лямбдакоррекцию глянь на хх на полностью прогретом моторе, к примеру в 1-й группе измерений двс, при правильной смеси показания должны быстро меняться от + к - около 0.
Блин поездил сейчас уже 5 и 6 отключает ошибка по пропускам p0306 cylinder 6 misfire detected а по 5 обрыв
Thursday,22,January,2015,16:18:39:55062 VCDS Version: Release 11.11.4 Address 03: ABS Brakes Labels: 4F0-910-517.lbl Control Module Part Number: 4F0 910 517 AL HW: 4F0 614 517 BA Component and/or Version: ESP8 quattro H03 0060 Software Coding: 0020921 Work Shop Code: WSC 02325 785 00200 VCID: 6ED879D279401368C39 1 Fault Found 01314 - Engine Control Module 013 - Check DTC Memory Freeze Frame Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 5 Reset counter: 72 Mileage: 145424 km Time Indication: 0 Date: 2015.01.22 Time: 12:42:04 Freeze Frame Hex Value: 0x0000 Hex Value: 0x42A2 Hex Value: 0x0025 Hex Value: 0x01AE Hex Value: 0x00FF Thursday,22,January,2015,16:17:11:55062 VCDS Version: Release 11.11.4 Address 01: Engine Labels: None Control Module Part Number: 4F1 910 551 HW: 4F1 907 551 B Component and/or Version: 3.0 V6 TFSI 0050 Software Coding: 0105000C190F0120 Work Shop Code: WSC 00375 935 84219 VCID: E0C497EA33943518C15 3 Faults Found 000774 - Cylinder 6 P0306 - 000 - Misfire Detected Freeze Frame Fault Status: 01100001 Fault Priority: 6 Fault Frequency: 1 Mileage: 145428 km Time Indication: 0 Date: 2015.01.22 Time: 13:30:22 Freeze Frame RPM: 2176 /min Mass Air / Rev.: 359.7 mg/str Temperature: 75.0°C Part Throttle Time: 153.6 s Speed: 0.0 km/h 004874 - Cylinder Disabling P130A - 000 - Freeze Frame Fault Status: 01100001 Fault Priority: 2 Fault Frequency: 1 Mileage: 145428 km Time Indication: 0 Date: 2015.01.22 Time: 13:30:22 Freeze Frame RPM: 2848 /min Mass Air / Rev.: 288.9 mg/str Temperature: 75.0°C Part Throttle Time: 153.6 s Speed: 0.0 km/h 053271 - Please Check Fault Codes in Control Module for ABS Brakes U1017 - 000 - Freeze Frame Fault Status: 01101000 Fault Priority: 1 Fault Frequency: 1 Mileage: 145428 km Time Indication: 0 Date: 2015.01.22 Time: 13:30:22 Freeze Frame RPM: 2816 /min Mass Air / Rev.: 114.5 mg/str Temperature: 76.5°C Overrun Load: 0.0 % Speed: 0.0 km/h
Поменял свечи пока полет нормальный. Посмотрел лямбды в 1 группе в 3 окне показания скачу -3.8....1.5 в четвером -0.5....1.5
