пробейте VIN пожалуйста
Тема в разделе "Выбор Audi с пробегом", создана пользователем JohnGrey, 4 окт 2006.
  1. далекий
    далекий Bad e-mail
    1 дек 2006
    17
    Ответ: пробейте VIN пожалуйста
    пробейте VIN пожалуйста WAUZZZ4BZWN023010 очень благодарю
  2. Airborn
    Airborn Живу я здесь
    30 июн 2005
    1.706
    Audi Q5 2.0d 2019
    VIN Number WAUZZZ4BZWN023010;
    Sales type 4B20H4;
    Exterior color L5
    Roof color L5
    Interior trim code BR;
    Engine code & No. AEB105952;
    Transmission code DHW;
    Date of production 24.06.1997;
    Model year 1998;
    Расшифровка кодов комплектации
    Код Опция
    0TC front floor mats
    4X1 side airbag front
    2K1 reinforced bumpers
    5MC decorative aluminum inserts "check graphite"
    9B0 without telepay device
    6V1 rear trim panel (ECE)
    9Q2 multi-function indicator/on-board computer with check control
    8T0 without cruise control system (CCS)
    1N1 power steering
    0LW special plates/stickers/ safety certificates for Germany
    2Z7 type sign and company logo without displacement data
    4M0 without cup holder
    1YA without transmission shafts f. rear axle
    8X0 without headlight washer system
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    L0L left-hand drive vehicle
    8TC rear fog light for driving on the right
    1G3 alloy spare wheel with original equipment tires
    5C0 without special body measures
    7P1 power adjustable lumbar support in frontseats
    7A0 without CD changer/CD player
    1Z0 initial standard fuel filling
    Q1A standard front seats
    G0C 5-speed manual transmission
    3X0 without load-through provision
    8Q1 headlight-range adjustment
    7E0 w/o heat accumulator/auxiliary heating
    3PF electric height adjustment for both front seats
    7X0 without park distance control
    U1C instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.)
    5K0 without paint preservative
    6W5 front license plate bracket
    2WA without additional tires
    M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C
    0YD weight category rear axle weight range 4
    1VG installation parts for four-cylinder engine
    B0A component parts set without country-specific design requirement
    7AA electronic vehicle immobilization device
    1D0 without towing attachment
    4UE airbag f. driver a. front seat passenger
    0JG weight category front axle weight range 7
    3B0 without additional child seat anchor
    2A5 delivery equipment (transit coating) with thin seat cover
    1KD disc brakes, rear
    0G1 gearshift lever
    T8B components for base engine, unit 058.D
    7M1 scuff plates in door apertures with metal inserts
    3Q6 three rear headrests
    F0A no special purpose vehicle, standard equipment
    8BG twin headlamp for left-hand drive with integrated high-beam headlight
    K8B notchback
    5RQ outer right rear view mirror: convex
    7Q0 without navigation device
    8UD radio "concert"
    5D1 carrier frequency 433.92 MHz
    3Y0 without roll-up sun screen
    1SA without additional engine guard
    9VD speaker (active)
    2PG steering wheel
    6E3 center armrest front
    0VC information kit in German
    4K1 radio remote controlled central locking
    1WC transmission shaft w/ 108mm in diameter
    3FA without roof insert (standard roof)
    7QA without CD ROM
    9W0 w/o car phone preparation/installation
    2B0 without additional exterior noise suppression
    6M1 tie down straps
    1LB disc brakes, front
    8K0 without special low beam mode
    1E1 activated carbon canister
    1T3 first aid kit and warning triangle
    E0A no special edition
    8CC speedometer sensor without seal (electronic speedometer sensor)
    B99 type approval EC
    8Z5 engine cooling system, type 1
    5SL outer left rear view mirror: non-spherical
    4GH windshield tinted with windshield sunshield
    1X0 front wheel drive
    6Q1 plastic gearshift knob/handle
    3V0 without child bench seat
    1PA standard wheel bolts
    4KC side and rear windows tinted
    3C7 3-point seat belt for center rear seat
    5A5 trunk lining, with stowage trays
    6XE outer rear view mirrors: powered, heatedelectrically foldable
    H6S tires 195/65 R 15 V
    3ND rear seat bench/backrest, unfolding
    9P0 without seat belt warning light
    5E2 sill top with door cover
    4W1 cassette storage unit
    6U1 additional dust seal outside
    N4J fabric seat covering "Sports", 4B0
    1AH electronic differential lock (EDL)
    8KA w/o catalytic converter warning light
    3CA without partition
    8GL alternator 120A
    FA0 control of standard production
    4L2 dipping breakaway inside rear view mirror
    A8S standard equipment
    C6U forged alloy wheels 6J x 15 polished, offset 45
    0ST labels/plates in German and French
    7CA without label for radio remote control
    0DS installation differentiation for build status of vehicle class 4B0 (AUDI)
    6N0 without mud flaps
    3S0 without roof rails/roof load rack
    4A3 seat heater for front seats separately controlled
    J1P battery 220 A (44 Ah)
    SA7 inventory control model 2
    9M0 without auxiliary/parking heater
    2G1 insert for the filling up of unleaded fuel
    1EX special identification plate for EC
    6R1 leatherette gearshift boot
    1BA standard suspension/shock absorption
    9AK Climatronic with impact pressure control free of cfc
    C01 operating permit, alteration 1
    Нераспознанные коды
    WM3 PH5 RCL
    1 человеку нравится это.
