Пробейте пожалуйста вин!!!
Тема в разделе "Выбор Audi с пробегом", создана пользователем mpv, 13 июл 2006.
  1. Коля Герасимов
    Коля Герасимов Живу я здесь
    11 май 2004
    1.501
    Трёхлитровая японк
    Ответ: Пробейте пожалуйста вин!!!
    И этот, пожалуйста: wauzzz8dzsa122591
  2. Airborn
    Airborn Живу я здесь
    30 июн 2005
    1.706
    Audi Q5 2.0d 2019
    Нивапрос :hi:
    VIN Number WAUZZZ8DZSA122591;
    Sales type 8D20C4;
    Exterior color Q8
    Roof color Q8
    Interior trim code QL;
    Engine code & No. ADR 49182;
    Transmission code CPD;
    Date of production 19.05.1995;
    Model year 1995;
    Код Опция
    1BE sports suspension/shock absorption
    9Q0 without multi-function indicator/ on-board computer
    2K1 reinforced bumpers
    0TD front and rear floor mats
    5MD decorative aluminum inserts
    6V1 rear trim panel (ECE)
    8T0 without cruise control system (CCS)
    0LW special plates/stickers/ safety certificates for Germany
    3L1 manual height adjustment for left front seat
    M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z
    4M0 without cup holder
    4TB vanity mirror right
    8X0 without headlight washer system
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    8AA without radio
    9Y0 without outdoor temperature gage
    L0L left-hand drive vehicle
    1G2 steel spare wheel with original equipment tires
    8TC rear fog light for driving on the right
    5C0 without special body measures
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    G0C 5-speed manual transmission
    4F1 central locking system
    3X0 without load-through provision
    7P4 manually adjustable lumbar support in front seats
    8Q1 headlight-range adjustment
    C0V steel wheels 6J x 15 offset 45 (five-hole)
    3AF outer right rear view mirror: convex, powered, heated
    U1A instrument insert with km/h speedometer,clock, tachometer and trip odometer
    6W5 front license plate bracket
    5K1 paint preservative (wax)
    9V0 without anti-theft protection system
    1VG installation parts for four-cylinder engine
    B0A component parts set without country-specific design requirement
    1D0 without towing attachment
    4UE airbag f. driver a. front seat passenger
    3B0 without additional child seat anchor
    2A5 delivery equipment (transit coating) with thin seat cover
    8BB halogen headlight for left-hand drive
    0G1 gearshift lever
    4R0 mechanical window regulator
    F0A no special purpose vehicle, standard equipment
    K8B notchback
    3Y0 without roll-up sun screen
    8R0 without center high-mounted stop light
    6E0 without center armrest front
    0VC information kit in German
    1WC transmission shaft w/ 108mm in diameter
    8NA without parking light warning light
    9W0 w/o car phone preparation/installation
    3FE electric slide/tilt sunroof with sun screen/sunblind
    2B0 without additional exterior noise suppression
    8Z0 standard engine cooling system
    2PV leather trimmed sports steering wheel
    8RA without speakers
    8K0 without special low beam mode
    1E1 activated carbon canister
    1T3 first aid kit and warning triangle
    0W1 label for central electric German-speaking countries
    E0A no special edition
    3C1 static lap belt, center rear
    8CC speedometer sensor without seal (electronic speedometer sensor)
    3BS outer left rear view mirror: non-spherical, powered, heated
    B99 type approval EC
    4GH windshield tinted with windshield sunshield
    1X0 front wheel drive
    N4A fabric seat covering
    1LH disc brakes, front
    1PA standard wheel bolts
    4ZE black moldings
    6Q2 leather gearshift knob/handle
    H6S tires 195/65 R 15 V
    1AC anti-lock brake system (ABS)
    0SB labels/plates in German
    4W0 without cassette and CD storage unit
    9P0 without seat belt warning light
    6U0 without additional seals outside
    8S0 without reading light
    8KA w/o catalytic converter warning light
    3CA without partition
    T5Z components for base engine, unit 058.B
    8GM alternator 70A
    FA0 control of standard production
    9T1 heated washer nozzles, front
    4SB vanity mirror left
    A8S standard equipment
    9AA manually controlled heating system
    6N0 without mud flaps
    4A0 without seat heater
    6FA components without special surface appearance
    3S0 without roof rails/roof load rack
    3NZ rear seat bench unsplit, backrest split folding
    J1P battery 220 A (44 Ah)
    9X6 heated door lock cylinder left with micro switch
    0DY installation differentiation for build status of vehicle class B5 (AUDI) unit components
    2V1 dust and pollen filter
    2G1 insert for the filling up of unleaded fuel
    1EX special identification plate for EC
    6R2 leather gearshift boot
    2Z0 deletion of model designation
    C01 operating permit, alteration 1
    Нераспознанные коды
    P16 PW2
  3. Comandor
    Comandor Новичок
    13 июл 2006
    61
    Audi 80 2.0 85г.
