тюнинх приборки и вывод показаний
Тема в разделе "Мультимедиа и автозвук", создана пользователем сидоров 1968, 17 апр 2011.
  1. Igor`
    Igor` Участник форума
    2 дек 2008
    370
    A4 B8 FL
    всем привет, я в теме, даже м.б. и заказал но сомневаюсь в совместимости с моей машиной...:confused::confused::confused:
  2. Артёмка
    Артёмка Живу я здесь
    18 ноя 2005
    1.181
    Audi A2 1.6 FSI
    а комп у тебя полный?
  3. Igor`
    2 дек 2008
    370
    A4 B8 FL
    #103 Igor`, 6 сен 2011
    комп полный, но у него на сайте написано что к комбинации приборов помимо CAN шины должна идти еще доп шина с магнитолы или навигации.
    или я чет неправильно понял?
    Compatible cars
    The FIS-Control only works with cars equipped with the "big" display in the instrument cluster. The half-size displays are not supported (but often it is possible to upgrade to the full display by simply replacing the instrument cluster... search the internet for more information).
    The FIS-Control works with CAN-Bus and non-CAN-Bus clusters as long as the 3-wire-bus (CLK, DAT, ENA) is available.
    Clusters that only have CAN-bus will not work.
    For clusters that support both busses, it is important to know that only one interface may be connected at a time. Therefore it is not possible to have a navi (connected via CAN) and the FIS-Control (connected via 3-wire-bus) both using the DIS-display. (If the navi is for the 3-wire-bus too, it will work.)
    The FIS-Control is already tested as working in the following cars:
    Audi A4 B5 (model years since 1997)
    Audi A6 C5
    Audi S3 8L
    Audi S4 B5 (all model years)
    Audi TT 8N
    Volkwagen T4
    Volkswagen Golf IV
    Volkswagen Passat B5
    Volkswagen Sharan I (the ECU of newer models don't use KWP1281, so the FIS-Control will not be able to connect)
    Ford Galaxy WGR
    I expect that the FIS-Control will work in all other VAG cars that meet the requirements listed above. The pins of the 3-wire-bus are labeled "clock", "data" and "enable". If you have these three pins at your cluster, chances are good that the FIS-Control will work.
  4. Parenj
    Parenj Живу я здесь
    30 май 2007
    2.895
    A4 avant 1.9AFN 98
    Это для того чтобы верхняя часть дисплея была задействована.
  5. sergeynik S6
    sergeynik S6 Живу я здесь
    27 янв 2005
    3.415
    Tesla model X 2020
  6. Parenj
    Parenj Живу я здесь
    30 май 2007
    2.895
    A4 avant 1.9AFN 98
  7. sergeynik S6
    27 янв 2005
    3.415
    Tesla model X 2020
    эт исходники для атмел процессора AT90S2313 можно взять любой современный
    в исходниках главное процедуры доступа к строкам дисплея. ищите пионера с паяльником там надато 78l05 + проц + пара кондюков + провода
    и решайте че куда выводить.
    в примере для с4 выводится инфа со штатных датчиков ЕГТ и давления наддува
    1 человеку нравится это.
  8. Parenj
    Parenj Живу я здесь
    30 май 2007
    2.895
    A4 avant 1.9AFN 98
    Спасибо!
    Будем надеяться, что среди нас найдутся пионеры и не поленятся сделать отчёт чё куда и как.
  9. ch1n
    ch1n Bad e-mail
    28 дек 2007
    34
    Passat b5
    Парни надо Fis брать и делов то ...
  10. Parenj
    Parenj Живу я здесь
    30 май 2007
    2.895
    A4 avant 1.9AFN 98
    Бери! Делов-то? А мне лично интересней узнать как собрать самому.
  11. ch1n
    ch1n Bad e-mail
    28 дек 2007
    34
    Passat b5
    ну я пожалуй тож подожду ... 6 к нет лишних :)
  12. SRF
    SRF Живу я здесь
    21 авг 2006
    1.826
    Allroad 2.7T 1.5 bar
    Фис стоит как мультитроникс, нужно функционал сравнить. Плюс фис в подключении к сток дисплею
  13. inneet
    inneet Новичок
    3 апр 2011
    82
    TT (8N3) 1.8TQ 225
    Мультитроникс больше как маршрутный комп, а вот фис функционал серьезнее. И правильно замечено - лишней коробки на торпеде не будет!!!
  14. evgen_72rus
    evgen_72rus Старожил
    20 дек 2009
    14.079
    Авто мото
    Мёртво всё... пионеров не нашлось?
  15. al mazud
    al mazud Живу я здесь
    20 июн 2007
    3.285
    q3 2.0tq '14
    хочу на 8е, с цветной приборкой
  16. dus72
    dus72 Старожил
    4 янв 2009
    12.791
    Тюменская обл.
    957 4.5t Magnum 23"
    ой а как я хочу!
  17. Parenj
    Parenj Живу я здесь
    30 май 2007
    2.895
    A4 avant 1.9AFN 98
    Хотят многие, а пионера с паяльником так и нету :( Обидно :(
  18. mixailromanov
    mixailromanov Живу я здесь
    20 фев 2010
    1.758
    ищу coupe quattro!
    да есть пионер))) скажите тока че и куда паять. и еще- у меня дисплей большой и нет кнопочки на перекл дворников, показывает только остаток км снизу. мне наверно надо переключалку менять или я обречен? и с заменой переключалки вопрос не решится?
  19. BOP4YH
    BOP4YH Живу я здесь
    5 мар 2009
    2.270
    Калининградская обл.
    Zeekr 001, TT 8S 2.0
    Заказал FIS неделю назад. Жду. Посылка отправилась, но отследить по сайту не получается. Если все таки не затеряется и дойдет - поставим, попробуем, потом и отпишусь :hi:
  20. Parenj
    Parenj Живу я здесь
    30 май 2007
    2.895
    A4 avant 1.9AFN 98
    Знал бы сам что, куда и как... давно бы занялся :) Если кнопочка задействована в управлении, то думаю доставить не проблема.
