Тема в разделе "Ремонт Ауди", создана пользователем melkon, 26 фев 2009.
  1. mamont543
    mamont543 Завсегдатай
    27 окт 2014
    831
    Калужская обл.
    А6/С7
    Влад,спасибо!!! Карбклинер заставил его работать!!!
  2. audi_men
    audi_men Завсегдатай
    26 июл 2009
    519
    Audi А4/B6 1.8Т
  3. Chilik123
    Chilik123 Новичок
    26 янв 2015
    12
    b7
    sps budu iskati
  4. Stig_Вlоmqvist
    Stig_Вlоmqvist Новичок
    4 мар 2014
    10
    A4B8 Avant S-line
    Всем здравствуйте, подскажите пжлт по ошибкам, автомобиль Q5 8RB CAHA LTC, заранее спасибо,
    ошибки:
    Address 01: Engine (J623-CAHA) Labels: 03L-906-022-CAG.clb
    Part No SW: 03L 906 019 AS HW: 03L 906 022 B
    Component: R4 2,0L EDC H01 6575
    Revision: 11H01---
    Coding: 01210023241F2118
    Shop #: WSC 22829 142 84435
    ASAM Dataset: EV_ECM20TDI03L906019AS A01004
    ROD: EV_ECM20TDI03L906019AS.rod
    VCID: 7CF7127BF71EBCFEC8B-8029
    2 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [047] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 17
    Mileage: 165697 km
    Date: 2015.05.30
    Time: 14:45:41
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [047] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 17
    Mileage: 165697 km
    Date: 2015.05.30
    Time: 14:45:41
    Readiness: 0 1 0 0 0
    Address 36: Seat Mem. Drvr (J136) Labels: None
    Part No SW: 8R0 959 760 HW: 8R0 959 760
    Component: MEM-FS H05 0043
    Revision: AA000000 Serial number: 00001001272001
    Coding: 00581300000044440000
    Shop #: WSC 06335 000 00000
    VCID: FEF3987369022EEE66F-80AB
    2 Faults Found:
    03332 - Motor for Height Adjustment
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 149468 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 01:11:53
    03333 - Motor for Cushion Angle Adjustment
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 149468 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 01:11:53
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
    Component: EPB Audi B8 H08 0080
    Revision: 00000003 Serial number: 00000000363410
    Shop #: WSC 00000 000 00000
    VCID: 3365F94792C0B386591-8066
    2 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 170
    Mileage: 165914 km
    Time Indication: 0
    Date: 2015.06.04
    Time: 14:38:58
    Freeze Frame:
    Voltage: 13.70 V
    Count: 38
    Speed: 0.0 km/h
    Hex Value: 0x01E3
    Hex Value: 0x0008
    Hex Value: 0x1010
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 165694 km
    Time Indication: 0
    Date: 2015.05.30
    Time: 09:13:33
    Freeze Frame:
    Voltage: 12.70 V
    Count: 11
    Speed: 0.0 km/h
    Hex Value: 0x0263
    Hex Value: 0x0828
    Hex Value: 0x1010
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8T1 035 666 D HW: 8T1 035 666
    Component: H-BN-EU H65 0047
    Revision: -------- Serial number: 321E$097576379
    Coding: 010100060005A3ED51000B1E000000030001
    VCID: 3B75D167BA907BC6811-806E
    Subsystem 1 - Part No: 8R0 060 884 C
    Component: EUROPE 2008 5608
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
    Component: E0380 Bedient H08 0100
    2 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 149468 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 01:11:55
    Freeze Frame:
    Voltage: 13.60 V
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 109
    Mileage: 149468 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 01:11:58
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000100 00000000
  5. melkon
    melkon Суровый диагност
    21 сен 2005
    27.088
    Tuareg NF 3.0TDI на пневме.
    :hi::hi::hi:
  6. Evgen_nv
    Evgen_nv Новичок
    27 окт 2014
    4
    А6/С6 3.2FSI 05г.
