Тема в разделе "Ремонт Ауди", создана пользователем melkon, 26 фев 2009.
  1. leonid2015
    leonid2015 Новичок
    4 янв 2015
    25
    A6/C6
    Ребят помогайте!!!! куда копать и что смотреть. Особо интересует Климат- не работает мотор печки. Живёт своей жизнью.
    Sunday,20,November,2016,17:27:12:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    Mileage: 183700km-114145mi Repair Order:
    Chassis Type: 4F0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
    61 62 72 76
    Mileage: 183700km/114145miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 0010
    Address 01: Engine
    Cannot be reached
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4F1 910 155 B HW: 01J 927 156 HT
    Component: V30 01J 2.4l 4V EU2 0010
    Revision: 00000006 Serial number: 00000000831804
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 224B0C03FD3A2A0EA27-8077
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
    Component: ESP 8.0 front H03 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0021330
    VCID: 2C57E23B8FFEEC7E18B-8079
    2 Faults Found:
    01435 - Brake Pressure Sensor 1 (G201)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 103
    Mileage: 183702 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 16:38:13
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4382
    Hex Value: 0x001C
    Hex Value: 0xB1A8
    Hex Value: 0x00FF
    01119 - Gear Recognition Signal
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 63
    Mileage: 183702 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 17:01:12
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x4382
    Hex Value: 0x0031
    Hex Value: 0x01AA
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H30 0160
    Revision: 27100401 Serial number: 10600300123382
    Coding: 0000003
    Shop #: WSC 02323 785 00200
    VCID: E3C5C90722A0E306691-80B6
    Subsystem 1 - Part No: 4F0 910 131 A
    Component: FBSAUDIC6 EZS H43 0070
    Subsystem 2 - Part No: 4F0 910 220
    Component: FBSAUDIC6 IDG H36 0040
    1 Fault Found:
    00230 - Transmission Park Selector Switch (F305)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 63
    Mileage: 183702 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 17:01:40
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 S HW: 4E0 035 729
    Component: Interfacebox H43 5150
    Revision: 00000000 Serial number: 350EM057563416
    Coding: 0000001
    Shop #: WSC 02335 785 00200
    VCID: 3365F94752C0B386591-8066
    Subsystem 1 - Part No: 4F0 910 609 B
    Component: Bedienteil MMIC6H07 0010
    Subsystem 2 - Serial number: 00000000115686
    Subsystem 3 - Serial number: 0124.02.050000000100010307я
    Subsystem 4 - Serial number: 010307я
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F1 820 043 J
    Component: KLIMABETAETIGUNGH11 0150
    Revision: 00000026 Serial number: 00000000121687
    Coding: 0000006
    VCID: DBB5F1E71AD0DBC6211-808E
    2 Faults Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 103
    Mileage: 183702 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 16:41:47
    02071 - Local Databus
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 183702 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 16:41:47
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H14 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0002122
    VCID: E6C3D013D192962E8EF-80B3
    Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H05 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0050
    Coding: 00141886
    Shop #: WSC 02335
    2 Faults Found:
    02746 - Bulb for Daytime Running Light; Right
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 63
    Mileage: 183700 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 16:39:00
    01494 - Bulb for Parking Lamps; Left (M1)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 63
    Mileage: 183700 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 16:39:00
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBE7127139
    Shop #: WSC 00000 000 00000
    VCID: 1C3732FBDF5E1CFE68B-8049
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
    Component: 32 AIRBAG AUDI8RH29 0250
    Revision: 05H29000 Serial number: 0037LD05KXR0
    Coding: 0013106
    Shop #: WSC 00351 935 80186
    VCID: 285F1E2B9B06C05EFC3-807D
    Subsystem 1 - Serial number: 6332CSME095936182
    Subsystem 2 - Serial number: 6342CSME084969435
    Subsystem 3 - Serial number: 6351HSME063F1C004
    Subsystem 4 - Serial number: 6361HSME0648101B%
    Subsystem 5 - Serial number: 6371VSME064C604ET
    Subsystem 6 - Serial number: 6381VSME064240246
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549
    Component: Lenksдulenmodul H07 0230
    Revision: 00H07000 Serial number: 90022050430035
    Coding: 0000001
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 900 M
    Component: KOMBIINSTR. M73 H10 0630
    Revision: 00500000 Serial number: 4R4157T25
    Coding: 0258143
    Shop #: WSC 00113 935 01234
    VCID: 1E3338F3C9420EEE86F-804B
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 08008052250182
    Coding: ECFE73C41B0104