  3. Юркен
    Юркен Новичок
    1 дек 2006
    20
    Audi 100/45 2.0 93г
    пробейте VIN пожалуйста WAUZZZ4AZPN093854. Большое спасибо!
  4. bond.utd
    bond.utd Новичок
    27 ноя 2006
    16
    Audi A6
    Вот, исправил ошибку в Вине, если можно - WAUZZZ8ZZ1NO48691 - заранее спасибо!!!
  5. ASK08
    ASK08 Участник форума
    18 авг 2006
    193
    Das Auto 2 штуки
    Понравилась машинка,7.12. так или иначе решится вопрос с покупкой,если можно вот:
    WAUZZZ4BZWN122892:shock:
  6. Prozed
    Prozed Живу я здесь
    28 ноя 2006
    1.462
    Touareg + A4
    Пробейте вин пожалуйста!
    WAUZZZ8DZWA061346
  7. Ikk
    Ikk Участник форума
    10 окт 2006
    239
    А3
    AUDI80 АВТ - 2.0
    1991-09Gomera met
    6 динамиков.
  8. Bend
    Bend Завсегдатай
    14 авг 2005
    864
    S8, 6spd manual
    19.03.1998
    А6 ку 2.4
    A8S - Исполнение Standard
    G0G - 5-Ступ. Механическая Кп Для Полного Привода
    K8B - Полностью Оцинкованный Кузов
    MT5 - 6-Цил.Бенз.Дв-Ль 2,4 Л/121 Квт (V6) Eu3 (Временное Решение) Баз.Двигатель: T7t
    T7T - 6-Цил. Бенз.Двиг. 2,4 Л Агрег. 078.7
    0DS - Спецкомплект Для Платформы 4b0 Audi
    0G1 - Рычаг Механизма Включения Передач
    1E1 - Противопылевой Фильтр С Угольным Фильтром
    1VH - Монтажные Детали Для 6-Цил. Двигателя
    1X1 - Полный Привод
    C05 - Разрешение На Эксплуатацию, Приложение 05
    Q1D - Спорт. Передн. Сиденья
    SA9 - Диспомодель 4
    1BE - Спорт.Ход.Часть, Улучш.Шумоизоляция, Усил.Подвеска, Уменьш.Дорожн.Просвет Приблиз. На 25 Мм
    3FE - Сдвижной/Откидной Стеклянный Электролюк
    5K0 - Без Консервации Окрашенной Поверхности
    6E3 - Центральный Передний Подлокотник С Вещевым Отсеком
    7P1 - Опора Поясничного Позвонка С Электрорегул. В Передн. Сиденьях
    PH5 - код не найден
    PRN - Alloy Wheels, 205 X 400, 7-Spoke Design,With Run-Flat Pax System, 215/650 R 440 Tyres
    RBL - Radio Chorus With Front And Rear Speakers
    WL1 - Leather Trim "Vienna"
    WM3 - Sharan "Voyage Ii" For Belgium / Luxembourg With Rch Radio "Gamma"
    C6P - Легкосплавные Диски 7j X 16, Дизайн "9 Спиц", Et 45
    H6U - Шины 205/55 R 16
    N4J - Обивка Сидений: Ткань "Sport 4b0"
    1MR - Кожаное Рулевое Колесо (4 Спицы)
    1PC - Болты – Секретки
    5MC - Декор. Алюм. Вставки, Karo-Graphit
    6Q2 - Кожаная Рукоятка Рычага Кп
    6R2 - Кожаный Чехол Рычага Кп
    8GL - Генератор 120 А
    8UC - Аудиосистема Сhorus
    9AK - Кондиционер "Climatronic"
    9VD - Динамик(-И) Спереди И Сзади
    B0A - Деталировка Без Спец. Конструктивных Предписаний Для Страны
