Расход масла на А-4 2.0
Тема в разделе "A4", создана пользователем Vdimka, 25 апр 2006.
  1. smal
    smal Bad e-mail
    5 сен 2008
    563
    А4 8Е,2.0 ALT был.
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CB906%7E1%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} *page Section1 {size:595.3pt 841.9pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Ну что ж, как говорится, человек радуется два раза – когда покупает машину и …Удачной езды без разочарования!:nod:
  2. repair
    repair Bad e-mail
    27 фев 2008
    765
    VW JETTA V 2006 1.6 Manual
    Проздравляю!:nod:
    А коробка какая ? Я думаю, врядли DSG.
    Я тоже уже 1.5 месяца на Джетте-5 езжу, с 1.6 простым двиглом.
  3. kanin_vladimir
    kanin_vladimir Живу я здесь
    23 авг 2008
    1.813
    BMWX3 дизель+Golf6
    это 102 л.с. 8-ми клапанный или уже новый?
  4. tola
    tola Новичок
    29 июл 2009
    2
    Re: Ответ: Расход масла на А-4 2.0
    &nbsp;Вчера заменил этот патрубок вентиляции без снятия всасывающего коллектора. Затратил на это гдето час, т.к делал впервые. Итак чтобы снят патрубок вентиляции необходимо кусок мягкой проволоки примерно 30-40 см. диаметр 1-2 мм. и сталной штырь такой же длинны диаметром примерно 5мм.
    Итак, перерезаем старый патрубок под коллектором и отсоединяем от детали 11. Затем нужно отсоеденить верхнюю клемму генератора и клемму напротив, от всасывающего коллектора, и спрятать между генератором и коллектором. Теперь нужно вставить штыть в отверстие между щупом и отливом на коллекторе, конец попасть в выступ стопора 16 и наполовину вытащить аккуратно из патрубка, затем нужно просунуть руку между генератором и коллектором и полностю вытащить 16 наружу. Теперь также рукой вытаскиваем 14 называемый "глушитель", из блока. И вот теперь вытаскивая его наружу нужно смотреть в какую сторону будет направлен оставшийся кусок патрубка т.к примерно в таком положении его будет необходимо вставлять назад. При сборке вставляем патрубок концом присоединяемым к 11, вперед, между генератором и коллектором, пропускаем конец патрубка между коллектором и крышкой клапанов т.е на свое место. Затем , (тут я изрядно попотел т.к "глушитель" проходит между генератором и коллектором очень плотно) просовываем его во внутрь, вставляем нижнюю часть " глушителя" в блок при этом смазав место посадки смазкой. Чтобы вставить стопор нужно его перед этим закрепить проволокой но не намертво, а обмотнув 1-1.5 оборота. затем также просунув руку внутрь опускаете стопор в отверстие между щупом. Вставив стопор придерживаете его рукой, и стаягиваем аккуратно проволоку.
    Результат, несколько ссадин и довольное урчание моторчика
  5. repair
    repair Bad e-mail
    27 фев 2008
    765
    Да, да, старый как мир - 1.6(ну добавили кое-что новое на обвес) .:nod:
  6. tola
    tola Новичок
    29 июл 2009
    2
    Мой ответ на #25
  7. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    а по-моему лучше снять впуск и заодно все Г там почистить
  8. 777ВАНЕК
    777ВАНЕК Живу я здесь
    29 авг 2007
    1.305
    Volkswagen Passat B6 2,0 FSI 05г.; Rolls-Royce Phantom 6.75 i V12 48V (с водителем)
    Привет, да ты в самом начале? Ты хочешь повторить всё, начиная с 25 поста?
    Слушай, я сейчас "скорую" вызову, адрес свой давай!:hospital:
  9. 777ВАНЕК
    29 авг 2007
    1.305
    Сенька!
  10. 777ВАНЕК
    29 авг 2007
    1.305
    Да, я думаю, что не ДСГ, хотя не знаю как отличить и что это за ДСГ. У меня 6 скоростей, переключаются как на обычном автомате. ДСГ вроде с вариатором по плавности хода схож, типа двойное сцепление без разрыва мощности.
    За сколько Джетту взял? Я тут посчитал, что "убитый" Пассат поинтересней, чем пустая, хотя и не уставшая Джета.
  11. 777ВАНЕК
    29 авг 2007
    1.305
    Нет!!!
  12. Valecha
    Valecha Старожил
    1 ноя 2008
    6.381
    Кореец, будь он неладен)
    Ваня, молодца! Согласен полностью. Я вот тоже задумаюсь пересесть на что то поновее-шустрее и уже почти расстался со своей (кризис, будь он не ладен :hot:). Лучше 3-5-7 летний немец, чем новый японец (если конечно это не лексус). Как то у них все простенько и безвкусно. Пластик игрушечный, музыка писклявая, шумоизоляция никакая.