    Shop #: WSC 00351 935 53945
    VCID: 275D1D179618CF26F59-8072
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
    Component: TSG FA H10 0020
    Revision: 00000000 Serial number: eI
    Coding: 0000522
    Shop #: WSC 02327 785 00200
    VCID: 2A5BE423850AF24EEA7-807F
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
    Component: Komfortgeraet H15 0100
    Revision: 01000015 Serial number: 01003000320000
    Coding: 0131313
    Subsystem 1 - Component: Sounder No Answer
    Subsystem 2 - Component: IRUE No Answer
    8 Faults Found:
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 246
    Mileage: 120341 km
    Time Indication: 0
    Date: 2010.03.03
    Time: 17:33:51
    00987 - Lamp for Brake Light; Left (M9)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 63
    Mileage: 183703 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 17:09:22
    01502 - Bulb for Rear Fog; Left (L46)
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 63
    Mileage: 175026 km
    Time Indication: 0
    Date: 2005.03.04
    Time: 18:33:40
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 63
    Mileage: 182142 km
    Time Indication: 0
    Date: 2005.02.03
    Time: 15:04:45
    01504 - Bulb for License-Plate Light (X)
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 63
    Mileage: 182197 km
    Time Indication: 0
    Date: 2005.02.12
    Time: 11:55:22
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Reset counter: 63
    Mileage: 181897 km
    Time Indication: 0
    Date: 2005.05.30
    Time: 18:43:57
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 3
    Fault Frequency: 72
    Reset counter: 246
    Mileage: 181689 km
    Time Indication: 0
    Date: 2005.04.03
    Time: 12:46:23
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 63
    Mileage: 0 km
    Time Indication: 0
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H09 0350
    Revision: 19S00001 Serial number: 01202050065089
    Coding: 0000006
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H09 0050
    Revision: Serial number: 00000000071165
    Coding: 0001104
    VCID: DEB3F8F309C2CEEE46F-808B
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
    Component: TSG BF H10 0020
    Revision: 00000000 Serial number: 'ЂI
    Coding: 0000522
    VCID: 29591B2F800CF956E3D-807C
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 HW: 4F0 907 801
    Component: EPB C63C0030 H03 0030
    Revision: C63C0030
    Coding: 0002031
    Shop #: WSC 02334 785 00200
    VCID: DDB1FFFF04C4D5F65F5-8088
    1 Fault Found:
    01316 - ABS Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 103
    Mileage: 183696 km
    Time Indication: 0
    Date: 2016.11.20
    Time: 17:03:11
    Freeze Frame:
    Voltage: 13.04 V
    Count: 236
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 C
    Component: Dynamische LWR H01 0010
    Coding: 0000003
    VCID: 3A7BD46375AA42CE9A7-806F
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541 B
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 394EK057551112
    Coding: 0000000
    VCID: 2E53E833B9E29E6E36F-807B
    3 Faults Found:
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 103
    Mileage: 183648 km
    Time Indication: 0
    Date: 2016.11.16
    Time: 12:01:03
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 239
    Reset counter: 103
    Mileage: 183648 km
    Time Indication: 0
    Date: 2016.11.16
    Time: 12:00:06
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 105
    Reset counter: 63
    Mileage: 183645 km
    Time Indication: 0
    Date: 2016.10.31
    Time: 19:25:16
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H12 0490
    Revision: 00000000 Serial number: 00000000028110
    VCID: 23450907E2202306A91-8076
    Subsystem 1 - Part No: 4F0 915 105 B
    Component: von MLA 1234567898
    Coding: 34463039313531303542204D4C4131323334353637383938
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
    Component: TSG HL H11 0030
    Coding: 0000002
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
    Component: TSG HR H11 0030
    Coding: 0000002
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 A HW: 4F0 919 283 A
    Component: Parkhilfe 8-Kan H12 0030
    Revision: --.--.-- Serial number: 11820505601278
    Coding: 0001006
    4 Faults Found:
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 183646 km
    Time Indication: 0
    Date: 2016.11.17
    Time: 16:06:20
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 183646 km
    Time Indication: 0
    Date: 2016.11.17
    Time: 16:06:21
    01626 - Sensor for Parking-Aid; Front Right (G252)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 103
    Mileage: 183678 km
    Time Indication: 0
    Date: 2016.11.18
    Time: 17:24:50
    02070 - Rear Parking Aid Sensors
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 183646 km
    Time Indication: 0
    Date: 2016.11.17
    Time: 16:06:20
    End ---------------------------------------------------------------------
  2. sanya-1
    sanya-1 Старожил
    15 дек 2003
    14.868
    Отпишусь по проблеме - дело было в электрической части блока АБС..