    B99 - Одобрение Типа Тс По Внутр.Регламенту, Но В Соотв.С Реглам. Ес В Ес
    E0A - Отсутствует Исполнение В Рамках Акции
    FA0 - Регламент Опытной Серии
    F0Y - Спец. А/М
    J0L - Акб 340 А (70 А*ч)
    L0L - Lhd Vehicle
    U1C - Панель Приборов С Шкалой "Км/Ч", Часы, Тахометр, Суточный Счетчик Пути В Км И Доп.Приб. (Вольтметр И Темп. Масла)
    0JH - Класс Грузоподъемности Передней Оси - Весовой Диапазон 8
    0LW - Спец. Таблички/Наклейки/Серт. Безопасности Для Германии
    0ST - Наклейки/Таблички На Нем./Франц. Яз.
    0TC - Коврики
    0VC - Руководство По Эксплуатации На Нем. Языке
    0YP - Класс Грузоподъемности Задней Оси - Весовой Диапазон 13
    1AH - Электронная Блокировка Дифференциала (Eds)
    1C1 - Антифриз С Темп. Замерз. До -25 Град. С, Допуск До -30 Град. С
    1D0 - Без Тягово-Сцепного Устройства
    1EX - Табличка С Vin-Номером
    1G3 - Полноразмерное Запасное Колесо, Легкосплавный Диск
    1KD - Задние Дисковые Тормоза
    1LB - Желтые Передние Суппорты
    1N1 - Усилитель Руля
    1SA - Без Дополнительной Защиты Картера
    1T3 - Аптечка И Знак Аварийной Остановки
    1WB - Диаметр Фланца Вала Кп 100 Мм
    1YC - Диаметр Фланца Вала Кп 100 Мм Для Заднего Моста
    1Z2 - Увеличение Объема Заправки Серийным Топливом
    2A5 - Оснащение Для Транспортировки Морским Путем (Защита При Транспортировке), С Тонкой Обивкой Сиденья
    2B0 - Без Дополнительной Шумоизоляции
    2G1 - Вставка Для Неэтилированного Бензина
    2K1 - Усиленные Бамперы
    2WA - Без Дополнительной Резины
    2Z1 - Надпись На Задней Части Кузова С Обозначением Модели И С Эмблемой Quattro, Без Указания Литража
    3B0 - Без Подготовки Для Постзаводской Установки Системы Креплений Детских Сидений Isofix Сзади
    3CA - Без Перегородки
    3C7 - Диагонально-Поясной Ремень Безопасности На Среднем Заднем Сиденье
    3NZ - Неразделенное Задн. Многоместн. Сиденье, Откидная Спинка 1/3 К 2/3, С Центр. Подлокотником
    3PF - Электрорегулировка Высоты Передних Сидений
    3Q6 - 3-Ий Подголовник Сзади
    3S0 - Без Релингов Крыши
    3V0 - Без Детского Многоместного Сиденья
    3X0 - Без Приспособл. Для Перевозки Длинномерн. Грузов
    3Y0 - Без Солнцезащитной Шторки
    4A0 - Без Обогрева Сидений
    4GH - Серая Тонировка В Верхней Части Ветров. Стекла
    4KC - Зеленое Теплозащитное Остекление
    4K1 - Центральный Замок C Дистанционным Радиоуправлением; 2 Радиоключа, 1 Ключ Складной
    4L2 - Затемняемое Зеркало В Салоне
    4M0 - Без Подстаканника
    4UE - Подушка Безоп.Водителя И Пер.Пасс.
    4W0 - Без Отсека Для Кассет/Компакт-Дисков
    4X1 - Бок. Подушка Безоп. Водителя И Передн.Пасс.