    Если не трудно пробей пожалуйста
    WAUZZZ85ZGA007083
  4. Airborn
    30 июн 2005
    1.706
    Audi Q5 2.0d 2019
    Старше 91 года не бъёЦЦа :cry2: :hi:
  5. Comandor
    Comandor Новичок
    13 июл 2006
    61
    Audi 80 2.0 85г.
    и что теперь вообще никак не узнать такую информацию?
  6. Airborn
    30 июн 2005
    1.706
    Audi Q5 2.0d 2019
    хз, а что ты хотел узнать? :shock:
  7. Comandor
    Comandor Новичок
    13 июл 2006
    61
    Audi 80 2.0 85г.
    ну вот как ты давал всем разъяснения по машине
    вот и я хотел такое же
  8. Sattelite
    Sattelite Bad e-mail
    16 июл 2006
    86
    Mitsubishi Lancer X
    опа... О.О .... такс... я это с доверености перепечатывал...
    вот с ПТС: WAUZZZ8DZXA328234
    (ёптыть, откудаж я этот взял WAUZZZ8DZXA218124 ? =))) )....
    извеняюсь что сбил с толку... виноват... криворучка немного =)...
  9. Airborn
    30 июн 2005
    1.706
    Audi Q5 2.0d 2019
    Бывает, не парься :hi:
    Держи вот лучше:
    VIN Number WAUZZZ8DZXA328234;
    Sales type 8D50C8;
    Exterior color E8
    Roof color E8
    Interior trim code EB;
    Engine code & No. ADR512456;
    Transmission code DMU;
    Date of production 01.07.1999;
    Model year 1999;
    Код Опция
    4X1 side airbag front
    8T1 cruise control system (CCS)
    1YA without transmission shafts f. rear axle
    6RA dashboard and door trim panel one-piece, single color
    9Y1 outdoor temperature gage
    7P0 without lumbar support in front and rear seats
    G0E four-speed automatic transmission
    7X0 without park distance control
    2WA without additional tires
    B0F component parts set, complying with vehicle type for Switzerland, various parts
    1KD disc brakes, rear
    1S7 tool kit and aluminum jack
    0G2 selector lever
    4R3 power windows with comfort operation
    7Q0 without navigation device
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    B13 type approval Switzerland
    1SA without additional engine guard
    6E3 center armrest front
    3FA without roof insert (standard roof)
    4K4 radio remote controlled central locking operated from inside and separate trunk release
    7QA without CD ROM
    1T0 w/o first aid kit and warning triangle
    6M0 without tie down straps/net/pocket
    5A5 trunk lining, with stowage trays
    4ZE black moldings
    VC0 w/o remote-controlled garage door opener
    8GL alternator 120A
    4L2 dipping breakaway inside rear view mirror
    1LZ front disc brakes, standard ventilation
    4SD left vanity mirror illuminated
    7K0 without tire pressure warning light
    J1L battery 280 A (60 Ah)
    7CC label for radio remote control for
    6FB body-colored outer rear view mirror housings
    4LA without controls
    4E0 tailgate/trunk lid unlocking from outside
    1EY special identification plate with weight data, but without general operating permit (ROW)
    8WB front fog lights
    C00 operating permit, initial registration
    2Z1 type sign at rear and "Quattro" nameplates respectively
    N5G fabric seat covering (not specified yet)
    1MR leather steering wheel
    4TD right vanity mirror illuminated
    1G3 alloy spare wheel with original equipment tires