    до этого "отвалилась" масса в виде тонких алюминиевых контактов внутри блока - были в итоге отремонтированы. Соленоиды блока, пока прямая масса была в отвале, видимо нашли её через перефирию. В итоге что-то подгорело не в том месте и не в то время. В общем поменял блок и все ок!)
  3. Sergey4
    Sergey4 Живу я здесь
    14 окт 2012
    4.497
    2.7тди
    Доброго.Загорелся красный значёк акб на приборке,появились ошибки.С чего начинать ремонт?Авто в профиле.
    Контроллер 19: CAN-шина Описания: 4F0-907-468.clb
    Номер детали контроллера: 4F0 907 468 R HW: 4F0 907 468 F
    Компонент и/или Версия: GW-BEM 4CAN-M H06 0058
    Код ПО: 00C303
    Код СТО: WSC 31414 790 00001
    VCID: 3E792988A9C11BCE4C-806A
    2 ошибок найдено:
    02252 - Генератор
    012 - Сбой в изоляции эл.цепи - Периодически
    Момент неисправности:
    Статус ошибки: 00101100
    Приоритет ошибки: 1
    Частота ошибки: 3
    Сброс счетчика: 139
    Пробег:: 78889 km
    Индикация времени: 0
    Дата: 2016.11.26
    Время: 16:39:39
    Биты: 01111
    Напряжение: 11.40 V
    Счетчик: 7
    02252 - Генератор
    003 - Механическая поломка - Периодически
    Статус ошибки: 00100011
    Приоритет ошибки: 1
    Частота ошибки: 2
    Сброс счетчика: 139
    Пробег:: 78895 km
    Дата: 2016.11.26
    Время: 16:44:36
    Биты: 01111
    Напряжение: 11.30 V
    Счетчик: 7
    Контроллер 01: Двигатель Описания: 059-907-401-V2.clb
    Номер детали контроллера: 4L2 910 401 C HW: 4L0 907 401 C
    Компонент и/или Версия: 3.0TDI EDC17 H39 0003
    Код ПО: 2A2A0012A50600010000
    ASAM установки: EV_ECM30TDI0114L2910401C 001003 (AU56)
    ROD: EV_ECM30TDI0114L1910401P.rod
    VCID: 244DFBE02F6D511E3A-8070
    1 Ошибка найдена:
    7144 - Диагностический интерфейс шин данных-J533
    U1008 00 [044] - опросить память неисправностей
    Периодически - Подтверждено - Проверено после сброса памяти
    Статус ошибки: 00000001
    Приоритет ошибки: 2
    Частота ошибки: 3
    Пробег:: 78889 km
    Дата: 2016.11.26
    Время: 16:39:39
    Готовность: 0 0 0 0 1
  4. melkon
    melkon Суровый диагност
    21 сен 2005
    27.088
    Tuareg NF 3.0TDI на пневме.
    Начать с проверки того что на самом деле на клеммах АКБ в состоянии покоя и при заведенном моторе .
  5. Sergey4
    14 окт 2012
    4.497
    2.7тди
    Думаю там на самом деле нет тока заряда,т.к. до гаража дотянул,а там уже завестись не смог,стартер не крутит.
  6. Sergey4
    14 окт 2012
    4.497
    2.7тди
    Влад,а я правильно понимаю, что можно мерить на клеммах под капотом или обязательно на самом акб?
  7. ansko
    ansko Живу я здесь
    26 фев 2009
    1.191
    A4 Avant AVV 2000г
    Двигатель AVV.
    Ошибки:
    2 Найдены неисправности:
    16684 - Обнаружен пропуск воспламенения
    P0300 - 35-10 - - - Непостоянно
    16686 - Цилиндр 2: обнаружен пропуск воспламенения
    P0302 - 35-10 - - - Непостоянно
    Предистория:
    Лил 95, начались дерганья на хорошо прогретую. Залил 95 випаур, дергатьня прошла. Залил 95, дергатьня вернулась. Залил 95 випаур, уже не помогает. Дергатьня осталась.
    Менял: фильтра воздушный и топливный, свечи, провода. Не помогло.
    Спасибо.
  8. ansko
    ansko Живу я здесь
    26 фев 2009
    1.191
    A4 Avant AVV 2000г
    Можно на ты.
    Можно и 92 лить. Зимой лью. Летом 95 с кондеем поинтересней.
    Проблему мою как решить?
  9. Melkon&Ratkov
    25 фев 2014
    7.915
    Можно и там и там померить
  10. Sergey4
    14 окт 2012
    4.497
    2.7тди
  11. [nfs]
    [nfs] Участник форума
    11 ноя 2012
    197
    A4 B8 2.0 TFSI/CDNC
    Будьте добры расшифровать.
