A6 C6 Технические проблемы и неисправности
Тема в разделе "4F C6", создана пользователем Lawyer, 11 апр 2009.
  1. aSquare
    aSquare Новичок
    23 сен 2015
    81
    Q7/4L 3.0TDI 06г.
    Добрый день!
    Можете помочь разобраться с пару ошибок.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    Shop #: WSC 02325 785 00200
    VCID: 66C8409C518B357482-8032
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 327385 km
    Time Indication: 0
    Date: 2018.03.01
    Time: 16:59:15
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4086
    Hex Value: 0x002D
    Hex Value: 0x05A4
    Hex Value: 0x00FF
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000000326483
    Coding: 0000278
    VCID: 1C3C2274DF473FA4E4-8048
    1 Fault Found:
    01854 - Heated Seat; Front Right (Z46)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 327385 km
    Time Indication: 0
    Date: 2018.03.01
    Time: 16:59:19
    Freeze Frame:
    Temperature: 20.0∞C
    Address 15: Airbags Labels: 4F0-910-655-8R.clb
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 42 AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0HLU5V
    Coding: 0013362
    VCID: 29520BA08015DA0C6F-807C
    Subsystem 1 - Serial number: 6332CSME14681632Z
    Subsystem 2 - Serial number: 6342CSME14684812$
    Subsystem 3 - Serial number: 6352QSME1939335BL
    Subsystem 4 - Serial number: 6362QSME19313249A
    Subsystem 5 - Serial number: 63734SME19284835+
    Subsystem 6 - Serial number: 63834SME18762347/
    1 Fault Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
    001 - Upper Limit Exceeded - MIL ON
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01024180710000
    Coding: 0402161
    Shop #: WSC 02335 785 00200
    VCID: 2E58F8BCB9FBBD34BA-807A
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    2 Faults Found:
    01504 - Bulb for License-Plate Light (X)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 187
    Reset counter: 17
    Mileage: 325109 km
    Time Indication: 0
    Date: 2017.10.03
    Time: 22:55:41
    01134 - Alarm Horn (H12)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 17
    Mileage: 342508 km
    Time Indication: 0
    Date: 2006.05.11
    Time: 05:43:54
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000321
    Shop #: WSC 80093 222 69422
    VCID: 20441684F32F1B4438-8074
    1 Fault Found:
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
    011 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101011
    Fault Priority: 2
    Fault Frequency: 91
    Reset counter: 249
    Mileage: 324792 km
    Time Indication: 0
    Date: 2017.09.30
    Time: 10:11:34
    Freeze Frame:
    Voltage: 13.04 V
    Count: 84
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06330631503276
    Coding: 0201116
    Shop #: WSC 131071 1023 2097151
    VCID: 28540EA49B1FE30470-807C
    2 Faults Found:
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 327385 km
    Time Indication: 0
    Date: 2018.03.01
    Time: 17:00:12
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 17
    Mileage: 327385 km
    Time Indication: 0
    Date: 2018.03.01
    Time: 17:00:12
    Заранее спасибо
  2. Masterz
    Masterz Живу я здесь
    16 июл 2006
    2.318
    Латвия
    A6 AvQt '08 2.7TDi 6HP
    А что непонятно-то. Там в деталях описано, какая именно лампочка не горит, какой именно сенсор парктроника издох.
    Про ручник - возможно перегорел один из предов питания моторов - расположены в багажнике, чёрный блок - 3 & 4-ый.
    Если оба в норме - тогда проводка блок-мотор.
    Меняй лампы, датчики парктроника, лечи подогрев сидушки. Часть ошибок "уйдёт" сама, часть надо будет сбросить.
    aSquare нравится это.
  3. Андрик78
    Андрик78 Старожил
    22 июн 2012
    20.372
    Q5
    Может у него аккумулятор накануне разряжался? Просто ошибки стереть забыл? :)
  4. aSquare
    aSquare Новичок
    23 сен 2015
    81
    Q7/4L 3.0TDI 06г.
    Ошибки не стираются...
  5. aSquare
    aSquare Новичок
    23 сен 2015
    81
    Q7/4L 3.0TDI 06г.
    А по конкретнее можно ?
  6. Masterz
    16 июл 2006
    2.318
    Латвия
    По ручнику - может. А по обрыву лампы освещения номера - что-та сомневаюсь.
  7. Андрик78
    Андрик78 Старожил
    22 июн 2012
    20.372
    Q5
    Там и подушки и сидушки ....
  8. aSquare
    aSquare Новичок
    23 сен 2015
    81
    Q7/4L 3.0TDI 06г.
    Сильно затратный ремонт ?
  9. Masterz
    16 июл 2006
    2.318
    Латвия
    По сидушке - начиная от банально разомнутого соединения под сидением до повреждённого нагревательного элемента. Ценник сильно разный.
  10. Nikolaygerasimov
    Nikolaygerasimov Завсегдатай
    2 июл 2017
    654
    A6 C6 3.0tdi quattro на пневме
    Нагревательный элемент тяжело повредить, скорее всего как обычно соединительный провод переломился в том месте где провод присоединяется к нагревательному элементу спинку
  11. popov_
    popov_ Живу я здесь
    25 фев 2011
    1.185
    А6С6 2,0TDI 07г.
    А что не так с Беларусьнефтью? Или так, абы ляпнуть?
    Заправляюсь и всё норм.
  12. Андрик78
    Андрик78 Старожил
    22 июн 2012
    20.372
    Q5
    #1832 Андрик78, 8 мар 2018
    А я заморозил фильтр прошлой зимой "всего" в -15? Прекрасная зимняя солярка на беларуснефти :thumbdown:
    А ты заправляйся, пока норм. Хто ж мешает :hello:
  13. fima76
    fima76 Живу я здесь
    2 июн 2012
    3.016
    A6 Avant 2,7BPP07г
    Аналогичная ситуация была у меня только в Москве на Нефть-Магистраль,правда машина была Пежо Партнер.
  14. Руxa18
    Руxa18 Новичок
    10 мар 2018
    7
    Добрый вечер столкнулся с такой проблемой, вечером приехал все было хорошо, утром хотел завести в никакую, крутит но не заводит, компрессия упала в целиндрах, мотор 2.4 BDW
  15. Тубабу
    Тубабу Живу я здесь
    8 ноя 2012
    3.573
    А6 3 TDI квак 08
    Для начала проверить наличие бензина в баке, ну и желательно подключить шнурок ошибки почитать.
  16. Nikolaygerasimov
    2 июл 2017
    654
    С чего стало понятно про компрессию?
  17. Тубабу
    Тубабу Живу я здесь
    8 ноя 2012
    3.573
    А6 3 TDI квак 08
    Больше всего с потолка, что в голову пришло.
    pa-shocka4 нравится это.
  18. Nikolaygerasimov
    2 июл 2017
    654
    Потому и спросил, но мало ли
  19. pa-shocka4
    pa-shocka4 Старожил
    4 ноя 2008
    8.808
    Жигулевские привычки?) Тут тебе кибернетике, чуть что - зови Васю для проверки:umnik:
  20. Alex_z
    Alex_z Старожил
    13 июн 2008
    17.790
    Корея Северная
    A6 C6 3.0TDI 2008
    Вообще-то когда компрессия пропадает,это очень даже чувствуется
    На прошлой машине когда на ночь Лавра в цилиндры налил, с утра в полной мере этот "эффект" ощутил,тут не надо даже автомехаником быть,сразу все понятно