    8Q0 without headlight-range adjustment
    0YD weight category rear axle weight range 4
    C8N alloy wheels 6J x 15 style not designated; 4B0 601 025 L offset 45
    4N0 standard dashboard
    0JE weight category front axle weight range 5
    2T0 without double-sized standard (DIN)
    9V7 electronic vehicle immobilization devicewith anti-theft alarm system and passenger compartment control
    7M1 scuff plates in door apertures with metal inserts
    3Q6 three rear headrests
    5RQ outer right rear view mirror: convex
    0K0 without alternative drive module
    K8D Station Wagon Variant/Avant
    5D1 carrier frequency 433.92 MHz
    8JH ellipsoidal headlight for driving on the right
    1WD transmission shaft for tripod joints
    6PC leatherette hand brake lever handle
    F0Y vehicle with optional features
    8YU radio preparation for commercial goods
    5SL outer left rear view mirror: non-spherical
    8Z5 engine cooling system, type 1
    3C7 3-point seat belt for center rear seat
    6XD outer rear view mirrors: powered, heated
    0L0 mechanical throttle actuation
    5E1 without sill top with door cover
    8RM eight loudspeakers (passive)
    8S4 two reading lights front, two rear
    0ST labels/plates in German and French
    4P0 rear floor panel module, type 1
    0LF special plates/stickers/ safety certificates for Switzerland
    5TH decorative aluminum inserts "points"
    3S2 black roof rails
    6R0 selector lever cover
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    Нераспознанные коды
    WM5 WKC
  10. Sattelite
    16 июл 2006
    86
    Mitsubishi Lancer X
    Большое спасибо! вроде тоже всё совпадает.... (многое конечно не понятно, исчерпывающая инфа про машку...)...
  11. Alekss
    Alekss Участник форума
    14 июн 2006
    161
    Q7 3 TDI
    И мне.. заранее спасибо..
    WAUZZZ8DZWA216856..
  12. zombi
    zombi Новичок
    26 июн 2006
    62
    Audi 80 b4 92r.
    А не поделитесь ссылочкой где вин пробиваете? :up:
  13. sim_a100_2.3_92
    sim_a100_2.3_92 Старожил
    6 дек 2003
    28.972
    ВАЗ 21083
    http://www.vw-club.ru/vw/vin/
  14. Airborn
    30 июн 2005
    1.706
    Audi Q5 2.0d 2019
    Неа :D
  15. mpv
    mpv Участник форума
    25 май 2006
    189
    Audi A6 2.8 Q FSI(
    WAUZZZ4B42N011132
  16. AudiA
    AudiA Bad e-mail
    19 фев 2006
    648
    A6 4.2 Q 4F - С6
    аирборн ку ку =)
  17. sim_a100_2.3_92
    6 дек 2003
    28.972
    ВАЗ 21083
    Ленивые все какие:)
    VIN: WAUZZZ4B42N011132
    Код модели: 4B20CZ ()
    Дата выпуска: 28.06.2001
    Модельный год: 2002
    Код и номер двигателя: BDV 002801
    Код КПП: FAM
    Комбинация цветов интерьера: LA
    Комбинация цветов кузова: 4Z
    Цвет крыши: 4Z
    Комплектация автомобиля (код и наименование):
    0DS installation differentiation for build status of vehicle class 4B0 (AUDI)
    0F2 fuel system for carburetor gasoline engine
    0G7 Tiptronic
    0GG emissions concept EU 4
    0JK weight category front axle weight range 10
    0LW special plates/stickers/safety certificates for Germany
    0N5 standard rear axle
    0YP weight category rear axle weight range 13
    1LT disc brakes, front
    1N1 power steering