    Помогите загорелся на приборке значек EPС. Подключил шнурок вот что выдало
    Адрес 01: Электроника двигателя (AUK) Label: 06E-910-559-BKH.clb
    Part No SW: 4F1 910 559 P HW: 4F1 907 559
    Компонент: 3.2l V6 FSI 0010
    Ревизия: --H15--- Серийный номер:
    Кодировка: 01050200190F0120
    Мастерская #: WSC 00465 935 94813
    VCID: 38750E064B17D7E197B-806D
    5 Найдены неисправности:
    012555 — Регулир.давл.в контуре низк.давл.топл.системы
    P310B — 009 — давл.топлива за пред.допуска
    Стоп-кадр:
    Статус неисправности: 00100100
    Приоритет неисправности: 2
    Частота появления ошибки: 1
    Индекс забывания: 40
    Пробег: 140797 km
    Отсчет времени: 0
    Дата: 2015.06.05
    Время: 18:21:02
    Стоп-кадр:
    Об/мин: 672 /min
    Возд. масса: 119.9 мг/ул
    Температура: 93.0°C
    Холостой ход
    Давление: 4.9 bar
    Скорость: 0.0 km/h
    004766 — Контур низкого давления топливной системы
    P129E — 009 — слишком низкое давление
    Стоп-кадр:
    Частота появления ошибки: 2
    Пробег: 140801 km
    Отсчет времени: 0
    Дата: 2015.06.05
    Время: 18:38:49
    Стоп-кадр:
    Об/мин: 3360 /min
    Возд. масса: 87.2 мг/ул
    Температура: 99.0°C
    Режим прин.ХХ
    Давление: 2.1 bar
    Скорость: 78.0 km/h
    009525 — Выключатель стартера/зажигания
    P2535 — 006 — короткое замыкание на плюс
    Стоп-кадр:
    Статус неисправности: 11100001
    Частота появления ошибки: 4
    Пробег: 140803 km
    Отсчет времени: 0
    Дата: 2015.06.05
    Время: 21:41:42
    Стоп-кадр:
    Об/мин: 0 /min
    Возд. масса: 0.0 мг/ул
    Температура: 60.0°C
    Выкл. двиг.
    Напряжение: 12.14 V
    Скорость: 0.0 km/h
    012371 — Включение стартера;ответн.сигнал от клеммы 50
    P3053 — 006 — коротк.замык.на массу/обрыв цепи
    Стоп-кадр:
    Пробег: 140803 km
    Отсчет времени: 0
    Дата: 2015.06.05
    Время: 21:47:12
    Стоп-кадр:
    Об/мин: 0 /min
    Температура: 61.5°C
    Выкл. двиг.
    Напряжение: 11.93 V
    Скорость: 0.0 km/h
    012424 — Реле стартера
    P3088 — 006 — неисправность в электрической цепи
    Стоп-кадр:
    Пробег: 140803 km
    Отсчет времени: 0
    Дата: 2015.06.05
    Время: 21:47:16
    Стоп-кадр:
    Об/мин: 0 /min
    Температура: 61.5°C
    Выкл. двиг.
    Напряжение: 11.93 V
    Скорость: 0.0 km/h
    Готовность: 0000 0000
    Адрес 17: Комбинация приборов Label: 4F0-910-xxx-17.clb
    Part No SW: 4F0 910 900 A HW: 4F0 920 900 R
    Компонент: KOMBIINSTR. M73 H11 0630
    Ревизия: 00000000 Серийный номер: 4R6188C75
    Кодировка: 2305003
    Мастерская #: WSC 00394 935 99368
    VCID: 1E39F89EC9F389D17D7-804B
    2 Найдены неисправности:
    00771 — Датчик уровня топлива-G
    010 — Разорвана цепь или замыкание на плюс — Непостоянно
    Стоп-кадр:
    Статус неисправности: 00101010
    Приоритет неисправности: 7
    Индекс забывания: 209
    Пробег: 140745 km
    Отсчет времени: 0
    Дата: 2015.06.03
    Время: 19:17:12
    00438 — Датчик 2 уровня топлива(G169)
    Стоп-кадр:
    Пробег: 140745 km
    Отсчет времени: 0
    Дата: 2015.06.03
    Время: 19:17:12
    Подскажите что делать? Куда копать?
  7. sonic_a4
    sonic_a4 Живу я здесь
    25 авг 2013
    4.491
    A6/C6 3.2Q 05г.
    - по датчикам уровня: в разделе 4F C6 ищете темы "стрелка уровня топлива на нуле", если на фишке бензонасоса датчики в обрыве, достаете бензонасос, и поджимаете контакты на фишке, фишку лучше закрепить к корпусу пластиковыми хомутами.