    Стираю, а она моментально появляется.
    Контроллер 56: Радио (J503) Описания: 8Tx-035-1xx-56.clb
    Номер детали SW: 8T1 035 186 C HW: 8T1 035 186 C
    Компонент:: Concert3 H02 0210
    Ревизия: 00000004 Номер лицензии: AUZ5Z6H1121442
    Кодировка: 0502008001010500435B070000
    Код сервиса:: WSC 06325 000 00000
    VCID: 37773CAC86FB2A868F-8063
    Подсистема 1 - Номер детали SW: 8T0 919 603 A HW: 8T0 919 603 A
    Компонент:: Display
    1 Ошибка найдена:
    03138 - Вход AUX IN
    011 - Обрыв цепи
    Статус ошибки: 01101011
    Приоритет ошибки: 5
    Частота ошибки: 1
    Сброс счетчика: 246
  12. melkon
    21 сен 2005
    27.088
    А в AUX-е торчит что нибудь ? Если подключить и пробовать воспроизвести с него музыка поет ?
  13. [nfs]
    11 ноя 2012
    197
    A4 B8 2.0 TFSI/CDNC
    в AUXe торчит джек от... как бы его назвать-то... блютус адаптера, который запитан через розетку в том же подлокотнике где и AUX. Он (адаптер) от прежнего хозяина. Не сильно вникал в него, разок получилось с телефона через него отправить музло. Поет. Естественно управлять плейлистом с руля не позволяет, поэтому пока отложил всё до лучших времен, тк эта система показалась как минимум странной.
  14. melkon
    21 сен 2005
    27.088
    Да она странная . Если кодировка есть под AUX то если он выдернут то часто она проявляется
  15. [nfs]
    11 ноя 2012
    197
    A4 B8 2.0 TFSI/CDNC
    Попробую эту приблуду извлечь из аукса, стереть ошибку и понаблюдать.
    благодарю
  16. t.r.a.m.p
    t.r.a.m.p Живу я здесь
    17 янв 2010
    1.436
    Audi A4 1.8T quattro 03г. AMB автомат
    Добрый день, клубни! Беда! Авто сначала на ходу троило (горел ESP и ABS), потом при запуске, теперь вообще просто стартер крутит с каким-то глухим воем. При этом горит чек, абс и есп. За два дня до этого мне поменяли гидротрансформатор. До замены за 7 лет владения такого не было.
    Завести не могу, поэтому снял ошибки при включенном зажигании. (Это не стираемые ошибки):
    17953 - Управление дроссельной заслонкой: сбой в работе
    P1545 - 008 - недостоверный сигнал
    18265 - Сигнал нагрузки: сообщение об ошибке от блока управления двигателя
    P1857 - 003 - механическое повреждение
    18256 - Считать данные из памяти неисправностей блока управления двигателя
    P1848 - 35-00 - -
    01826 - Датчик угла поворота рулевого колеса-G85, напряжение питания на кл.30
    35-00 -
    Информации по этим ошибкам много, двое суток изучал. Но прежде чем я окунулся с головой в далекую от меня электронику, хотелось бы понимать:
    могли ли рукожопые мастера что-нибудь задеть или на место не воткнуть, когда с бубликом возились (например, когда подрамник снимали) или это совпадение? Ведь ДЗ, ДМРВ, ЭБУ находятся сверху, а ремонтные работы проводились снизу.
    PS: снял фишку с ДМРВ - завелась, но страшно смотреть было. Троила, обороты нестабильные, бензом воняла, но работала. При этом ДМРВ с подключенной фишкой ошибок не выдавал.
  17. Udgin0069
    Udgin0069 Живу я здесь
    23 янв 2012
    3.746
    A4 B8 2.0T
    Ага, тоже иногда появлялась, на работу аукса не влияла, последнее время не появляется.
  18. sanya-1
    sanya-1 Старожил
    15 дек 2003
    14.868
    Тебе походу нужно его менять, а не фишку снимать.
  19. t.r.a.m.p
    17 янв 2010
    1.436
    Может и нужно, но с неработающим ДМРВ и уж тем более с отключенным, авто не должно глохнуть или захлебываться! Что-то где-то еще надо лечить.
  20. sanya-1
    sanya-1 Старожил
    15 дек 2003
    14.868
    А вообще, конечно, не мешало бы разъем ДЗ и его провода проверить.. Ты же говоришь - не стирается? А должна бы удалиться..