    5A5 - Облиц.Баг.Отдел. С Ящичками Для Мелк.Дет-Лей
    5C0 - Кузов Без Особых Мероприятий
    5D1 - Дистанционное Управление И Блокировка Дверей
    5E2 - Накладка Порога С Обшивкой Двери В Цвет Кузова
    5RQ - Сферич.Наружн.Прав.Зеркало Со Стор.Передн.Пасс.
    5SL - Асферич.Наружн.Зеркало На Стороне Водителя
    6M1 - Комбинированная Сетка
    6N0 - Без Брызговиков
    6U1 - Доп.Наружн. Противопыльные Уплотнители
    6V1 - Щиток Номерн. Знака Еэк
    6W5 - Передний Держатель Номерн. Знака (Фрг, Франция)
    6XD - Электрорегулировка И Обогрев Наружн. Зеркал
    7AA - Электронный Иммобилайзер
    7A0 - Без Cd-Чейнджера/Проигрывателя Cd
    7CA - Без Наклейки Радиоуправление
    7E0 - Без Накопителя Тепла/Доп. Обогрева
    7M1 - Пластиковые Накладки Порогов В Дверных Проемах С Металлическими Вставками
    7QA - Без Cd-Rom
    7Q0 - Без Прибора Навигации
    7X0 - Без Парковочного Ассистента
    8BG - Галог.Основн.Фары И Указ.Поворотов В Едином Корп. С Прозр.Рассеивателем
    8CC - Спидометр Не Опломбирован (Электронный Спидометр)
    8KA - Без Контроля Катализатора
    8K0 - Без Спец. Включения Ближнего Света
    8Q1 - Регулировка Угла Наклона Фар
    8TC - Задний Противотуманный Фонарь
    8T0 - Без Системы Gra
    8X0 - Без Очистителя Фар
    8Z5 - Система Охл. Дв-Ля, Исполнение 1
    9B0 - Без Устройства Telepass
    9M0 - Без Дополнительного/Автономного Отопителя
    9P0 - Без Контроля Ремней Безопасности
    9Q0 - Без Многофункционального Дисплея/Бортового Компьютера
    9W0 - Без Подготовки Для Постзаводской Установки Автотелефона/Автотелефона
  9. Bend
    Bend Завсегдатай
    14 авг 2005
    864
    S8, 6spd manual
    А4 1.6
    30 10 1997
    G0C - 5-Ступ. Механическая Кп
    M4T - 4-Цил.Бенз.Дв-Ль 1,6 Л/74 Квт, Mpi, Mveg 2/Eu3-D, Базовый Двигатель: T6u
    T6U - 4-Цил. Бенз.Двиг. 1,6 Л Агрег. 06b.1 (Алюм.)
    0DY - Спецкомплект Для Платформы B5 Audi– Детали Агрегатов –
    0K0 - Без Альтернативной Системы Привода
    1VG - Монтажные Детали Для 4-Цил. Двигателя
    1X0 - Передний Привод
    C06 - Разрешение На Эксплуатацию, Приложение 06
    SL9 - Упр. Код (Для Завода)
    2Z0 - Без Указания Типа И Литража
    6RA - Состоящая Из Одной Части/Одноцветная Передняя Панель И Обивка Дверей
    7P4 - Опора Поясничного Позвонка В Спинках Передних Сидений
    9Y1 - Индикация Наружной Температуры
    PH5 - код не найден
    PW1 - Winter Package Without Alternator 8gd
    WM1 - Sharan "Voyage I" For Belgium / Luxembourg With Rlb Monochrome
    N4G - Обивка Сидений: Ткань "Basis"
    5MF - Декор. Алюм. Вставки, Stars-Quarz
    8GD - Генератор 90 А
    8RN - 8 Активных Динамиков
    9T1 - Обогреваемые Жиклеры Омывателя Ветрового Стекла
    9X6 - Обогр.Личин.Дверн.Замк. Слева, С Микровыключ.
    C8N - Легкосплавные Диски 6j X 15 4b0 601 025l-Дизайн, Et 45
    F0A - Не Спец. А/М, Стандартное Исполнение
    H6S - Шины 195/65 R 15
    J1P - Акб 220 А (44 А*ч)
    L0L - Lhd Vehicle
    Q1A - Стандартн. Сиденья
    U1A - Панель Приборов С Шкалой "Км/Ч", Часы, Тахометр И Суточный Счетчик Пути В Км
    0JC - Класс Грузоподъемности Передней Оси - Весовой Диапазон 3
    0TC - Коврики
    0YC - Класс Грузоподъемности Задней Оси - Весовой Диапазон 3
    1AC - Антиблокировочная Система (Abs) Включая Систему Asr
    1BA - Стандартная Подвеска/Шумоизоляция
    1LZ - Передние Вентилируемые Дисковые Тормоза
    1PA - Стандартные Колесные Болты
    1S7 - Инструменты И Алюминиевый Домкрат
    1YA - Без Валов С Фланцами Кп Для Заднего Моста
    1Z0 - Первая Заправка Серийным Топливом
    2PG - Покрытое Вспененной Пластмассой Рул. Колесо, 4 Спицы
    3C1 - Поясной Ремень Безопасности Для Центрального Заднего Сиденья
    3FA - Без Люка (Сплошная Крыша)
    3L1 - Водительское Сиденье С Регулировкой Высоты
    3ND - Без Заднего Сиденья
    3Q1 - 2 Задних Подголовника
    4F1 - Центральный Замок
    4M6 - Держатель Для Напитков
    4R2 - Передние Электростеклоподъемники (При 4 Дверях)
    4SB - Косметическое Зеркало Слева Солнцезащитном Козырьке
    4TB - Космет.Зеркало Справа Солнцезащ. Козырьке
    4ZE - Черные Декор.Накладки
    5D0 - Без Несущей Частоты
    5E1 - Без Накладки Порога С Обшивкой Двери
    6E0 - Без Центрального Переднего Подлокотника
    6M0 - Без Резиновых Шнуров Типа "Паук" Для Крепления Багажа/Сетки/Сумки
    6Q1 - Пластиковая Рукоятка Рычага Кп
    6R1 - Чехол Рычага Кп Из Иск. Кожи
    6U0 - Без Доп. Наружн. Уплотнителей
    7M0 - Пластиковые Накладки Порогов В Дверных Проемах
    7QA - Без Cd-Rom
    8N4 - Прерывистое Включение Стеклоочистителя Ветрового Стекла
    8R1 - Третий Стоп-Сигнал
    8S4 - Салонн.Плафон Спереди И 2 Салонн.Плафона Сзади С Задержкой Выключения И Регулир.Яркости, 2 Плаф.Для Чтения Спереди
  10. ASK08
    18 авг 2006
    193
    Das Auto 2 штуки
    Огромоное спасибо Bend:hi: Bcё совпадает!!!
  11. ildarado
    ildarado Участник форума
    2 ноя 2006
    302
    Ауди 100 С4 AAR 91г.
    Пробейте пожалуйста VIN: WAUZZZ4A2MN028672
    Заранее спасибо.
  12. Pano77
    Pano77 Дачник)
    22 янв 2006
    1.680
    КМЗ 58
    У меня audi 100/45 92 год, почему в расшифровке комплектации указано два генератора разной мощности??
  13. Prozed
    Prozed Живу я здесь
    28 ноя 2006
    1.462
    Touareg + A4
    Бгалодарствую, камрад! :beer:
  14. vishy11
    vishy11 Bad e-mail
    31 окт 2006
    28
    Audi А4, 2.0, 01г.
    Пробейте Vin, пожалуйста. Заранее спасибо.
    WAUZZZ8EZ1A030003
  15. Stem
    Stem Bad e-mail
    1 ноя 2006
    40
    Audi A4 (B5) 1.6 96 г.
    пробейте плиз этот номер
    wauzzz4azrn066825
  16. Банкир_ПБ
    Банкир_ПБ Участник форума
    29 янв 2006
    142
    Hyundai i30
    Можно попросить пробить ВИН? ПРросто нашел одну ничегочечную в Питере, как бы не ушла...45, черная,, 2.6 литра...WAU ZZZ 4AZSN 064466
  17. Bend
    Bend Завсегдатай
    14 авг 2005
    864
    S8, 6spd manual
    23 12 1994
    M76 - 6-Цил.Бенз. Дв-Ль 2,6 Л/110 Квт Mveg 2 Базовый Двигатель: T7y
    T7Y - 6-Цил. Бенз.Двиг. 2,6 Л Агрег. 078.6
    S7U - "Корпоративные Продажи В Израиль"
    8T1 - Система Gra
    PH5 - код не найден
    RTC - Radio Beta Cc With Loudspeakers In The Front
    3AF - Электрорегулировка И Обогрев Правого Сферич.Наружн. Зеркала
    3BE - Электрорегул. И Обогрев Лев. Наружн. Зеркала С Плоск.Зерк.Стеклом
    6G1 - Дефлекторы Размораживателя Для Боковых Стекол, Регулируемые
    8AC - Магнитола “beta”
    8L4 - Антенна В Стекле
    8RE - 4 Передних Динамика: 2 Х 2 Канала
    8Z2 - Усиленный Вентилятор И Радиатор Системы Охлаждения Двигателя
    9X5 - Обогреваемые Личинки Дверных Замков Слева И Справа С Микровыключателем
    B01 - Одобрение Типа Тс По Внутр.Регламенту, Но В Соотв.С Реглам. Ес В Фрг
    C0V - Стальные Диски 6j X 15
    H3E - Шины 195/65 R 15 V (Черные)
    J0J - Акб 300 А (63 А*ч)
    L0L - Lhd Vehicle
    N0E - Ткань Jacquard Satin
    U0C - Панель Приборов С Электронным Спидометром, Суммирующий И Суточный Счетчик Пройденного Пути В Км, Тахометр
    0DT - Спецкомплект Для Платформы С Audi– Детали Агрегатов –
    0EA - Спецкомплект Для Кпп "B80" --Детали А/М--
    0F2 - Впрысковая Система Питания Бенз. Дв-Ля
    0MA - Без Наклейки «автоматический Пуск»,
    0SB - Наклейки/Таблички На Нем. Языке
    0TC - Коврики
    0W1 - Наклейка Для Коммутац. Блока Немецко-Говор. Стран
    1EC - Заводская Спецтабличка С Обозначением Модели А/М
    1G2 - Полноразмерное Запасное Колесо, Стальной Диск
    1T2 - Знак Аварийной Остановки В Багажном Отделении
    1WD - Диаметр Фланца Вала Кп Для Шарнира Типа Трипод
    2A0 - Без Оснащения Для Транспортировки
    2CA - Без Гидроблока
    2L0 - Без Нижней Защиты Топл. Бака
    2TB - Решетка Бампера Для Горячих Климат. Зон
    2V1 - Противопыльный И Антиаллергенный Фильтр
    3C3 - Трехточ.Ремни Безоп. С Автом.Катушкой Во 2-Ом Ряде Сидений С Регул. Высоты И 1 Поясн. Ремень Безоп. С Автом.Кат.
    3GA - Без Пола Груз. Отсека
    3J1 - Регулируемые По Высоте Передние Подголовники
    3N0 - Без Вещевых Отсеков В Багажнике
    3Q5 - Задние Подголовники
    3YB - Вещевые Карманы В Обивке Передн. Дверей
    3ZB - Задние Трехточечн. Ремни Безоп. С Автомат.Катушкой
    4D0 - Без Сидений С Функцией Вентиляции/Массажа
    4E0 - Дистанц. Отпирание Крышки Топл. Бака
    4SA - Без Левого Косметического Зеркала
    4U1 - 2 Сетчатых Кармана На Спинках Наружных Сидений 2-Ого Ряда
    4ZB - Комплект Блестящей Наружной Отделки Кузова
    5H1 - Облицовка Задней Двери
    5MJ - Декор.Вставки "Anthrazit Metallic" Для Передней Панели И Обивки Дверей
    6C0 - Уплотнитель Дверного Стекла Standard
    6D1 - Центральный Задний Подлокотник
    6EA - Кузов Без Доп. Боковых Облицовок (Защита От Ударов Камней)
    6FF - Корпус Наружных Зеркал И Дверные Ручки В Цвет Кузова
    6KG - Решетка Радиатора В Цвет Кузова
    6T0 - Без Освещения В Пространстве Для Ног
    8FA - Без Второй Акб
    8F2 - Белые Боковые Указатели Поворотов
    8G0 - Без Кабеля Антенны Для Рации
    8JH - Эллипсоидные Основные Фары Для Правостороннего Движения