    - по низкому давлению - похоже что прозевали бензин:)
    по электрической части в ошибках все написано.
  8. Evgen_nv
    Evgen_nv Новичок
    27 окт 2014
    4
    А6/С6 3.2FSI 05г.
    sonic_a4, так дело в том что я удалил ошибки по низкому давлению они снова появились. И моторчик в баке как то прерывесто качает.
  9. Blackbuilder
    Blackbuilder Участник форума
    5 июл 2014
    340
    Audi Q7 4L
    Здравствуйте. Нужна помощь. После установки подсветки ног вылезли ошибки:
    01330 - Центральный блок управления систем комфорта J393
    013 - Проверить коды ошибок
    02071 - Локальная шина данных
    012 - Нарушение в электрической цепи
    03280 - Позиция переключателя света
    008 - Некорректный сигнал
    00457 - Блок управления бортовой сети
    01305 - Шина данных информационно-командной системы Infortainment
    004 - Нет сигнала\связи - Периодически
    Машина audi a4 b8 VIN WAUZZZ8K49N054003 перестали включаться дворники и отказал тумблер переключения режимов света
  10. sonic_a4
    25 авг 2013
    4.491
    A6/C6 3.2Q 05г.
    Тогда тест на производительность или смотреть заполняемость на ХХ при отвлеченных потребителях; в баке не пусто, а то еще влияет система вентиляции... Опять же все есть в нашем разделе
  11. hvatok
    hvatok Завсегдатай
    16 авг 2010
    765
    A4 B8 1.8 TFSI 08
    Audi A4 B8 2008 г
    03110 Блок управления активного рулевого управления (J792)
    004 нет сигнала/связи
    Люди подскажите пожалуйста, после замены приборки дорестайла на рестайлинг , висит вот такая ошибка. При чем на старой приборке такой ошибки не было. Куда лезть? Тогда как убрать эту ошибку? Горит желтый рул. Заранее спасибо.
  12. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    #1412 052, 7 июн 2015
    Отпаять светодиод в приборке-больше вариантов нет. Другой вариант- кан-хакером выцепить посылку от 792 на рестайловой машине и перепрошить гейтвей под эту команду. Но это задача для автохакеров. Светодиод отпаять тоже нелегко-придётся дёргать стрелы , чтобы поднять подложку, а потом вертать эти стрелы на место. Неопытному можно вертать обратно очень долго.
  13. hvatok
    hvatok Завсегдатай
    16 авг 2010
    765
    A4 B8 1.8 TFSI 08
    #1413 hvatok, 7 июн 2015
    Eps горит вследствие этой ошибки?и что такое 792, хакеры нашлись для подсказки им.
  14. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    792-блок управления электроусилителя руля. На дорестайле его не было. Гейтвей в дорестайле не шлёт посылки о нём, а рестайловая приборка ждёт этих посылок. Можно, наверное, изменить конфиг приборки на программном уровне(кодировки и адаптации это не позволяют), но опять таки -это репрог(ещё непонятно возможен ли он).
  15. hvatok
    hvatok Завсегдатай
    16 авг 2010
    765
    A4 B8 1.8 TFSI 08
    Замена гейтвея на рестайлинг не поможет?
  16. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    Поможет, наверное. Главное, чтобы эта замена не вызвала более сильную головную боль:nod:
  17. melkon
    21 сен 2005
    27.088
    Замена гейтвей не приделает блок электроусилителя к машине ...
  18. Blackbuilder
    5 июл 2014
    340
    Audi Q7 4L
    Парни можете подсказать откуда ноги растут и как проверить блок комфорта?
  19. 052
    052 Водолей
    24 янв 2011
    6.388
    bmx
    В чём суть установки заключалась?
  20. Blackbuilder
    5 июл 2014
    340
    Audi Q7 4L
    Готовые плафоны вставил в отведенные под них места под сиденьями рулем и бардачком. Подключил передние Т32 в 17 пин и задние В черный 17 контактный в 14 пин. Плафоны спереди загорелись сразу а вот задние после программного подключения. После всего этого появились ошибки по блоку комфорта и отсохли дворники и переключатель света ругается на неправильное положение