    1PC wheel bolts with anti-theft protection (unlockable)
    1VH installation parts for six-cylinder engine
    1X1 four wheel drive
    1YC transmission shafts for rear axle diameter 100
    1Z2 increase in initial standard fuel filling
    2A4 delivery equipment for shipment (transitcoating) with thick seat cover
    2C5 axial and vertical adjustable steering column
    2T1 double-sized standard (DIN)
    3GA without cargo area
    3HA without leather parts scope
    3L5 electric seat adjustment for both front seats
    3V0 without child bench seat
    3X1 load-through provision with ski bag
    4A3 seat heater for front seats separately controlled
    4KC side and rear windows tinted
    4X3 side airbag front with curtain airbag
    4ZB bright moldings
    7E0 w/o heat accumulator/auxiliary heating
    5E2 sill top with door cover
    5RU outer right rear view mirror: convex (large viewing field)
    5TM decorative aluminum inserts "check gray"
    6M1 tie down straps
    6SS luggage compartment floor covering
    6XE outer rear view mirrors: powered, heatedelectrically foldable
    7AA electronic vehicle immobilization device
    7P1 power adjustable lumbar support in frontseats
    7Q9 navigation system
    7QB CD ROM (Germany)
    7X1 ultrasonic park distance control
    8ED bi-functional headlight with gas discharge lamp, for driving on the right
    8GL alternator 120A
    8Q3 automatic headlight-range adjustment dynamic (self-adjusting while driving)
    8UM radio "symphony" (ECE)
    8X1 headlight washer system
    9AK "Climatronic" with impact pressure control free of cfc
    9B0 without telepay device
    9M0 without auxiliary/parking heater
    9NX without electronic logbook
    9Q2 multi-function indicator/on-board computer with check control
    9VD speaker (active)
    9ZF preparation for cellular phone with hands-free speaking system
    A00 no self-collection
    B01 type approval Germany
    C17 operating permit, alteration 17
    CB1 alloy wheels 7J x 16 Alu-4, offset 42
    D5B 6-cyl. gasoline engine 2.4 L/125 kW 30V base engine is: T7T
    FC0 without customized installation
    FQ0 standard production wheels
    G0Q five-speed automatic transmission for four-wheel drive vehicle
    H6U tires 205/55 R 16 91W
    J0L battery 340 A (70 Ah)
    K8B notchback
    N1H leather seat covering
    NT0 transit coating (type 1)
    P16
    PLD
    PNH
    PPA
    PSV
    PX4
    Q1D sports front seats
    QA0 without child seat
    QH0 without voice control
    QV0 w/o TV reception/digital radio reception
    RLA
    RSY
    T7T components for base engine, unit 078.7
    U2B instrument insert with km/h speedometer,radio-controlled clock, tachometer, tripodometer and additional instruments
    V0A tires w/o specification of tire brand
    VX0 without hands-free system
    VY0 without danger alarm system
    WS1
    WV1
  18. zombi
    zombi Новичок
    26 июн 2006
    62
    Audi 80 b4 92r.
    Спасиб канечна! пока ждал сам наткнулся на этот сайт:)
  19. mr_noel
    mr_noel Новичок
    30 апр 2006
    44
    Буду очень благодарен, если и мой VIN пробьете.
    A6 3.0 2002 WAUZZZ4BX2N073831
  20. Airborn
    30 июн 2005
    1.706
    Audi Q5 2.0d 2019
    кукуку