    8LA - Без Доп. Контр. Приборов/Включателей
    8NA - Без Контроля Стояночного Света
    8R0 - Без Высоко Расположенного Стоп-Сигнала
    8S0 - Без Плафона Для Чтения
    8U0 - Без Доп. Приборов Измерения Пройденного Пути
    8WB - Противотуманные Фары
    8Y1 - Звуковой Сигнал С Двойным Тоном
    9A0 - Без Тревожн.Сигнал.Для Такси
    9BA - Без Доп. Электропакета Безопасности
    9EE - Жгут Проводов Для 6-Цил. Дв-Ля Со Впрыском
    9F0 - Без Подготовки Для Постзаводской Установки Комбинации Спецсигналов И Без Антенны Для Рации
    9G0 - Генератор 130 А
    9HA - Без Доп. Индикации Ошибки Функции
    9J0 - Без Высокого Звук.Сигнала/Регулировкой Последовательности Включения Звука
    9K0 - Без Стеклоочистителя Ветрового Стекла С Высокой Производительностью
    9PB - Рычаги/Щетки Стеклоочистителя С Доп. Аэродинам. Направляющими
    9R0 - Без Check Controll/Индикации Периодичности Технического Обслуживания
    9SA - Без Кодировки
    9S0 - Без Подготовки Для Постзаводской Установки Рации
    9V0 - Без Противоугонной Системы
    9Y0 - Без Индикации Наружной Температуры
  18. Bend
    Bend Завсегдатай
    14 авг 2005
    864
    S8, 6spd manual
    22/03/1994
    A100 2.8
    M7H - 6-Цил. Бенз. Дв-Ль 2,8 Л/128 Квт (V-6) (2 Клап. На Цил.), Регул. Катализатор, Баз. Двигатель: T7e
    T7E - 6-Цил. Бенз.Двиг. 2,8 Л Агрег. 078.1
    9X4 - Без Обогрев.Личин.Дверн.Замк. С Микровыключ.
    WB9 - Polo "Sports" With Electric Equipment Package Ii For 4-Door (4r3) France
    WC8 - Equipment Package Iii For 4-Door For Belgium / Luxembourg
    C4A - 4 Легкосплавных Диска "Wellington" 7 J X 15
    H0P - Шины 205/60 R 15 V
    1PB - Колесные Болты С Колпачками
    2V0 - Система Обогрева И Подачи Свежего Воздуха В Салон, Вентилятор С 4-Мя Реж. Работы И Функция Циркуляции Воздуха
    4TD - Космет.Зеркало С Подсветкой В Солнцезащ.Козырьке Передн.Пасс.
    4UB - Подушка Безоп. Для Nar
    8WD - Противотуманные Фары
    9V6 - Противоугонная Система С Иммобилайзером
    B32 - Одобрение Типа Тс По Внутр.Регламенту, Но В Соотв.С Реглам. Ес В Люксембурге
    L0L - Lhd Vehicle
    0FF - Производство Neckarsulm
    0LA - Без Спец. Табличек/Наклеек/Сертиф. Безопасности
    0TA - Без Ковриков
    1EY - Заводская Спецтабличка С Указанием Массы, Но Без Abe (Rdw)
    1T0 - Без Аптечки, Без Знака Аварийной Остановки
    1VC - Монтажные Детали Для 6-Цил. Двигателя (2 Кл. На Цил.)
    2C3 - Система Procon-Ten: Травмобезопасная Рул. Колонка С Преднатяжителем Ремней Безоп.
    3J4 - Передние Подголовники
    5MG - Декор. Вставки Из Корня Орех. Дерева Для Передн. Панели, Верхн. Части Центр. Консоли И Обивки Дверей
    6C1 - Уплотнитель Дверного Стекла В Качестве Фасонной Детали
    6FB - Корпус Наружных Зеркал И Дверные Ручки В Цвет Кузова
    6W1 - Передний Держатель Номерн. Знака (Италия)
    8AV - Без Магнитолы, С Разъемами Для Динамиков
    8BB - Двойная Фара И Указатель Поворотов Под Общим Прозрачным Стеклом
    8F0 - Без Боковых Фонарей
    8LB - Доп. Контр. Приборы (Напряжение, Давление Масла, Температура Масла)
    8Q0 - Без Регулировки Угла Наклона Фар
    8RM - 8 Динамиков Спереди И Сзади: 2 Х 2 Канала
    9R1 - Check Controll/Индикация Периодичности Технического Обслуживания
    9SA - Без Кодировки
  19. Bend
    Bend Завсегдатай
    14 авг 2005
    864
    S8, 6spd manual
    A4 2.0
    07/02/2001
    G0Z - Вариатор
    T0F - 4-Цил. Бенз.Двиг. 2 Л Агрег. 06b.E (Алюм.)
    C01 - Разрешение На Эксплуатацию, Приложение 01
    SA7 - Диспомодель 2
    4L6 - Автоматически Затемняющееся Зеркало Салона
    6XJ - Электрорегулировка, Обогрев И Автоматическое Затемнение Наружн.Зеркал
    7X2 - Сист.Контроля За Расстоян.Между Бампером И Препятств.Спереди И Сзади И Предупрежд.Акуст. И Оптич.Сигналами При Парк.
    8RY - Динамики Системы Bose
    8UD - Аудиосистема Concert
    PNH - Navigation System
    PRD - Cast Aluminium Alloy Wheels, 7jx16, 5-Arm "Aero" Design, With 215/55 R 16 Y Tyres
    PSV - Seat Heating For Front Seats
    P18 - Leather-Covered Sports Steering Wheel, 3-Spoke, With Gearshift Function
    CA1 - Алюминиевые Кованые Диски 7j X 16
    H3R - Шины 215/55 R16 93y
    U2A - Панель Приборов С Шкалой "Км/Ч", Радиочасами, Тахометром И Суточн.Счетчиком Пробега В Км
    1MU - Спортивное Кожаное Рулевое Колесо С 3 Спицами И С Клавишами
    4A3 - Обогрев Передних Сидений
    6PC - Кожаная Рукоятка Рычага Стоян. Тормоза
    7QB - Cd-Rom Для Фрг
    7Q9 - Система Навигации
    9Q4 - Многофункциональный Дисплей/Бортовой Компьютер С Check Control И Цветным Дисплеем
    A00 - Обычная Поставка, Без Самовывоза
    FC0 - Без Индивидуальной Комплектации
    FM0 - Базовое Исполнение
    L0L - Lhd Vehicle
    MW2 - 4-Цил.Бенз. Дв-Ль 2.0 Л/96 Квт (20 Кл.) Мрi, Eu4 Баз. Двигатель: T0f
    N3A - Тканевая Обивка Сидений, Рисунок "Tools"
    QE0 - Без Системы Отсеков
    QH0 - Без Системы Голосового Управления
    QQ0 - Без Доп. Фонарей (Освещение Внутри)
    QV0 - Без Тв-Тюнера/Цифрового Радиоприема
    VB0 - Без Автомат. Регул. Дистанции (Adr)
    VC0 - Без Устр-Ва Открыв. Гаражн.Ворот
    VR0 - Без Фронтальной Защиты
    V0A - Шины Без Определения Марки Производителя
    0CS - Спецкомплект Для Данного Класса А/М -8e0-
    0GG - Система Выпуска Ог По Стандарту Евро 4
    0G7 - Tiptronic
    0JJ - Класс Грузоподъемности Передней Оси - Весовой Диапазон 9
    0TC - Коврики
    0YH - Класс Грузоподъемности Задней Оси - Весовой Диапазон 8
    1G0 - Tire Mobility Set - Компрессор 12 В И Герметик Для Шин
    1WC - Диаметр Фланца Вала Кп 108 Мм
    1W0 - Без Холодильной Камеры/Охлаждения Перчаточного Ящика
    2KR - Наклейки/Таблички На Англ./Нем. Языке
    2T0 - Без Двойного Din
    3L3 - Передние Сиденья С Регулировкой Высоты
    4K4 - Центральный Замок С Радиодистанц. Управлением
    4N0 - Передняя Панель Standard
    4P2 - Модульное Напольное Покрытие, Сзади, Исп. 3
    4R5 - Передние Электростеклоподъемники
    4X3 - Подушка Безоп. Для Головы
    5K1 - Консервация Окрашенной Поверхности (Воск)
    5MA - Декоративные Вставки, Блестящий Пластик
    5RU - Зеркало На Правом Крыле
    6R0 - Отделка Рычага Акп
    6SS - Складной Ящик В Настиле Пола Багажн. Отделения, Убирающийся Во Внутрь
    7B0 - Без Розетки
    7K0 - Без Системы Контроля Давления В Шинах
    8KB - Контроль Катализатора
    9NX - Без Электронной Книги Учета Работы Водителя
  20. Bend
    Bend Завсегдатай
    14 авг 2005
    864
    S8, 6spd manual
    Эта не бъется старовата.
