Расход масла на А-4 2.0
Тема в разделе "A4", создана пользователем Vdimka, 25 апр 2006.
  1. smal
    smal Bad e-mail
    5 сен 2008
    563
    А4 8Е,2.0 ALT был.
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CB906%7E1%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} *page Section1 {size:595.3pt 841.9pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Извини, если чем-то огорчил в своём высказывании!:beer:
    <o:p> </o:p>
    Объясняю – потому что я думаю (и даже на 99,99% уверен), что не бывает таких чудес на свете, что только исключительно к Альту такое пренебрежение и издевательство как в Германии, так и в других странах, куда потом продали этого индивидуума.
    ЗЫ Да, за исключением страны восходящего солнца, т.к. оттуда, по отзывам, идут нежрущие. Хотя мне никогда не понять, почему продают авто с пробегом 30 ткм (Восток – дело тонкое…:shock:)
  2. gosy97
    gosy97 Печенег
    2 май 2007
    4.642
    S6/09, 320dx/15
    А куда там ездить-то???
  3. gosy97
    gosy97 Печенег
    2 май 2007
    4.642
    S6/09, 320dx/15
    Есть у меня странный, но не праздный вопрос.
    Кто НЕ греет машину, прежде, чем поехать?
    Не греет - это: пристегнул ремень, завёл мотор, включил передачу и поехал....
  4. repair
    repair Bad e-mail
    27 фев 2008
    765
    VW JETTA V 2006 1.6 Manual
    Почему АЛТ называют чуть ли не единственным движком от Ауди, который жрет масло, будучи исправным ? Потому что, конструкция у него такая. При этой конструкции у немцев получился некоторый расход масла. Подтверждается статистикой владельцев новых машин. Этот расход был указан в мануале на машину и специально выделен жирним шрифтом. Немцы считают, что некоторый, не большой расход - нормой, именно на этом движке.
    И эта конструкция получилась, наверное, критичной к качеству и характеристикам масел. Что и подтвердилось у нас на форуме. Видимо, эта критичность и приводит к запуску масложора. Залейте другое масло в другой движок от Ауди и некоторый масложор появится, только если залить откровенное фуфло.
  5. Andron_AU
    Andron_AU Bad e-mail
    2 авг 2007
    874
    80-В4,A4-В5,6,8
    Может... С мая по ноябрь...
  6. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    я не грею
  7. gosy97
    gosy97 Печенег
    2 май 2007
    4.642
    S6/09, 320dx/15
    а сколько оборотов даёшь, как поехал??? примерно...
  8. michфуд
    michфуд Старожил
    12 окт 2005
    15.243
    A4 8E 2,0 01
    не больше 2500.
    обычно 1500 и так долго, даже через пару километров на хх сваливаюсь ибо пробка сразу.
    в мороз только лютый чтобы побыстрее нагреться я до пробки еду в ручном режиме - там кручу до 5000 и держу некоторое время, а то в пробку приедешь а движка еще холодная - замерзнешь пока прогреется.
  9. smal
    smal Bad e-mail
    5 сен 2008
    563
    А4 8Е,2.0 ALT был.
    куда то же они ездят!
    <link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CB906%7E1%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} *page Section1 {size:612.0pt 792.0pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Мож на Фудзияму, мож в булочную…:D
    Я почти всегда грею.
  10. slavik86
    slavik86 Завсегдатай
    25 дек 2008
    503
    A4/B6 2.0 01г.
    грею - зимой, летом - нет!
  11. kanin_vladimir
    kanin_vladimir Живу я здесь
    23 авг 2008
    1.813
    BMWX3 дизель+Golf6
    в частности на этом авто (продан с пробегом 24тыс.100км) закончилась гарантия от дилера-на следующей неделе машина была продана и я думаю была куплена у этого же дилера новая машина (и её тоже продадут как закончится гарантия).
    и ещё пример-уже лично мой. Я купил праворукий 5-ти летний TYT RAV4 с пробегом 11тыс.км из дефектов заменена в Японии задняя дверь в сборе (отмечено в аукционнике) и по кузову косметический косяк на левой задней двери (царапина с вмятиной длиной 2 см). Авто просто НОВОЕ, я покатался за год до 35тыс.км (была одна машина в семье) и продал его с пробегом в 35тыс.км. Купил перекупщик, оставил себе и при встрече просто пищал от восторга.
    Мне за год авто любая машина надоедает и я хочу другую. А японец 3 года ездил на ALTе-я бы столько не выдержал.
    Есть авто и с большими пробегами, они идут по цене навоза, наши соотечественники с удовольствием их покупают, а что-105тыс.км и закончившийся сякен-низкая цена это и была мечта любого российского покупателя.
  12. kanin_vladimir
    23 авг 2008
    1.813
    BMWX3 дизель+Golf6
    я летом не грею. Сел, запустил двигатель, одел ремень, подождал 30 секунд и поехал. Обороты до 1500-2000.
    зимой я не ездил на ALTе.
    В холодное время запустил двигатель, включил обогрев сидений, сел, одел ремень, подождал пока стрелка тахометра не упадёт вниз на одно деление (ориентировочно хотя бы до 1000), включил D, постоял 5-10 секунд, включил R, постоял 5-10 секунд, включил D и поехал. Обороты до 1500-2000.
  13. gosy97
    gosy97 Печенег
    2 май 2007
    4.642
    S6/09, 320dx/15
    видите корреляцию?
    (у Мича Лукойл, да и не жалуется он особо)
    Нельзя греть современные машины. Завёл и поехал 2000-2500.
    Как исключение, типа, ребёнка в холодную машину не сажать - можно греть.
    Не греть + топливо Евро4 - и есть ответ ;)
    (но это не продлит жизнь вашему термостату. хы! :bt:)
    Осталось решить вопрос топлива.
  14. Алег
    Алег Живу я здесь
    25 мар 2009
    2.066
    я никогда не грею , как-то не удобно ванять соседям под окнами .
  15. smal
    smal Bad e-mail
    5 сен 2008
    563
    А4 8Е,2.0 ALT был.
    #12155 smal, 10 ноя 2009
    Гося, ты сам - то веришь в то, что в Нижнем Новгороде и Краснодаре топливо Евро4, а в остальной Рассее нет?!:bt: Да по-моему и в Германии Альты кушают, а уж там грех жаловаться на топливо! так что сомневаюсь я...:nod:
    PS Кстати, по московским АЗС:
    любопытствующие могут ради интереса поюзать т.н. чёрные списки АЗС - так они практически не меняются от проверки до проверки!!! Так что о каком Евро4 можно говорить?...
    Да и не такой я наивный, чтобы при этом:
    я поверю в Евро4, не говоря уж о чудо-бензинах от Лукойла и от BP?:snooks:
  16. grust
    grust Живу я здесь
    27 сен 2005
    1.564
    A4 2.0, 2007
    давненько сюда не заходил)
    авто грею две минуты примерно, до падения холостых до 800об. дальше еду около 1,500 об пока не нагреется.
    зимой могу иногда прогреть пока стрелка не дернется.
    95ульт на бп
    39 ккм.
    1,5л от то до то.
  17. gosy97
    gosy97 Печенег
    2 май 2007
    4.642
    S6/09, 320dx/15
    свежая она исчо, колонка может хорошая, обороты может крутишь - мильён факторов :)
  18. gosy97
    gosy97 Печенег
    2 май 2007
    4.642
    S6/09, 320dx/15
    Вах, Андрей!
    Ну а снизу я что написал? Осталось решить вопрос топлива.
    Я то как раз верю, что оно поголовно не-до-Евро-2 здесь, в РФ!!! И это Проблема.
  19. sseerreeggaa
    sseerreeggaa Завсегдатай
    15 июл 2009
    781
    Ауди А4 Б8 2.0 ква механика
    Что за утверждение? На чем основаны знания? Почему нельзя? Хочу подробностей.
  20. gosy97
    gosy97 Печенег
    2 май 2007
    4.642
    S6/09, 320dx/15
    Сейчас расскажу свою точку зрения.
    А знания - они у Завода, обращайтесь и они "конечно же вам всё расскажут" :)