  13. kanin_vladimir
    23 авг 2008
    1.813
    BMWX3 дизель+Golf6
    а как же легендарные TYT LC Prado и TYT LC 100 за меньшие деньги :)
    Да, управляемость на скорости плохая, до салон проще, но зато по надежности и неубиваемости авто сложно найти...Про проходимость я молчу :)
    Для кого-то комфорт важнее, для ко кого надежность на первом месте.
    Я уже говорил, что когда у меня были чистокровные японцы у меня не было даже инструментов (кроме ключа на 10 чтобы плюсовую клемму на таможне закручивать), как появились немцы появился полный набор инструментов. Когда были японцы я даже про экзист не знал :rofl:
    Теперь вот снова хочу японский авто:hi:
    Ладно, давайте не начинать религиозные войны, а то модераторы достанут, что-нибудь да достанут ;)
  14. 777ВАНЕК
    29 авг 2007
    1.305
    Не зли Володьку! (япошки гуанно :))
    Короче с автоматом я видимо попал на тридцатку (немцы тоже гуано). Сейчас поштудировал интернет, выяснил, что у меня 09G коробка (не DSG) и у неё болезнь поломка гидроблока, как на моей прошлой Шкоде (Чехи тоже гуано). Мои симптомы тому подтверждение. Но т.к. толчки еле заметны, то буду эксплуатировать до осени, а там может и поменяю (на меня и продажу хватит и думаю коробочную тему закрыть). Хорошо, хоть запчасти есть, а то на Пежо, например, пол года ждать (Французы тоже гуано).
    Кондей ещё не дует, ставлю LO, даже вентилятор не включается. На клапаночек в одной трубке нажал, газ под давлением шипит, на пальце маслянистая жидкость оталась, надо тоже диагностировать.
    В общем 50-80 и "кот" уже будет почти не "в мешке". Бу-га-га!
  15. 777ВАНЕК
    29 авг 2007
    1.305
    ПРАДеды рулят! УАЗ Патриот за немерянные бабки, да и правый руль как я понял рекламируется!? Хотя, если затонировать, то не видно где водитель сидит.
    Тут байку кто-то мне рассказал. Парень поймал такси и остановилась девятка реэкспортная с правым рулём. Парень сел слева спереди, где у нормальных машин руль обычно. Таксист отъезжая резко вырулил и резанул какого-то борзого "упыря". Тот "упырь" не долго думая, останавливается, перегораживая дорогу таксисту, выходит, открывает дверь девятке и начинает ногами долбить пацана, который волею судеб оказался на левом переднем сиденье. Неповезло...
  16. kanin_vladimir
    23 авг 2008
    1.813
    BMWX3 дизель+Golf6
    Полностью согласен, причём редкостное!
    Иван, а глаза то тебе на что (а то сразу диагностика :))? Посмотри сначала на компрессор кондиционера глазами-там сразу видно если катушка рабочая то включается наружный шкив-его глазами видно если он начинает вращаться. Катушку компрессора можно проверить на обрыв тестером-снял разъём и всё. На катушке есть термопредохранитель fuse просто так не перегорает. Катушка меняется, стоит от 4 до 6тыс.руб.
  17. kanin_vladimir
    23 авг 2008
    1.813
    BMWX3 дизель+Golf6
    Иван ты не прав. Я всех праведников (те которые сторонники правого руля) которых знал пересадил на левый руль (привёз им из Японии bmw и opelей) :)
    Одно скажу честно-в немцах комфортней, но по надежности немцев мне уже были от них предъявы-типа я проехал всего 70 тыс.км. и у меня сломалась кнопка на педали тормоза-что за х? :)
  18. 777ВАНЕК
    29 авг 2007
    1.305
    Я обычно пупком смотрю или волосами, неплохая идея посмотреть глазами :thumbup:
    Володь, включение компрессора не происходит. Может датчик какого-нибудь давления или температуры... Надо подключать тестер, поеду на следующей неделе диагностироваться.
  19. 777ВАНЕК
    29 авг 2007
    1.305
    Не ори на меня!
    Японцы не безопасны! Могут морду набить, например, перепутав тебя с водителем. Или надо обогнать по трассе фуру на скорости, а не видно слева ничего, хорошо, если Кукурузник и по обочине можно по болоту его обогнуть, а если...
    Японцы гуано! Короче все гуано, кроме моего Пассата!
  20. kanin_vladimir
    23 авг 2008
    1.813
    BMWX3 дизель+Golf6
    :rofl::rofl::rofl:
    у матёрого перекупщика тестер должен быть всегда с собой.
    Знал я одного виртуозного психолога (у него был с собой всегда тестер), так он умудрялся купить на рынке утром неисправный по электрике авто по-дешёвке, с помощью простого тестера почнинить авто и в этот же день его продать! О VAG-comе он и не слышал:rofl:
