Широкие возможности VAG-COM
Тема в разделе "Ремонт Ауди", создана пользователем boich, 3 авг 2011.
  1. V0L
    V0L Участник форума
    13 июн 2011
    377
    Q5 2.0 TFSI 2009
    это для 3g меню или на 2g тоже работает? Если да. то именно находится?
  2. VasilbV
    VasilbV Директор БАНи
    13 май 2008
    13.357
    Вожак стаи
    Griff, чёт нарыл по ДХО
    Adjust LED Brightness This will allow you to change the intensity of the LED's when your headlights are on. By default the LED's are only 8-9% or brightness.
    [09 – Cent. Elect.]
    [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3
    Enter new value for LED brightness i.e. "100" If you want LED's at 100%.
    Values bellow 5 turns the LED's off and generates an error code and warning in DIS .
    Надо поробовать...
    1 человеку нравится это.
  3. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    у брата 2G. что-то совпадает, что-то нет
  4. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    Ещё по лампочкам....
    Keep LED DRL's on With Turn Signals
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 3 Bit 7 - Change 1 to 0
    Turn off amber side markers (US models Only)
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 10 Bit 3 - Change 1 to 0
    Front Fog Lights stay on with High-beams **
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 1 - Change 1 to 0
    Rear Fog Lights stay on with High-beams **
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 2 - Change 1 to 0
    Headlights on all the time **
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 5 - Change 0 to 1
    Fog Light turns on with turn signal (Curb Side Lighting)**
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 4 Bit 0 - Change 0 to 1
    *Headlights must be on without Fog Lights for this to work.
    Front Turn Signals as Parking lights **
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 10 Bit 0 - Change 0 to 1
    Once the change has been made you can enable the front turn signals as DRL's by making the following change
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 2 Bit 6 - Change 0 to 1
    Emergency Brake Flashing Lights
    This change allows the brake lights to flash rapidly in the event of emergency braking.
    [46 - Comfort System]
    [Coding - 07] -> [Long Coding Helper] -> Byte 8:
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    I have not been able to confirm this working on my own car although it is coded. I have seen video's of people who have enabled this though and it's cool feature. During emergency braking your brake lights strobe momentarily before going solid.
    Keep LED's at Full Brightness with Parking Lights
    This will stop the LED's from dimming when the parking lights are turned on.
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 3: Bit 2 - Change 0 to 1
  5. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    Вот это что такое?
    Alarm
    Enable Double Disarm Beep
    [46 - Central Conv.]
    [Adaptation - 10] -> Channel 63 -> Add 4 to what ever value is there. I.E. if the current value is 3 your new value will be 7
  6. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    Где-то тут читал, что при отключении контроля пристёгнутых ремней безопасности мы лишаемся автоматического снятия с ручника при трогании на В
    Вот вроде решение
    Auto Release Brake without Seatbelt On **
    This will allow you to move your car and have the brake release without your seatbelt on.
    [53 - Parking Brake]
    [Security Access - 16] (Enter code presented by program)
    [Adaptation - 10] -> Channel 7 change 1 to 0
  7. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    все написанное выше точно прокатывает для 4-ки 2010 года. на 4F - пока не проверено
  8. boich
    boich Участник форума
    19 апр 2011
    473
    Польша
    Q7 3.0 Tdi crca
    Сколько секунд должны работать омыватели фар??? У меня секунд 5-6 и так, что вся машина мокрая!
  9. Rivera
    Rivera Участник форума
    1 окт 2011
    173
    A6-C6-3.2quattro®
    Люди, друзья, товарищи!!! Не хотел бы показаться дебилом, но всё же)))))))
    Что мне необходимо для того, что бы я мог подключить авто к компу и вносить какие-либо изменения??? Какая нужна программа (под ВИНДУ или на МАКЕ то же что-то можно установить?), какой нужен шнур, что сколько стоит и где всё это купить??? Может кто-то возьмёт лично надо мной шевство и воспитает меня в этом вопросе???
    Заранее очень признателен и благодарен!!!
  10. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    Начни вот с этой темы http://www.audi-club.ru/forum/showthread.php?t=237364
    тебе нужен провод за 3500
    за 1200 только для машин до 2005 мод. года
    Прикупи шнурок, далее изучай форум
  11. Rivera
    1 окт 2011
    173
    A6-C6-3.2quattro®
    Примного БЛАГОДАРЕН!!!
  12. bonuztmb
    bonuztmb Участник форума
    31 авг 2011
    452
    Q7 3.6 09г
    Здраствуйте судь моей проблемы такова. Полез искать блок парктроника в правую обшивку в багажнике, нашёл. На нём 2 кода 4F0 910 283 и 4F0 919 283 . И НИКАКИХ букв вконце нету.... машина 04.2004 a6 c6 .
    Я и не надеялся увидеть там что то кроме буквы А .... но там нет никакой буквы ....
    Подскажите может я не то что делаю ... Блок стоит - снимаем правый кожух в багажнике , он там если смотреть из багажника слева вверху ...
  13. Happyman
    Happyman Завсегдатай
    2 янв 2009
    597
    А6, 3.2Q BYU2008г
    Да Чтож это такое, сколько раз здесь и каким шрифтом писать что данный топик - это справочник по проверенным кодам а не тема обсуждения блока парктроника и обшивки дверей....
  14. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    Лана тебе, не :chainik:
    Лучше скажи, у тебя рестайл?
    Если да, то яркость LED где подправить?
    И омыватель фар можно как-то сделать, что бы включался ТОЛЬКО при длительной работе (1-2 сек) омывалки стекла
  15. Йуч
    Йуч Участник форума
    10 мар 2011
    308
    Q7 4,2 fsi '08
    Друзья, реально ли научить а6 сворачивать зеркала при постановке на охрану?
  16. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    ОД мне сказал, что только на новых
    на С6 - нет, хоть ап стену расшибись ((
  17. Happyman
    2 янв 2009
    597
    А6, 3.2Q BYU2008г
    Дорестайл, с лед нужно попробовать как у ку7, с омывателем сколько читал подобные томики инфы не встречал, только полное отключение.
  18. V0L
    V0L Участник форума
    13 июн 2011
    377
    Q5 2.0 TFSI 2009
    Скажите, где, если вообще есть, в vcds такое длинное кодирование из сообщения VasilbV? [​IMG]
  19. VasilbV
    13 май 2008
    13.357
    Вожак стаи
    Выбираешь интересующий тебя блок, далее кодирование, далее увидишь вот такую картинку с кнопкой "Помощник длинного кодирования"
  20. V0L
    V0L Участник форума
    13 июн 2011
    377
    Q5 2.0 TFSI 2009
    а у меня не появляется такой... в каком блоке именно твоя картинка?
