. Bits: 00000000
    Steering Angle: 123.94°
    000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 - 008 - Incorrect Correlation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 146258 km
    Time Indication: 0
    Date: 2015.10.22
    Time: 10:22:18
    Freeze Frame:
    RPM: 1120 /min
    Temperature: 46.5°C
    Overrun
    Bin. Bits: 01000000
    Speed: 25.0 km/h
    Заранее благдарен!
  2. Mikhael
    Mikhael Новичок
    12 дек 2011
    77
    A4
    Ошибка: 9443859 - Driver's Front Airbag Crash Sensor
    Делюсь опытом, может кому пригодится.
    Начало истории: зимой, в сильный мороз, автомобиль неделю стоял во дворе. При запуске загорелся значок подушки безопасности.
    На сервисе распечатали ошибку.
    Вроде как датчик. Поменяли, ошибка осталась. Решил проверить всю проводку, под бачком омывателя всё хорошо, сняли крыло, проверили весь жгут - всё нормально. Разобрали подлокотник для доступа к блоку управления - окисление клеммы провода.
    Цена работ по исправлению 6500 руб. (Без стоимости замены датчика)
  3. Asket
    Asket ₪₪₪₪₪₪₪₪
    17 мар 2009
    18.272
    Q7 3.0TDI
    Тоже делюсь- Была ошибка пиропатрона плюсовой клеммы аккума. Вагкомом не стиралась, дилерским васом легко.
  4. ais54
    ais54 Новичок
    11 ноя 2015
    11
    #2324 ais54, 12 ноя 2015
    Господа ! подскажите кто в теме.
    Автомобиль АУДИ Q5 2.0 TFSI__ 2012 год.
    После ДТП ( не большого) в блоке батареи ( адрес 8C ) прописалась ошибка КРАША полученная с блока SRS.
    Ошибка P160900.
    С падушками безопасности разобрались, поменяли и привели в порядок все ГУД ошибок нет.
    Вопрос: Убираеться ли сканером ошибка в блоке J840 ? Да или нет ?
    Должна-же убираться....
    Дело в том что у меня старая версия диагностики ДО 2012 года__и в меню параметров нет пункта стереть ошибки...а может он не предусмотрен? (сомневаюсь)
    Все события вижу.
    Заранее благодарен!
  5. ais54
    ais54 Новичок
    11 ноя 2015
    11
    Неужели никто не в курсе ??? очень печально.......
  6. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    Привет всем. Тема жива?
    Помогите мне, пожалуйста.
    За последнюю неделю заметил, что авто утром заводится стал сложнее. Дольше крутит.
    НО внимания особо не придавал, мало ли.
    Владею авто 4 года, все 4 года периодически 012555 выскакивает. Кроме как своим наличием никаких проблем не доставляла.
    И вот сегодня авто на парковке заглох.
    Завелся легко и сразу. Через минуту опять заглох.
    Потом на ходу глох дважды.
    Ваг ком подключил. Записаны две новые ошибки.
    009529 -Low pressure fuel sensor (g410): Open circuit
    P2539-001-Uper limit exceeded
    и вторая
    004767 - Low pressure fuel pressure regulation: pressure too high
    P129F-001 - Upper limit Exceeded- Intermittent
    Стоп кадр этих двух ошибок не совпадает с 12555, она была тысячи на две раньше этих последний раз.
    Поиск курил, но ничего не сообразил, помогите пожалуйста :(
  7. sonic_a4
    sonic_a4 Живу я здесь
    25 авг 2013
    4.491
    A6/C6 3.2Q 05г.
    Злодей, конечно можно догадаться о каком моторе идет речь, но экспертов уровня Ванги тут не наблюдается:)
    PS выкладывайте полный лог ошибок - при пересказе теряется не меньше 20% информации
  8. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    полный лог это как?
    2тфси., bwe :) а4 в7 2006
  9. sonic_a4
    25 авг 2013
    4.491
    A6/C6 3.2Q 05г.
    Полный текст ошибок...
  10. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    #2330 052, 14 ноя 2015
    Ну и проверь проводку к датчику .Опорное там 5В должно быть ,как на всех датчиках.
  11. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    052, спасибо.
    А из-за плохого бензина могла такая ерунда случится? ну, может там фильтр (он же за давление отвечает) залипнуть? просто ерунда случаилась через 2 км на парковке после 2 минут тарахтения на хх. Сразу после заправки.
    лил 98, но мало ли.
  12. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    #2332 Zlodey, 14 ноя 2015
    или может таки уже пора БУ насоса менять.
    Я так понял это следующее проявление 12555 или нет?
  13. audi_men
    audi_men Завсегдатай
    26 июл 2009
    519
    Audi А4/B6 1.8Т
    насос устал провер давление топлива и как оно держит
  14. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    или БУ? не?
  15. MAYER-M
    MAYER-M Живу я здесь
    14 фев 2012
    2.275
    Q7 3.0 Full S-Line
    не поленись и полистай 9 стр.,вопросов не будет.
    http://www.audi-club.ru/forum/showthread.php?t=210175
  16. sonic_a4
    25 авг 2013
    4.491
    A6/C6 3.2Q 05г.
    Злодей, Вы точно уверены что Вам нужны советы??))
    PS Павел, не претендую на истину в первой инстанции, но почти уверен, что при выходе из рабочего диапазона разработчики позаботились о том, чтобы датчик не выдавал ерунду
  17. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    Эту тему я неоднократно читал. У меня не 12555 сейчас. Ошибка, что давление слишком высокое.
    Авто глохнет исключительно на хх или последующем старте. Имхо. Налил говна, топл филтр залип в положении закрыто и давит все что дает насос в рампу. Обратки на хх либо вобще нет, либо сильно мало. Вот и все. Сейчас посмтрю опорное напряжение, залью 98 вр и меняю топл.фильтр. надеюсь поможет.
    Других причин возникновения излишек давления при уставшеб блоке управления насоса в баке я пока не могу придумать.
  18. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    Конечно мне нужны советы, иначе зачем я тут. К примеру я вообще не понял что это такое. Сейчас болееменее думается. Просто советы из разряда насос в баке устал я воспринимаю как пора двигатель менять если масло жрет.
    Обычно советы это как продиагностировать, а не что наверное точно неисправно. Ошибка это следствие, а причины могут быть разные, мне нужны советы о причинах и их исключении методом диагностики.
  19. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    #2339 052, 14 ноя 2015
    Флаг ошибки именно по обрыву связи с ЭБУД-там обычно высвечивается одно и то же значение в 103 группе. Провода перетираются ,рвутся .Изоляция трескается -дальше водица делает свое дело ,медь превращается в купорос:cry: Недостоверные данные, проц определяет, как несоответствующие данные- более сложный алгоритм.
  20. Zlodey
    Zlodey Старожил
    12 фев 2006
    9.291
    турбокватроручка
    Проверил опорное напряжение. Оно есть 4.94 в как и на втором проводе во время работы насоса те же вольты висят, как подкачка закончилась на опорном напряжение сохранилось, на втором нет.
    Еще обнаружил разломаный разъем фишки датчика. По сути фишка наполовину снята была. Надо поменять. Мож в этом и проблема была? Тупо соскочила фишка с проводами. Кто вот и когда мне столько разъемов поломал? То на коробке, то на датчике темперптуры двигла, то на этом дачике:hot::hot:
